error build hello_world first project
859 次查看
nik_45935
I am new to NXP ide. I downloaded the IDE and installed the SDK for my board. While building the simplest sdk project "hello_world" the following errors occur:
make -r -j7 all
Building file: ../utilities/str/fsl_str.c
Building file: ../utilities/debug_console/fsl_debug_console.c
Building file: ../utilities/fsl_assert.c
Building file: ../startup/boot_multicore_slave.c
Invoking: MCU C Compiler
arm-none-eabi-gcc -D__REDLIB__ -DCPU_MCXN947VDF -DCPU_MCXN947VDF_cm33 -DCPU_MCXN947VDF_cm33_core0 -DSDK_OS_BAREMETAL -DSERIAL_PORT_TYPE_UART=1 -DSDK_DEBUGCONSOLE=0 -DCR_INTEGER_PRINTF -DPRINTF_FLOAT_ENABLE=0 -DSDK_DEBUGCONSOLE_UART -D__MCUXPRESSO -D__USE_CMSIS -DDEBUG -I"/Users/macbookpro13_nik/mcuxpresso/MCXN947_Project_2/board" -I"/Users/macbookpro13_nik/mcuxpresso/MCXN947_Project_2/source" -I"/Users/macbookpro13_nik/mcuxpresso/MCXN947_Project_2/drivers" -I"/Users/macbookpro13_nik/mcuxpresso/MCXN947_Project_2/device" -I"/Users/macbookpro13_nik/mcuxpresso/MCXN947_Project_2/utilities/debug_console" -I"/Users/macbookpro13_nik/mcuxpresso/MCXN947_Project_2/component/uart" -I"/Users/macbookpro13_nik/mcuxpresso/MCXN947_Project_2/utilities/debug_console/config" -I"/Users/macbookpro13_nik/mcuxpresso/MCXN947_Project_2/component/serial_manager" -I"/Users/macbookpro13_nik/mcuxpresso/MCXN947_Project_2/component/lists" -I"/Users/macbookpro13_nik/mcuxpresso/MCXN947_Project_2/device/periph" -I"/Users/macbookpro13_nik/mcuxpresso/MCXN947_Project_2/utilities" -I"/Users/macbookpro13_nik/mcuxpresso/MCXN947_Project_2/CMSIS" -I"/Users/macbookpro13_nik/mcuxpresso/MCXN947_Project_2/CMSIS/m-profile" -I"/Users/macbookpro13_nik/mcuxpresso/MCXN947_Project_2/utilities/str" -O0 -fno-common -g3 -gdwarf-4 -Wall -c -ffunction-sections -fdata-sections -fno-builtin -fmerge-constants -fmacro-prefix-map="../utilities/str/"= -mcpu=cortex-m33 -mfpu=fpv5-sp-d16 -mfloat-abi=hard -mthumb -D__REDLIB__ -fstack-usage -specs=redlib.specs -MMD -MP -MF"utilities/str/fsl_str.d" -MT"utilities/str/fsl_str.o" -MT"utilities/str/fsl_str.d" -o "utilities/str/fsl_str.o" "../utilities/str/fsl_str.c"
Building file: ../startup/startup_mcxn947_cm33_core0.c
arm-none-eabi-gcc -D__REDLIB__ -DCPU_MCXN947VDF -DCPU_MCXN947VDF_cm33 -DCPU_MCXN947VDF_cm33_core0 -DSDK_OS_BAREMETAL -DSERIAL_PORT_TYPE_UART=1 -DSDK_DEBUGCONSOLE=0 -DCR_INTEGER_PRINTF -DPRINTF_FLOAT_ENABLE=0 -DSDK_DEBUGCONSOLE_UART -D__MCUXPRESSO -D__USE_CMSIS -DDEBUG -I"/Users/macbookpro13_nik/mcuxpresso/MCXN947_Project_2/board" -I"/Users/macbookpro13_nik/mcuxpresso/MCXN947_Project_2/source" -I"/Users/macbookpro13_nik/mcuxpresso/MCXN947_Project_2/drivers" -I"/Users/macbookpro13_nik/mcuxpresso/MCXN947_Project_2/device" -I"/Users/macbookpro13_nik/mcuxpresso/MCXN947_Project_2/utilities/debug_console" -I"/Users/macbookpro13_nik/mcuxpresso/MCXN947_Project_2/component/uart" -I"/Users/macbookpro13_nik/mcuxpresso/MCXN947_Project_2/utilities/debug_console/config" -I"/Users/macbookpro13_nik/mcuxpresso/MCXN947_Project_2/component/serial_manager" -I"/Users/macbookpro13_nik/mcuxpresso/MCXN947_Project_2/component/lists" -I"/Users/macbookpro13_nik/mcuxpresso/MCXN947_Project_2/device/periph" -I"/Users/macbookpro13_nik/mcuxpresso/MCXN947_Project_2/utilities" -I"/Users/macbookpro13_nik/mcuxpresso/MCXN947_Project_2/CMSIS" -I"/Users/macbookpro13_nik/mcuxpresso/MCXN947_Project_2/CMSIS/m-profile" -I"/Users/macbookpro13_nik/mcuxpresso/MCXN947_Project_2/utilities/str" -O0 -fno-common -g3 -gdwarf-4 -Wall -c -ffunction-sections -fdata-sections -fno-builtin -fmerge-constants -fmacro-prefix-map="../utilities/debug_console/"= -mcpu=cortex-m33 -mfpu=fpv5-sp-d16 -mfloat-abi=hard -mthumb -D__REDLIB__ -fstack-usage -specs=redlib.specs -MMD -MP -MF"utilities/debug_console/fsl_debug_console.d" -MT"utilities/debug_console/fsl_debug_console.o" -MT"utilities/debug_console/fsl_debug_console.d" -o "utilities/debug_console/fsl_debug_console.o" "../utilities/debug_console/fsl_debug_console.c"
arm-none-eabi-gcc -D__REDLIB__ -DCPU_MCXN947VDF -DCPU_MCXN947VDF_cm33 -DCPU_MCXN947VDF_cm33_core0 -DSDK_OS_BAREMETAL -DSERIAL_PORT_TYPE_UART=1 -DSDK_DEBUGCONSOLE=0 -DCR_INTEGER_PRINTF -DPRINTF_FLOAT_ENABLE=0 -DSDK_DEBUGCONSOLE_UART -D__MCUXPRESSO -D__USE_CMSIS -DDEBUG -I"/Users/macbookpro13_nik/mcuxpresso/MCXN947_Project_2/board" -I"/Users/macbookpro13_nik/mcuxpresso/MCXN947_Project_2/source" -I"/Users/macbookpro13_nik/mcuxpresso/MCXN947_Project_2/drivers" -I"/Users/macbookpro13_nik/mcuxpresso/MCXN947_Project_2/device" -I"/Users/macbookpro13_nik/mcuxpresso/MCXN947_Project_2/utilities/debug_console" -I"/Users/macbookpro13_nik/mcuxpresso/MCXN947_Project_2/component/uart" -I"/Users/macbookpro13_nik/mcuxpresso/MCXN947_Project_2/utilities/debug_console/config" -I"/Users/macbookpro13_nik/mcuxpresso/MCXN947_Project_2/component/serial_manager" -I"/Users/macbookpro13_nik/mcuxpresso/MCXN947_Project_2/component/lists" -I"/Users/macbookpro13_nik/mcuxpresso/MCXN947_Project_2/device/periph" -I"/Users/macbookpro13_nik/mcuxpresso/MCXN947_Project_2/utilities" -I"/Users/macbookpro13_nik/mcuxpresso/MCXN947_Project_2/CMSIS" -I"/Users/macbookpro13_nik/mcuxpresso/MCXN947_Project_2/CMSIS/m-profile" -I"/Users/macbookpro13_nik/mcuxpresso/MCXN947_Project_2/utilities/str" -O0 -fno-common -g3 -gdwarf-4 -Wall -c -ffunction-sections -fdata-sections -fno-builtin -fmerge-constants -fmacro-prefix-map="../startup/"= -mcpu=cortex-m33 -mfpu=fpv5-sp-d16 -mfloat-abi=hard -mthumb -D__REDLIB__ -fstack-usage -specs=redlib.specs -MMD -MP -MF"startup/boot_multicore_slave.d" -MT"startup/boot_multicore_slave.o" -MT"startup/boot_multicore_slave.d" -o "startup/boot_multicore_slave.o" "../startup/boot_multicore_slave.c"
