Hi,@diego_charles
Thanks for your reply!
It may not be just disabling global interrupts. For example, when I erase FLASH, other system interrupts block because it takes 100 milliseconds to erase a sector, which affects the response of other interrupts such as timers. However, this has a significant impact on our production application.
How do I solve the problem of erasing flash without affecting other interrupt responses? Can you provide a solution?
Jarman
