FreeRTOS I2C Example on FRDM_K66 Master Error on Write
ソリューションへジャンプ
2,706件の閲覧回数
jeremyanderson
I'm using MCUExpresso IDE with SDK2.x.  I've imported the SDK example of freertos I2c.  Everything works fine with compiling and debugging, but it always fails with a kStatus_I2C_Addr_Nak.  Is there something I need to do with teh board to make this example work?
2,399件の閲覧回数
jeremyanderson
OK, RTFM.  Problem solved.  Read the doc/readme.txt file and the proper connections are shown.
2,400件の閲覧回数
jeremyanderson