arm-none-eabi-gcc -D__REDLIB__ -DCPU_MCXN947VDF -DCPU_MCXN947VDF_cm33 -DCPU_MCXN947VDF_cm33_core0 -DSDK_OS_BAREMETAL -DSERIAL_PORT_TYPE_UART=1 -DSDK_DEBUGCONSOLE=0 -DCR_INTEGER_PRINTF -DPRINTF_FLOAT_ENABLE=0 -DSDK_DEBUGCONSOLE_UART -D__MCUXPRESSO -D__USE_CMSIS -DDEBUG -I"/Users/macbookpro13_nik/mcuxpresso/MCXN947_Project_2/board" -I"/Users/macbookpro13_nik/mcuxpresso/MCXN947_Project_2/source" -I"/Users/macbookpro13_nik/mcuxpresso/MCXN947_Project_2/drivers" -I"/Users/macbookpro13_nik/mcuxpresso/MCXN947_Project_2/device" -I"/Users/macbookpro13_nik/mcuxpresso/MCXN947_Project_2/utilities/debug_console" -I"/Users/macbookpro13_nik/mcuxpresso/MCXN947_Project_2/component/uart" -I"/Users/macbookpro13_nik/mcuxpresso/MCXN947_Project_2/utilities/debug_console/config" -I"/Users/macbookpro13_nik/mcuxpresso/MCXN947_Project_2/component/serial_manager" -I"/Users/macbookpro13_nik/mcuxpresso/MCXN947_Project_2/component/lists" -I"/Users/macbookpro13_nik/mcuxpresso/MCXN947_Project_2/device/periph" -I"/Users/macbookpro13_nik/mcuxpresso/MCXN947_Project_2/utilities" -I"/Users/macbookpro13_nik/mcuxpresso/MCXN947_Project_2/CMSIS" -I"/Users/macbookpro13_nik/mcuxpresso/MCXN947_Project_2/CMSIS/m-profile" -I"/Users/macbookpro13_nik/mcuxpresso/MCXN947_Project_2/utilities/str" -O0 -fno-common -g3 -gdwarf-4 -Wall -c -ffunction-sections -fdata-sections -fno-builtin -fmerge-constants -fmacro-prefix-map="../startup/"= -mcpu=cortex-m33 -mfpu=fpv5-sp-d16 -mfloat-abi=hard -mthumb -D__REDLIB__ -fstack-usage -specs=redlib.specs -MMD -MP -MF"startup/startup_mcxn947_cm33_core0.d" -MT"startup/startup_mcxn947_cm33_core0.o" -MT"startup/startup_mcxn947_cm33_core0.d" -o "startup/startup_mcxn947_cm33_core0.o" "../startup/startup_mcxn947_cm33_core0.c"
Building file: ../source/MCXN947_Project_2.c
arm-none-eabi-gcc -D__REDLIB__ -DCPU_MCXN947VDF -DCPU_MCXN947VDF_cm33 -DCPU_MCXN947VDF_cm33_core0 -DSDK_OS_BAREMETAL -DSERIAL_PORT_TYPE_UART=1 -DSDK_DEBUGCONSOLE=0 -DCR_INTEGER_PRINTF -DPRINTF_FLOAT_ENABLE=0 -DSDK_DEBUGCONSOLE_UART -D__MCUXPRESSO -D__USE_CMSIS -DDEBUG -I"/Users/macbookpro13_nik/mcuxpresso/MCXN947_Project_2/board" -I"/Users/macbookpro13_nik/mcuxpresso/MCXN947_Project_2/source" -I"/Users/macbookpro13_nik/mcuxpresso/MCXN947_Project_2/drivers" -I"/Users/macbookpro13_nik/mcuxpresso/MCXN947_Project_2/device" -I"/Users/macbookpro13_nik/mcuxpresso/MCXN947_Project_2/utilities/debug_console" -I"/Users/macbookpro13_nik/mcuxpresso/MCXN947_Project_2/component/uart" -I"/Users/macbookpro13_nik/mcuxpresso/MCXN947_Project_2/utilities/debug_console/config" -I"/Users/macbookpro13_nik/mcuxpresso/MCXN947_Project_2/component/serial_manager" -I"/Users/macbookpro13_nik/mcuxpresso/MCXN947_Project_2/component/lists" -I"/Users/macbookpro13_nik/mcuxpresso/MCXN947_Project_2/device/periph" -I"/Users/macbookpro13_nik/mcuxpresso/MCXN947_Project_2/utilities" -I"/Users/macbookpro13_nik/mcuxpresso/MCXN947_Project_2/CMSIS" -I"/Users/macbookpro13_nik/mcuxpresso/MCXN947_Project_2/CMSIS/m-profile" -I"/Users/macbookpro13_nik/mcuxpresso/MCXN947_Project_2/utilities/str" -O0 -fno-common -g3 -gdwarf-4 -Wall -c -ffunction-sections -fdata-sections -fno-builtin -fmerge-constants -fmacro-prefix-map="../utilities/"= -mcpu=cortex-m33 -mfpu=fpv5-sp-d16 -mfloat-abi=hard -mthumb -D__REDLIB__ -fstack-usage -specs=redlib.specs -MMD -MP -MF"utilities/fsl_assert.d" -MT"utilities/fsl_assert.o" -MT"utilities/fsl_assert.d" -o "utilities/fsl_assert.o" "../utilities/fsl_assert.c"
Building file: ../source/semihost_hardfault.c
arm-none-eabi-gcc -D__REDLIB__ -DCPU_MCXN947VDF -DCPU_MCXN947VDF_cm33 -DCPU_MCXN947VDF_cm33_core0 -DSDK_OS_BAREMETAL -DSERIAL_PORT_TYPE_UART=1 -DSDK_DEBUGCONSOLE=0 -DCR_INTEGER_PRINTF -DPRINTF_FLOAT_ENABLE=0 -DSDK_DEBUGCONSOLE_UART -D__MCUXPRESSO -D__USE_CMSIS -DDEBUG -I"/Users/macbookpro13_nik/mcuxpresso/MCXN947_Project_2/board" -I"/Users/macbookpro13_nik/mcuxpresso/MCXN947_Project_2/source" -I"/Users/macbookpro13_nik/mcuxpresso/MCXN947_Project_2/drivers" -I"/Users/macbookpro13_nik/mcuxpresso/MCXN947_Project_2/device" -I"/Users/macbookpro13_nik/mcuxpresso/MCXN947_Project_2/utilities/debug_console" -I"/Users/macbookpro13_nik/mcuxpresso/MCXN947_Project_2/component/uart" -I"/Users/macbookpro13_nik/mcuxpresso/MCXN947_Project_2/utilities/debug_console/config" -I"/Users/macbookpro13_nik/mcuxpresso/MCXN947_Project_2/component/serial_manager" -I"/Users/macbookpro13_nik/mcuxpresso/MCXN947_Project_2/component/lists" -I"/Users/macbookpro13_nik/mcuxpresso/MCXN947_Project_2/device/periph" -I"/Users/macbookpro13_nik/mcuxpresso/MCXN947_Project_2/utilities" -I"/Users/macbookpro13_nik/mcuxpresso/MCXN947_Project_2/CMSIS" -I"/Users/macbookpro13_nik/mcuxpresso/MCXN947_Project_2/CMSIS/m-profile" -I"/Users/macbookpro13_nik/mcuxpresso/MCXN947_Project_2/utilities/str" -O0 -fno-common -g3 -gdwarf-4 -Wall -c -ffunction-sections -fdata-sections -fno-builtin -fmerge-constants -fmacro-prefix-map="../source/"= -mcpu=cortex-m33 -mfpu=fpv5-sp-d16 -mfloat-abi=hard -mthumb -D__REDLIB__ -fstack-usage -specs=redlib.specs -MMD -MP -MF"source/MCXN947_Project_2.d" -MT"source/MCXN947_Project_2.o" -MT"source/MCXN947_Project_2.d" -o "source/MCXN947_Project_2.o" "../source/MCXN947_Project_2.c"
arm-none-eabi-gcc -D__REDLIB__ -DCPU_MCXN947VDF -DCPU_MCXN947VDF_cm33 -DCPU_MCXN947VDF_cm33_core0 -DSDK_OS_BAREMETAL -DSERIAL_PORT_TYPE_UART=1 -DSDK_DEBUGCONSOLE=0 -DCR_INTEGER_PRINTF -DPRINTF_FLOAT_ENABLE=0 -DSDK_DEBUGCONSOLE_UART -D__MCUXPRESSO -D__USE_CMSIS -DDEBUG -I"/Users/macbookpro13_nik/mcuxpresso/MCXN947_Project_2/board" -I"/Users/macbookpro13_nik/mcuxpresso/MCXN947_Project_2/source" -I"/Users/macbookpro13_nik/mcuxpresso/MCXN947_Project_2/drivers" -I"/Users/macbookpro13_nik/mcuxpresso/MCXN947_Project_2/device" -I"/Users/macbookpro13_nik/mcuxpresso/MCXN947_Project_2/utilities/debug_console" -I"/Users/macbookpro13_nik/mcuxpresso/MCXN947_Project_2/component/uart" -I"/Users/macbookpro13_nik/mcuxpresso/MCXN947_Project_2/utilities/debug_console/config" -I"/Users/macbookpro13_nik/mcuxpresso/MCXN947_Project_2/component/serial_manager" -I"/Users/macbookpro13_nik/mcuxpresso/MCXN947_Project_2/component/lists" -I"/Users/macbookpro13_nik/mcuxpresso/MCXN947_Project_2/device/periph" -I"/Users/macbookpro13_nik/mcuxpresso/MCXN947_Project_2/utilities" -I"/Users/macbookpro13_nik/mcuxpresso/MCXN947_Project_2/CMSIS" -I"/Users/macbookpro13_nik/mcuxpresso/MCXN947_Project_2/CMSIS/m-profile" -I"/Users/macbookpro13_nik/mcuxpresso/MCXN947_Project_2/utilities/str" -O0 -fno-common -g3 -gdwarf-4 -Wall -c -ffunction-sections -fdata-sections -fno-builtin -fmerge-constants -fmacro-prefix-map="../source/"= -mcpu=cortex-m33 -mfpu=fpv5-sp-d16 -mfloat-abi=hard -mthumb -D__REDLIB__ -fstack-usage -specs=redlib.specs -MMD -MP -MF"source/semihost_hardfault.d" -MT"source/semihost_hardfault.o" -MT"source/semihost_hardfault.d" -o "source/semihost_hardfault.o" "../source/semihost_hardfault.c"
dyld[31585]: Library not loaded: /usr/local/opt/zstd/lib/libzstd.1.dylib
Referenced from: <66B02E5C-65B3-3C28-8492-4979A8E596B8> /Applications/MCUXpressoIDE_25.6.136/ide/plugins/com.nxp.mcuxpresso.tools.macosx_25.6.0.202501151204/tools/libexec/gcc/arm-none-eabi/14.2.1/cc1
Reason: tried: '/usr/local/opt/zstd/lib/libzstd.1.dylib' (no such file), '/System/Volumes/Preboot/Cryptexes/OS/usr/local/opt/zstd/lib/libzstd.1.dylib' (no such file), '/usr/local/opt/zstd/lib/libzstd.1.dylib' (no such file), '/usr/lib/libzstd.1.dylib' (no such file, not in dyld cache)
arm-none-eabi-gcc: internal compiler error: Abort trap: 6 signal terminated program cc1
Please submit a full bug report, with preprocessed source (by using -freport-bug).
See <https://bugs.linaro.org/> for instructions.
make[1]: *** [utilities/str/subdir.mk:20: utilities/str/fsl_str.o] Error 4
make[1]: *** Waiting for unfinished jobs....
dyld[31587]: Library not loaded: /usr/local/opt/zstd/lib/libzstd.1.dylib
make[1]: *** [startup/subdir.mk:23: startup/boot_multicore_slave.o] Error 4
dyld[31588]: Library not loaded: /usr/local/opt/zstd/lib/libzstd.1.dylib
make[1]: *** [utilities/debug_console/subdir.mk:20: utilities/debug_console/fsl_debug_console.o] Error 4
dyld[31589]: Library not loaded: /usr/local/opt/zstd/lib/libzstd.1.dylib
make[1]: *** [startup/subdir.mk:23: startup/startup_mcxn947_cm33_core0.o] Error 4
dyld[31590]: Library not loaded: /usr/local/opt/zstd/lib/libzstd.1.dylib
make[1]: *** [utilities/subdir.mk:20: utilities/fsl_assert.o] Error 4
dyld[31591]: Library not loaded: /usr/local/opt/zstd/lib/libzstd.1.dylib
make[1]: *** [source/subdir.mk:23: source/MCXN947_Project_2.o] Error 4
dyld[31592]: Library not loaded: /usr/local/opt/zstd/lib/libzstd.1.dylib
make[1]: *** [source/subdir.mk:23: source/semihost_hardfault.o] Error 4
make: *** [makefile:45: all] Error 2
"make -r -j7 all" terminated with exit code 2. Build might be incomplete.
12:21:43 Build Failed. 9 errors, 0 warnings. (took 386ms)
How can I fix them ? I am using MacOS
804 次查看
Hello @nik_45935
Please download the MCUXpresso IDE from:  https://www.nxp.com/design/design-center/software/development-software/mcuxpresso-software-and-tools...
Then download the SDK for the FRDM-MCXN947 from:  https://mcuxpresso.nxp.com/
After that, refer to the MCUXpresso IDE User Guide to import the SDK example and build it.
Hope this helps. If you still have any issues, please feel free to contact me.
Thank you.
