mem_extend function not work in MQX 4.2
1,831 次查看
davidzhu
I am a MQX user, I am using K66 and MQX 4.2.   I need to extend my external SDRAM to MQX pool with mem_extend, but  it is not successful,. Could you please give me a clue how to this correctly?
Thank you.
1,815 次查看
danielchen
Hi David:
If your application runs out of RAM and you want to create new tasks you need external RAM. In this case _mem_extend function is used to let the kernel know about external mem pool.
 you need to use these MACROs in user_config.h
 #define MQX_USE_LWMEM_ALLOCATOR 0
 #define MQX_USE_LWMEM 0
 #define MQX_USE_MEM 1
Please rebuild all libraries.
1,816 次查看
danielchen
Hi David:
