stdio.h
2,890 次查看
schakoma
Hello. I am trying to read and write integers to a file using the getw() and putw() using the stdio.h. However each time I use these functions I get an error: no reference to putw() or getw(). How can I add these functions to stdio.h or are there other functions I can use to write integers to files. I am using MCUXpresso v11
2,879 次查看
ErichStyger
Specialist I
Are you using a semihosting library? For example:
Otherwise: I wrote recently about that topic here: https://mcuoneclipse.com/2022/01/25/semihosting-with-nxp-mcuxpresso-sdk-and-frdm-ke02z/
I hope this helps,
Erich
2,880 次查看
ErichStyger
Specialist I
I hope this helps,
Erich