Alice
%3CLINGO-SUB%20id%3D%22lingo-sub-2304248%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E7%89%88%E6%9C%AC%20hello_world%20%E7%AC%AC%E4%B8%80%E4%B8%AA%E9%A1%B9%E7%9B%AE%E6%97%B6%E5%87%BA%E9%94%99%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2304248%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%88%91%E6%98%AF%E6%81%A9%E6%99%BA%E6%B5%A6%20ide%20%E7%9A%84%E6%96%B0%E6%88%90%E5%91%98%E3%80%82%E6%88%91%E4%B8%8B%E8%BD%BD%E4%BA%86%20IDE%20%E5%B9%B6%E4%B8%BA%E6%88%91%E7%9A%84%E6%9D%BF%E5%AE%89%E8%A3%85%E4%BA%86%20SDK%E3%80%82%E5%9C%A8%E6%9E%84%E5%BB%BA%E6%9C%80%E7%AE%80%E5%8D%95%E7%9A%84%20sdk%20%E9%A1%B9%E7%9B%AE%22hello_world%22%20%E6%97%B6%EF%BC%8C%E5%87%BA%E7%8E%B0%E4%BB%A5%E4%B8%8B%E9%94%99%E8%AF%AF%EF%BC%9A%3C%2FP%3E%3CDIV%3E%3CDIV%3E%3CP%3E%3CSPAN%3Emake%20-r%20-j7%20all%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E6%9E%84%E5%BB%BA%E6%96%87%E4%BB%B6%EF%BC%9A%20...%2Futilities%2Fstr%2Ffsl_str.c%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E6%9E%84%E5%BB%BA%E6%96%87%E4%BB%B6%EF%BC%9A..%2Futilities%2Fdebug_console%2Ffsl_debug_console.c%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E6%9E%84%E5%BB%BA%E6%96%87%E4%BB%B6%EF%BC%9A..%2Futilities%2Ffsl_assert.c%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E6%9E%84%E5%BB%BA%E6%96%87%E4%BB%B6%EF%BC%9A..%2Fstartup%2Fboot_multicore_slave.c%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E8%B0%83%E7%94%A8%EF%BC%9AMCU%20C%20%E7%BC%96%E8%AF%91%E5%99%A8%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3Earm-none-eabi-gcc-D%20__REDLIB__-DCPU_MCXN947VDF-dcpu_mcxn947vdf_cm33-dcpu_mcxn947vdf_cm33_cm33_core0-DSDK_OS_BAREMETAL-DSERIAL_PORT_TYPE_UART%3D1-DSDK_DEBUGCONSOLE%3D0-DCR_INTEGER_PRINTF%20DPRINTF_FLOAT_ENABLE%3D0-DSDK_DEBUGCONSOLE_UART-D%20__MCUXPRESSO%20-D__%20USE_CMSIS-DDEBUG-I%20%22%20%2FUsers%2Fmcbookpro13_nik%2Fmccuxpresso%2Fmcxn947_project_2%2FBoard%20%22-I%20%22%20%2Fusers%2Fmcbookpro13_project_2%2FBoard-I%20%2Fmcbookpro13_nik%2Fmcuxpresso%2Fproject_2%2FSource%22-I%20%22%20%2FUsers%2Fmcbookpro13_nik%2Fmcuxpresso%2Fmcxn947_project_2%2FDrivers%20%22-I%20%22%20%2FUsers%2Fmcbookpro13_nik%2Fmcuxpresso%2Fmcxn947_project_nik%2Fmcbookpro13_project_2%2FUtilities%2Fdebug_project_2%2FDevice%20%22-I%20%22%20%2Fusers%2Fmcbookpro13_project_2%2FUtilities%2Fdebug_g_project_2%2FUtilities%2FDEBUG_GConsole%20%22-I%20%22%20%2FUsers%2Fmacbookpro13_nik%2Fmcuxpresso%2Fmcxn947_project_2%2Fcomponent%2Fuart%20%22-I%20%22%20%2FUsers%2Fmacbookpro13_nik%2Fmcuxpresso%2Fmcxn947_project_2%2FUtilities%2FDEBUG_Config%20%22-I%20%22%20%2FUsers%2Fmacbookpro13_nik%2Fmcuxpresso%2Fmcuxpresso%2Fproject_2%2Fcomponent%2Fserial_mcubro13_nik%2Fmcuxpresso%2Fproject_mcuxpresso13_project_2%2F%E5%85%83%E5%99%A8%E4%BB%B6%2FSerial_Macbookpro13_nik%2Fmcuxpresso%2Fmcxn947_project_2%2F%E5%85%83%E5%99%A8%E4%BB%B6%2FLists%20%22-I%20%22%20%2FUsers%2Fmacbookpro13_nik%2F%20%22%20%22mcuxpresso%2Fmcxn947_project_2%2Fdevice%2FPeriph%20%22-I%20%22%20%2FUsers%2Fmcbookpro13_nik%2Fmcuxpresso%2Fmcxn947_project_2%2FUtilities%20%22-I%20%22%20%2FUsers%2Fmcbookpro13_nik%2Fmcbookpro13_nik%2Fmcbookpro13_nik%2Fmcbookpro13_nik%2Fmcuxpro13_nik%2Fmcuxpro13_nik%2Fmcuxpro13_nik%2Fmcuxpro13_nik%2Fmcuxpro13_nik%2Fcuxpresso%2Fmcxn947_project_2%2Fcmsis%2FM-Profile%20%22-I%20%2029%2FUsers%2Fmacbookpro13_nik%2Fmcuxpresso%2Fmcxn947_project_2%2FUtilities%2Fstr%20%22-O0-fno-common-gdwarf-4-Wall-c-function-sections-functionso%2Ffno-builtine-fmacro-prefix-map%3D%20%22...%2Futilities%2Fstr%2F%20%22%20%3D-mcpu%3Dcortex-m33-mfpu%3Dfpv5-sp-d16-mfloat-abi%3Dhard-mthumb-D%20__REDLIB__-fstack-usage-specs%3Dredlib.specs-mmd-MP%20%22%20%E5%AE%9E%E7%94%A8%E7%A8%8B%E5%BA%8F%2Fstr%2Ffsl_str.d%20%22-MT%22utilities%2Fstr%2Ffsl_str.o%22-MT%22utilities%2Fstr%2Ffsl_str.d%22-o%22utilities%2Fstr%2Ffsl_str.o%22%22..%2Futilities%2Fstr%2Ffsl_str.c%22%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E6%9E%84%E5%BB%BA%E6%96%87%E4%BB%B6%EF%BC%9A...%2Fstartup%2Fstartup_mcxn947_cm33_core0.c%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E8%B0%83%E7%94%A8%EF%BC%9AMCU%20C%20%E7%BC%96%E8%AF%91%E5%99%A8%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EArm-none-eabi-gcc-D%20__REDLIB__-DCPU_MCXN947VDF-dcpu_mcxn947vdf_cm33-dcpu_mcxn947vdf_cm33_cm33_core0-DSDK_OS_BAREMETAL-DSERIAL_PORT_TYPE_UART%3D1-DSDK_DEBUGCONSOLE%3D0-DCR_INTEGER_PRINTF%20DPRINTF_FLOAT_ENABLE%3D0-DSDK_DEBUGCONSOLE_UART-D%20__MCUXPRESSO%20-D__%20USE_CMSIS-DDEBUG-I%20%22%20%2FUsers%2Fmcbookpro13_nik%2Fmccuxpresso%2Fmcxn947_project_2%2F%E6%9D%BF%20%22-I%20%22%20%2Fusers%2Fmcbookpro13_project_2%2F%E6%9D%BF-I%20%2Fmcbookpro13_nik%2Fmcuxpresso%2Fproject_2%2FSource%22-I%20%22%20%2FUsers%2Fmcbookpro13_nik%2Fmcuxpresso%2Fmcxn947_project_2%2FDrivers%20%22-I%20%22%20%2FUsers%2Fmcbookpro13_nik%2Fmcuxpresso%2Fmcxn947_project_nik%2Fmcbookpro13_project_2%2FUtilities%2Fdebug_project_2%2F%E8%AE%BE%E5%A4%87%20%22-I%20%22%20%2Fusers%2Fmcbookpro13_project_2%2FUtilities%2Fdebug_g_project_2%2FUtilities%2FDEBUG_GConsole%20%22-I%20%22%20%2FUsers%2Fmacbookpro13