"Error in final launch sequence" when using debug on hello world app for first time - k64f
1,591 次查看
jamieghoorbin
I followed the instruction videos to install the NXP software, IDE and drivers. When i ran the hello world app in debug mode, i got an error message "Error in final launch sequence" and the details of the error was as follows:
Error: Read timed out
LinkServer has been terminated and will be restarted.
Please restart your debug session.
If the problem recurs, please power cycle your debug probe and restart MCUXpresso IDE.
I've only just purchased this and would appreciate a solution. Thanks
标记 (2)
1,171 次查看
ZhangJennie
Hi Jamie,
There are many possible reasons for this error.
I would suggest you test:
1. To avoid old connection associations, create a NEW project in a NEW workspace. Test if this new project can connect normal then.
2. check in windows task if there is any live connection still pending, if yes, kill it first.
3. If both 1 and 2 can not fix the problem, please try another connection with of the board. If you use FRDM-K64 board, change other interface. Here is the link for available OpenSDA:
https://www.nxp.com/support/developer-resources/run-time-software/kinetis-developer-resources/ides-f...
Jennie Zhang
