Basic timer usage for periodic operation
1,043 次查看
next_devenv
Could the community pls advise guidance, some refs or example/sample code for a basic use of a precision timing operation, for a newbie?
I'm using the QN908x DK, and would like to perform a specific operation every 10u seconds.
979 次查看
estephania_mart
It will depend on which kind of operation you need. Is the operation with the usage of the Wireless Connectivity Stack or is it just to get to know the MCU within it's peripherals?
I would recommend you to start with some of the driver and demo examples available in the SDK that you can download from this page as well as you can download the IDE.
If you want to understand in a general view Bluetooth LE and a little bit of the stack you can check this video series, those videos are for the KW41 the stack is very similar to the QN9080.
Estephania