_nik%2Fmcuxpresso%2Fmcxn947_project_2%2F%E5%85%83%E5%99%A8%E4%BB%B6%2Fuart%20%22-I%20%22%20%2FUsers%2Fmacbookpro13_nik%2Fmcuxpresso%2Fmcxn947_project_2%2FUtilities%2FDEBUG_Config%20%22-I%20%22%20%2FUsers%2Fmacbookpro13_nik%2Fmcuxpresso%2Fmcuxpresso%2Fproject_2%2F%E5%85%83%E5%99%A8%E4%BB%B6%2Fserial_mcubro13_nik%2Fmcuxpresso%2Fproject_mcuxpresso13_project_2%2F%E5%85%83%E5%99%A8%E4%BB%B6%2FSerial_Macbookpro13_nik%2Fmcuxpresso%2Fmcxn947_project_2%2F%E5%85%83%E5%99%A8%E4%BB%B6%2FLists%20%22-I%20%22%20%2FUsers%2Fmacbookpro13_nik%2F%20%22%20%22mcuxpresso%2Fmcxn947_project_2%2F%E8%AE%BE%E5%A4%87%2FPeriph%20%22-I%20%22%20%2FUsers%2Fmcbookpro13_nik%2Fmcuxpresso%2Fmcxn947_project_2%2FUtilities%20%22-I%20%22%20%2FUsers%2Fmcbookpro13_nik%2Fmcbookpro13_nik%2Fmcbookpro13_nik%2Fmcbookpro13_nik%2Fmcuxpro13_nik%2Fmcuxpro13_nik%2Fmcuxpro13_nik%2Fmcuxpro13_nik%2Fmcuxpro13_nik%2Fcuxpresso%2Fmcxn947_project_2%2Fcmsis%2FM-Profile%20%22-I%20%2029%2Fusers%2Fmacbookpro13_nik%2Fmcuxpresso%2Fmcxn947_project_2%2FUtilities%2Fstr%20%22-O0-fno-common-gdwarf-4-Wall-c-function-sections-functionso%2Ffno-builtine-fmacro-prefix-map%3D%20%22...%2Futilities%2Fdebug_console%2F%20%22%20%3D-mcpu%3Dcortex-m33-mfpu%3Dfpv5-sp-d16-mfloat-abi%3Dhard-mthumb-D%20__REDLIB__-fstack-usage-specs%3Dredib.specs-mmd-MP%20%22%20%E5%AE%9E%E7%94%A8%E7%A8%8B%E5%BA%8F%2F%E8%B0%83%E8%AF%95%E6%8E%A7%E5%88%B6%E5%8F%B0%2Ffsl_debug_console.d%20%22-MT%22utilities%2Fdebug_console%2Ffsl_debug_console.o%22-MT%22utilities%2Fdebug_console%2Ffsl_debug_console.d%22-o%22utilities%2Fdebug_console%2Ffsl_debug_console.o%22%22..%2Futilities%2Fdebug_console%2Ffsl_debug_console.c%22%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E8%B0%83%E7%94%A8%EF%BC%9AMCU%20C%20%E7%BC%96%E8%AF%91%E5%99%A8%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3Earm-none-eabi-gcc-D%20__REDLIB__-DCPU_MCXN947VDF-dcpu_mcxn947vdf_cm33-dcpu_mcxn947vdf_cm33_cm33_core0-DSDK_OS_BAREMETAL-DSERIAL_PORT_TYPE_UART%3D1-DSDK_DEBUGCONSOLE%3D0-DCR_INTEGER_PRINTF%20DPRINTF_FLOAT_ENABLE%3D0-DSDK_DEBUGCONSOLE_UART-D%20__MCUXPRESSO%20-D__%20USE_CMSIS-DDEBUG-I%20%22%20%2FUsers%2Fmcbookpro13_nik%2Fmccuxpresso%2Fmcxn947_project_2%2F%E6%9D%BF%20%22-I%20%22%20%2Fusers%2Fmcbookpro13_project_2%2F%E6%9D%BF-I%20%2Fmcbookpro13_nik%2Fmcuxpresso%2Fproject_2%2FSource%22-I%20%22%20%2FUsers%2Fmcbookpro13_nik%2Fmcuxpresso%2Fmcxn947_project_2%2FDrivers%20%22-I%20%22%20%2FUsers%2Fmcbookpro13_nik%2Fmcuxpresso%2Fmcxn947_project_nik%2Fmcbookpro13_project_2%2FUtilities%2Fdebug_project_2%2F%E8%AE%BE%E5%A4%87%20%22-I%20%22%20%2Fusers%2Fmcbookpro13_project_2%2FUtilities%2Fdebug_g_project_2%2FUtilities%2FDEBUG_GConsole%20%22-I%20%22%20%2FUsers%2Fmacbookpro13_nik%2Fmcuxpresso%2Fmcxn947_project_2%2F%E5%85%83%E5%99%A8%E4%BB%B6%2Fuart%20%22-I%20%22%20%2FUsers%2Fmacbookpro13_nik%2Fmcuxpresso%2Fmcxn947_project_2%2FUtilities%2FDEBUG_Config%20%22-I%20%22%20%2FUsers%2Fmacbookpro13_nik%2Fmcuxpresso%2Fmcuxpresso%2Fproject_2%2F%E5%85%83%E5%99%A8%E4%BB%B6%2Fserial_mcubro13_nik%2Fmcuxpresso%2Fproject_mcuxpresso13_project_2%2F%E5%85%83%E5%99%A8%E4%BB%B6%2FSerial_Macbookpro13_nik%2Fmcuxpresso%2Fmcxn947_project_2%2F%E5%85%83%E5%99%A8%E4%BB%B6%2FLists%20%22-I%20%22%20%2FUsers%2Fmacbookpro13_nik%2F%20%22%20%22mcuxpresso%2Fmcxn947_project_2%2F%E8%AE%BE%E5%A4%87%2FPeriph%20%22-I%20%22%20%2FUsers%2Fmcbookpro13_nik%2Fmcuxpresso%2Fmcxn947_project_2%2FUtilities%20%22-I%20%22%20%2FUsers%2Fmcbookpro13_nik%2Fmcbookpro13_nik%2Fmcbookpro13_nik%2Fmcbookpro13_nik%2Fmcuxpro13_nik%2Fmcuxpro13_nik%2Fmcuxpro13_nik%2Fmcuxpro13_nik%2Fmcuxpro13_nik%2Fcuxpresso%2Fmcxn947_project_2%2Fcmsis%2FM-Profile%20%22-I%20%2029%2FUsers%2Fmacbookpro13_nik%2Fmcuxpresso%2Fmcxn947_project_2%2FUtilities%2Fstr%20%22-O0-fno-common-gdwarf-4-Wall-c-function-sections-functionso%2Ffno-builtine-fmacro-prefix-map%3D%20%22...%2Fstartup%2F%20%22%20%3D-mcpu%3Dcortex-m33-mfpu%3Dfpv5-sp-d16-mfloat-abi%3Dhard-mthumb-D%20__REDLIB__-fstack-usage-specs%3Dredlib.specs-MMD-MP-MF%20%22%20startup%2Fboot_multicore_slave.d%20%22-MT%22startup%2Fboot_multicore_slave.o%22-MT%22startup%2Fboot_multicore_slave.d%22-o%22startup%2Fboot_multicore_slave.o%22%22..%2Fstartup%2Fboot_multicore_slave.c%22%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E8%B0%83%E7%94%A8%EF%BC%9AMCU%20C%20%E7%BC%96%E8%AF%91%E5%99%A8%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3Earm-none-eabi-gcc-D%20__REDLIB__-DCPU_MCXN947VDF-dcpu_mcxn947vdf_cm33-dcpu_mcxn947vdf_cm33_cm33_core0-DSDK_OS_BAREMETAL-DSERIAL_PORT_TYPE_UART%3D1-DSDK_DEBUGCONSOLE%3D0-DCR_INTEGER_PRINTF%20DPRINTF_FLOAT_ENABLE%3D0-DSDK_DEBUGCONSOLE_UART-D%20__MCUXPRESSO%20-D__%20USE_CMSIS-DDEBUG-I%20%22%20%2FUsers%2Fmcbookpro13_nik%2Fmccuxpresso%2Fmcxn947_project_2%2FBoard%20%22-I%20%22%20%2Fusers%2Fmcbookpro13_project_2%2FBoard-I%20%2Fmcbookpro13_nik%2Fmcuxpresso%2Fproject_2%2FSource%22-I%20%22%20%2FUsers%2Fmcbookpro13_nik%2Fmcuxpresso%2Fmcxn947_project_2%2FDrivers%20%22-I%20%22%20%2FUsers%2Fmcbookpro13_nik%2Fmcuxpresso%2Fmcxn947_project_nik%2Fmcbookpro13_project_2%2FUtilities%2Fdebug_project_2%2FDevice%20%22-I%20%22%20%2Fusers%2Fmcbookpro13_project_2%2FUtilities%2Fdebug_g_project_2%2FUtilities%2FDEBUG_GConsole%20%22-I%20%22%20%2FUsers%2Fmacbookpro13_nik%2Fmcuxpresso%2Fmcxn947_project_2%2Fcomponent%2Fuart%20%22-I%20%22%20%2FUsers%2Fmacbookpro13_nik%2Fmcuxpresso%2Fmcxn947_project_2%2FUtilities%2FDEBUG_Config%20%22-I%20%22%20%2FUsers%2Fmacbookpro13_nik%2Fmcuxpresso%2Fmcuxpresso%2Fproject_2%2Fcomponent%2Fserial_mcubro13_nik%2Fmcuxpresso%2Fproject_mcuxpresso13_project_2%2Fcomponent%2FSerial_Macbookpro13_nik%2Fmcuxpresso%2Fmcxn947_project_2%2Fcomponent%2FLists%20%22-I%20%22%20%2FUsers%2Fmacbookpro13_nik%2F%20%22%20%22mcuxpresso%2Fmcxn947_project_2%2Fdevice%2FPeriph%20%22-I%20%22%20%2FUsers%2Fmcbookpro13_nik%2Fmcuxpresso%2Fmcxn947_project_2%2FUtilities%20%22-I%20%22%20%2FUsers%2Fmcbookpro13_nik%2Fmcbookpro13_nik%2Fmcbookpro13_nik%2Fmcbookpro13_nik%2Fmcuxpro13_nik%2Fmcuxpro13_nik%2Fmcuxpro13_nik%2Fmcuxpro13_nik%2Fmcuxpro13_nik%2Fcuxpresso%2Fmcxn947_project_2%2Fcmsis%2FM-Profile%20%22-I%20%2029%2Fusers%2Fmacbookpro13_nik%2Fmcuxpresso%2Fmcxn947_project_2%2FUtilities%2Fstr%20%22-O0-fno-common-gdwarf-4-Wall-c-function-sections-functionso%2Ffno-builtine-fmacro-prefix-map%3D%20%22...%2Fstartup%2F%20%22%20%3D-mcpu%3Dcortex-m33-mfpu%3Dfpv5-sp-d16-mfloat-abi%3Dhard-mthumb-D%20__REDLIB__-fstack-usage-specs%3Dredlib.specs-MMD-MP-MF%20%22%20startup_mcxn947_cm33_core0.d%20%22-MT%22startup%2Fstartup_mcxn947_cm33_core0.o%22-MT%22startup%2Fstartup_mcxn947_cm33_core0.d%22-o%22startup%2Fstartup_mcxn947_cm33_core0.o%22%22..%2Fstartup%2Fstartup_mcxn947_cm33_core0.c%22%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E8%B0%83%E7%94%A8%EF%BC%9AMCU%20C%20%E7%BC%96%E8%AF%91%E5%99%A8%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E6%9E%84%E5%BB%BA%E6%96%87%E4%BB%B6%EF%BC%9A...%2Fsource%2FMCXN947_Project_2.c%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3Earm-none-eabi-gcc-D%20__REDLIB__-DCPU_MCXN947VDF-dcpu_mcxn947vdf_cm33-dcpu_mcxn947vdf_cm33_cm33_core0-DSDK_OS_BAREMETAL-DSERIAL_PORT_TYPE_UART%3D1-DSDK_DEBUGCONSOLE%3D0-DCR_INTEGER_PRINTF%20DPRINTF_FLOAT_ENABLE%3D0-DSDK_DEBUGCONSOLE_UART-D%20__MCUXPRESSO%20-D__%20USE_CMSIS-DDEBUG-I%20%22%20%2FUsers%2Fmcbookpro13_nik%2Fmccuxpresso%2Fmcxn947_project_2%2F%E6%9D%BF%20%22-I%20%22%20%2Fusers%2Fmcbookpro13_project_2%2F%E6%9D%BF-I%20%2Fmcbookpro13_nik%2Fmcuxpresso%2Fproject_2%2FSource%22-I%20%22%20%2FUsers%2Fmcbookpro13_nik%2Fmcuxpresso%2Fmcxn947_project_2%2FDrivers%20%22-I%20%22%20%2FUsers%2Fmcbookpro13_nik%2Fmcuxpresso%2Fmcxn947_project_nik%2Fmcbookpro13_project_2%2FUtilities%2Fdebug_project_2%2F%E8%AE%BE%E5%A4%87%20%22-I%20%22%20%2Fusers%2Fmcbookpro13_project_2%2FUtilities%2Fdebug_g_project_2%2FUtilities%2FDEBUG_GConsole%20%22-I%20%22%20%2FUsers%2Fmacbookpro13_nik%2Fmcuxpresso%2Fmcxn947_project_2%2F%E5%85%83%E5%99%A8%E4%BB%B6%2Fuart%20%22-I%20%22%20%2FUsers%2Fmacbookpro13_nik%2Fmcuxpresso%2Fmcxn947_project_2%2FUtilities%2FDEBUG_Config%20%22-I%20%22%20%2FUsers%2Fmacbookpro13_nik%2Fmcuxpresso%2Fmcuxpresso%2Fproject_2%2F%E5%85%83%E5%99%A8%E4%BB%B6%2Fserial_mcubro13_nik%2Fmcuxpresso%2Fproject_mcuxpresso13_project_2%2F%E5%85%83%E5%99%A8%E4%BB%B6%2FSerial_Macbookpro13_nik%2Fmcuxpresso%2Fmcxn947_project_2%2F%E5%85%83%E5%99%A8%E4%BB%B6%2FLists%20%22-I%20%22%20%2FUsers%2Fmacbookpro13_nik%2F%20%22%20%22mcuxpresso%2Fmcxn947_project_2%2F%E8%AE%BE%E5%A4%87%2FPeriph%20%22-I%20%22%20%2FUsers%2Fmcbookpro13_nik%2Fmcuxpresso%2Fmcxn947_project_2%2FUtilities%20%22-I%20%22%20%2FUsers%2Fmcbookpro13_nik%2Fmcbookpro13_nik%2Fmcbookpro13_nik%2Fmcbookpro13_nik%2Fmcuxpro13_nik%2Fmcuxpro13_nik%2Fmcuxpro13_nik%2Fmcuxpro13_nik%2Fmcuxpro13_nik%2Fcuxpresso%2Fmcxn947_project_2%2Fcmsis%2FM-Profile%20%22-I%20%2029%2Fusers%2Fmacbookpro13_nik%2Fmcuxpresso%2Fmcxn947_project_2%2FUtilities%2Fstr%20%22-O0-fno-common-gdwarf-4-Wall-c-function-sections-functionso%2Ffno-builtine-fmacro-prefix-map%3D%20%22...%2Futilities%2F%20%22%20%3D-mcpu%3Dcortex-m33-mfpu%3Dfpv5-sp-d16-mfloat-abi%3Dhard-mthumb-D%20__REDLIB__-fstack-usage-specs%3Dredlib.specs-mmd-MP%20%22%20%E5%AE%9E%E7%94%A8%E7%A8%8B%E5%BA%8F%2Ffsl_assert.d%20%22-MT%22utilities%2Ffsl_assert.o%22-MT%22utilities%2Ffsl_assert.d%22-o%22utilities%2Ffsl_assert.o%22%22..%2Futilities%2Ffsl_assert.c%22%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E6%9E%84%E5%BB%BA%E6%96%87%E4%BB%B6%EF%BC%9A...%2Fsource%2Fsemihost_hardfault.c%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E8%B0%83%E7%94%A8%EF%BC%9AMCU%20C%20%E7%BC%96%E8%AF%91%E5%99%A8%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3Earm-none-eabi-gcc-D%20__REDLIB__-DCPU_MCXN947VDF-dcpu_mcxn947vdf_cm33-dcpu_mcxn947vdf_cm33_cm33_core0-DSDK_OS_BAREMETAL-DSERIAL_PORT_TYPE_UART%3D1-DSDK_DEBUGCONSOLE%3D0-DCR_INTEGER_PRINTF%20DPRINTF_FLOAT_ENABLE%3D0-DSDK_DEBUGCONSOLE_UART-D%20__MCUXPRESSO%20-D__%20USE_CMSIS-DDEBUG-I%20%22%20%2FUsers%2Fmcbookpro13_nik%2Fmccuxpresso%2Fmcxn947_project_2%2FBoard%20%22-I%20%22%20%2Fusers%2Fmcbookpro13_project_2%2FBoard-I%20%2Fmcbookpro13_nik%2Fmcuxpresso%2Fproject_2%2FSource%22-I%20%22%20%2FUsers%2Fmcbookpro13_nik%2Fmcuxpresso%2Fmcxn947_project_2%2FDrivers%20%22-I%20%22%20%2FUsers%2Fmcbookpro13_nik%2Fmcuxpresso%2Fmcxn947_project_nik%2Fmcbookpro13_project_2%2FUtilities%2Fdebug_project_2%2FDevice%20%22-I%20%22%20%2Fusers%2Fmcbookpro13_project_2%2FUtilities%2Fdebug_g_project_2%2FUtilities%2FDEBUG_GConsole%20%22-I%20%22%20%2FUsers%2Fmacbookpro13_nik%2Fmcuxpresso%2Fmcxn947_project_2%2Fcomponent%2Fuart%20%22-I%20%22%20%2FUsers%2Fmacbookpro13_nik%2Fmcuxpresso%2Fmcxn947_project_2%2FUtilities%2FDEBUG_Config%20%22-I%20%22%20%2FUsers%2Fmacbookpro13_nik%2Fmcuxpresso%2Fmcuxpresso%2Fproject_2%2Fcomponent%2Fserial_mcubro13_nik%2Fmcuxpresso%2Fproject_mcuxpresso13_project_2%2Fcomponent%2FSerial_Macbookpro13_nik%2Fmcuxpresso%2Fmcxn947_project_2%2Fcomponent%2FLists%20%22-I%20%22%20%2FUsers%2Fmacbookpro13_nik%2F%20%22%20%22mcuxpresso%2Fmcxn947_project_2%2Fdevice%2FPeriph%20%22-I%20%22%20%2FUsers%2Fmcbookpro13_nik%2Fmcuxpresso%2Fmcxn947_project_2%2FUtilities%20%22-I%20%22%20%2FUsers%2Fmcbookpro13_nik%2Fmcbookpro13_nik%2Fmcbookpro13_nik%2Fmcbookpro13_nik%2Fmcuxpro13_nik%2Fmcuxpro13_nik%2Fmcuxpro13_nik%2Fmcuxpro13_nik%2Fmcuxpro13_nik%2Fcuxpresso%2Fmcxn947_project_2%2Fcmsis%2FM-Profile%20%22-I%20%2029%2Fusers%2Fmacbookpro13_nik%2Fmcuxpresso%2Fmcxn947_project_2%2FUtilities%2Fstr%20%22-O0-fno-common-gdwarf-4-Wall-c-function-sections-functionso%2Ffno-builtine-fmacro-prefix-map%3D%20%22...%2Fsource%2F%20%22%20%3D-mcpu%3Dcortex-m33-mfpu%3Dfpv5-sp-d16-mfloat-abi%3Dhard-mthumb-D%20__REDLIB__-fstack-usage-specs%3Dredlib.specs-mmd-MP-MF%20%22%20%E6%9D%A5%E6%BA%90%2Fmcxn947_project_2.D%20%22-MT%22source%2FMCXN947_Project_2.o%22-MT%22source%2FMCXN947_Project_2.d%22-o%22source%2FMCXN947_Project_2.o%22%22..%2Fsource%2FMCXN947_Project_2.c%22%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E8%B0%83%E7%94%A8%EF%BC%9AMCU%20C%20%E7%BC%96%E8%AF%91%E5%99%A8%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3Earm-none-eabi-gcc%20-D__REDLIB__%20-DCPU_MCXN947VDF%20-DCPU_MCXN947VDF_cm33%20-DCPU_MCXN947VDF_cm33_core0%20-DSDK_OS_BAREMETAL%20-DSERIAL_PORT_TYPE_UART%3D1%20-DSDK_DEBUGCONSOLE%3D0%20-DCR_INTEGER_PRINTF%20-DPRINTF_FLOAT_ENABLE%3D0%20-DSDK_DEBUGCONSOLE_UART%20-D__MCUXPRESSO%20-D__USE_CMSIS%20-DDEBUG%20-I%22%2FUsers%2Fmacbookpro13_nik%2Fmcuxpresso%2FMCXN947_Project_2%2F%E6%9D%BF%22%20-I%22%2FUsers%2Fmacbookpro13_nik%2Fmcuxpresso%2FMCXN947_Project_2%2Fsource%22%20-I%22%2FUsers%2Fmacbookpro13_nik%2Fmcuxpresso%2FMCXN947_Project_2%2Fdrivers%22%20-I%22%2FUsers%2Fmacbookpro13_nik%2Fmcuxpresso%2FMCXN947_Project_2%2F%E8%AE%BE%E5%A4%87%22%20-I%22%2FUsers%2Fmacbookpro13_nik%2Fmcuxpresso%2FMCXN947_Project_2%2Futilities%2Fdebug_console%22%20-I%22%2FUsers%2Fmacbookpro13_nik%2Fmcuxpresso%2FMCXN947_Project_2%2F%E5%85%83%E5%99%A8%E4%BB%B6%2Fuart%22%20-I%22%2FUsers%2Fmacbookpro13_nik%2Fmcuxpresso%2FMCXN947_Project_2%2Futilities%2Fdebug_console%2Fconfig%22%20-I%22%2FUsers%2Fmacbookpro13_nik%2Fmcuxpresso%2FMCXN947_Project_2%2F%E5%85%83%E5%99%A8%E4%BB%B6%2Fserial_manager%22%20-I%22%2FUsers%2Fmacbookpro13_nik%2Fmcuxpresso%2FMCXN947_Project_2%2F%E5%85%83%E5%99%A8%E4%BB%B6%2Flists%22%20-I%22%2FUsers%2Fmacbookpro13_nik%2Fmcuxpresso%2FMCXN947_Project_2%2F%E8%AE%BE%E5%A4%87%2Fperiph%22%20-I%22%2FUsers%2Fmacbookpro13_nik%2Fmcuxpresso%2FMCXN947_Project_2%2Futilities%22%20-I%22%2FUsers%2Fmacbookpro13_nik%2Fmcuxpresso%2FMCXN947_Project_2%2FCMSIS%22%20-I%22%2FUsers%2Fmacbookpro13_nik%2Fmcuxpresso%2FMCXN947_Project_2%2FCMSIS%2Fm-profile%22%20-I%22%2FUsers%2Fmacbookpro13_nik%2Fmcuxpresso%2FMCXN947_Project_2%2Futilities%2Fstr%22%20-O0%20-fno-common%20-g3%20-gdwarf-4%20-Wall%20-c%20-ffunction-sections%20-fdata-sections%20-fno-builtin%20-fmerge-constants%20-fmacro-prefix-map%3D%22..%2Fsource%2F%22%3D%20-mcpu%3Dcortex-m33%20-mfpu%3Dfpv5-sp-d16%20-mfloat-abi%3Dhard%20-mthumb%20-D__REDLIB__%20-fstack-usage%20-specs%3Dredlib.specs%20-MMD%20-MP%20-MF%22source%2Fsemihost_hardfault.d%22-MT%22source%2Fsemihost_hardfault.o%22-MT%22source%2Fsemihost_hardfault.d%22-o%22source%2Fsemihost_hardfault.o%22%22..%2Fsource%2Fsemihost_hardfault.c%22%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3Edyld%5B31585%5D%EF%BC%9A%E6%9C%AA%E5%8A%A0%E8%BD%BD%E5%BA%93%EF%BC%9A%2Fusr%2Flocal%2Fopt%2Fzstd%2Flib%2Flibzstd.1.dylib%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E5%BC%95%E7%94%A8%E8%87%AA%EF%BC%9A%26lt%3B66B02E5C-65B3-3C28-8492-4979A8E596B8%26gt%3B%20%2FApplications%2FMCUXpressoIDE_25.6.136%2Fide%2Fplugins%2Fcom.nxp.mcuxpresso.tools.macosx_25.6.0.202501151204%2Ftools%2Flibexec%2Fgcc%2FArm-none-eabi%2F14.2.1%2Fcc1%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E5%8E%9F%E5%9B%A0%EF%BC%9A%E5%B0%9D%E8%AF%95%EF%BC%9A%22%2Fusr%2Flocal%2Fopt%2Fzstd%2Flib%2Flibzstd.1.dylib(%E6%97%A0%E6%AD%A4%E7%B1%BB%E6%96%87%E4%BB%B6%EF%BC%89%EF%BC%8C%22%2FSystem%2FVolumes%2FPreboot%2FCryptexes%2FOS%2Fusr%2Flocal%2Fopt%2Fzstd%2Flib%2Flibzstd.1.dylib(%E6%97%A0%E6%AD%A4%E6%96%87%E4%BB%B6%EF%BC%89%EF%BC%8C%22%2Fusr%2Flocal%2Fopt%2Fzstd%2Flib%2Flibzstd.1.dylib(%E6%97%A0%E6%AD%A4%E6%96%87%E4%BB%B6%EF%BC%89%EF%BC%8C%22%2Fusr%2Flib%2Flibzstd.1.dylib(%E6%97%A0%E6%AD%A4%E6%96%87%E4%BB%B6%EF%BC%8C%E4%B8%8D%E5%9C%A8%20dyld%20%E7%BC%93%E5%AD%98%E4%B8%AD%EF%BC%89%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3Earm-none-eabi-gcc%EF%BC%9A%E5%86%85%E9%83%A8%E7%BC%96%E8%AF%91%E5%99%A8%E9%94%99%E8%AF%AF%EF%BC%9A%E4%B8%AD%E6%AD%A2%E9%99%B7%E9%98%B1%EF%BC%9A6%20%E4%BF%A1%E5%8F%B7%E7%BB%88%E6%AD%A2%E7%9A%84%E7%A8%8B%E5%BA%8F%20cc1%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E8%AF%B7%E6%8F%90%E4%BA%A4%E5%AE%8C%E6%95%B4%E7%9A%84%E9%94%99%E8%AF%AF%E6%8A%A5%E5%91%8A%EF%BC%8C%E5%B9%B6%E9%99%84%E4%B8%8A%E9%A2%84%E5%A4%84%E7%90%86%E7%9A%84%E6%BA%90%E4%BB%A3%E7%A0%81%EF%BC%88%E4%BD%BF%E7%94%A8%20-freport-bug%EF%BC%89%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E8%A7%81%26lt%3B%3CA%20href%3D%22https%3A%2F%2Fbugs.linaro.org%2F%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fbugs.linaro.org%2F%3C%2FA%3E%26gt%3B%E4%BB%A5%E8%8E%B7%E5%8F%96%E8%AF%B4%E6%98%8E%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3Emake%5B1%5D%EF%BC%9A***%20%5Butilities%2Fstr%2Fsubdir.mk%3A20%EF%BC%9Autilities%2Fstr%2Ffsl_str.o%5D%E9%94%99%E8%AF%AF%204%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3Emake%5B1%5D%EF%BC%9A***%20%E7%AD%89%E5%BE%85%E6%9C%AA%E5%AE%8C%E6%88%90%E7%9A%84%E5%B7%A5%E4%BD%9C....%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3Edyld%5B31587%5D%EF%BC%9A%E6%9C%AA%E5%8A%A0%E8%BD%BD%E5%BA%93%EF%BC%9A%2Fusr%2Flocal%2Fopt%2Fzstd%2Flib%2Flibzstd.1.dylib%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E5%BC%95%E7%94%A8%E8%87%AA%EF%BC%9A%26lt%3B66B02E5C-65B3-3C28-8492-4979A8E596B8%26gt%3B%20%2FApplications%2FMCUXpressoIDE_25.6.136%2Fide%2Fplugins%2Fcom.nxp.mcuxpresso.tools.macosx_25.6.0.202501151204%2Ftools%2Flibexec%2Fgcc%2FArm-none-eabi%2F14.2.1%2Fcc1%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E5%8E%9F%E5%9B%A0%EF%BC%9A%E5%B0%9D%E8%AF%95%EF%BC%9A%22%2Fusr%2Flocal%2Fopt%2Fzstd%2Flib%2Flibzstd.1.dylib(%E6%97%A0%E6%AD%A4%E7%B1%BB%E6%96%87%E4%BB%B6%EF%BC%89%EF%BC%8C%22%2FSystem%2FVolumes%2FPreboot%2FCryptexes%2FOS%2Fusr%2Flocal%2Fopt%2Fzstd%2Flib%2Flibzstd.1.dylib(%E6%97%A0%E6%AD%A4%E6%96%87%E4%BB%B6%EF%BC%89%EF%BC%8C%22%2Fusr%2Flocal%2Fopt%2Fzstd%2Flib%2Flibzstd.1.dylib(%E6%97%A0%E6%AD%A4%E6%96%87%E4%BB%B6%EF%BC%89%EF%BC%8C%22%2Fusr%2Flib%2Flibzstd.1.dylib(%E6%97%A0%E6%AD%A4%E6%96%87%E4%BB%B6%EF%BC%8C%E4%B8%8D%E5%9C%A8%20dyld%20%E7%BC%93%E5%AD%98%E4%B8%AD%EF%BC%89%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3Earm-none-eabi-gcc%EF%BC%9A%E5%86%85%E9%83%A8%E7%BC%96%E8%AF%91%E5%99%A8%E9%94%99%E8%AF%AF%EF%BC%9A%E4%B8%AD%E6%AD%A2%E9%99%B7%E9%98%B1%EF%BC%9A6%20%E4%BF%A1%E5%8F%B7%E7%BB%88%E6%AD%A2%E7%9A%84%E7%A8%8B%E5%BA%8F%20cc1%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E8%AF%B7%E6%8F%90%E4%BA%A4%E5%AE%8C%E6%95%B4%E7%9A%84%E9%94%99%E8%AF%AF%E6%8A%A5%E5%91%8A%EF%BC%8C%E5%B9%B6%E9%99%84%E4%B8%8A%E9%A2%84%E5%A4%84%E7%90%86%E7%9A%84%E6%BA%90%E4%BB%A3%E7%A0%81%EF%BC%88%E4%BD%BF%E7%94%A8%20-freport-bug%EF%BC%89%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E8%A7%81%26lt%3B%3CA%20href%3D%22https%3A%2F%2Fbugs.linaro.org%2F%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fbugs.linaro.org%2F%3C%2FA%3E%26gt%3B%E4%BB%A5%E8%8E%B7%E5%8F%96%E8%AF%B4%E6%98%8E%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3Emake%5B1%5D%EF%BC%9A***%20%5Bstartup%2Fsubdir.mk%3A23%EF%BC%9A%E5%90%AF%E5%8A%A8%2Fboot_multicore_slave.o%5D%E3%80%82%E9%94%99%E8%AF%AF%204%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3Edyld%5B31588%5D%EF%BC%9A%E6%9C%AA%E5%8A%A0%E8%BD%BD%E5%BA%93%EF%BC%9A%2Fusr%2Flocal%2Fopt%2Fzstd%2Flib%2Flibzstd.1.dylib%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E5%BC%95%E7%94%A8%E8%87%AA%EF%BC%9A%26lt%3B66B02E5C-65B3-3C28-8492-4979A8E596B8%26gt%3B%20%2FApplications%2FMCUXpressoIDE_25.6.136%2Fide%2Fplugins%2Fcom.nxp.mcuxpresso.tools.macosx_25.6.0.202501151204%2Ftools%2Flibexec%2Fgcc%2FArm-none-eabi%2F14.2.1%2Fcc1%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E5%8E%9F%E5%9B%A0%EF%BC%9A%E5%B0%9D%E8%AF%95%EF%BC%9A%22%2Fusr%2Flocal%2Fopt%2Fzstd%2Flib%2Flibzstd.1.dylib(%E6%97%A0%E6%AD%A4%E7%B1%BB%E6%96%87%E4%BB%B6%EF%BC%89%EF%BC%8C%22%2FSystem%2FVolumes%2FPreboot%2FCryptexes%2FOS%2Fusr%2Flocal%2Fopt%2Fzstd%2Flib%2Flibzstd.1.dylib(%E6%97%A0%E6%AD%A4%E6%96%87%E4%BB%B6%EF%BC%89%EF%BC%8C%22%2Fusr%2Flocal%2Fopt%2Fzstd%2Flib%2Flibzstd.1.dylib(%E6%97%A0%E6%AD%A4%E6%96%87%E4%BB%B6%EF%BC%89%EF%BC%8C%22%2Fusr%2Flib%2Flibzstd.1.dylib(%E6%97%A0%E6%AD%A4%E6%96%87%E4%BB%B6%EF%BC%8C%E4%B8%8D%E5%9C%A8%20dyld%20%E7%BC%93%E5%AD%98%E4%B8%AD%EF%BC%89%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3Earm-none-eabi-gcc%EF%BC%9A%E5%86%85%E9%83%A8%E7%BC%96%E8%AF%91%E5%99%A8%E9%94%99%E8%AF%AF%EF%BC%9A%E4%B8%AD%E6%AD%A2%E9%99%B7%E9%98%B1%EF%BC%9A6%20%E4%BF%A1%E5%8F%B7%E7%BB%88%E6%AD%A2%E7%9A%84%E7%A8%8B%E5%BA%8F%20cc1%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E8%AF%B7%E6%8F%90%E4%BA%A4%E5%AE%8C%E6%95%B4%E7%9A%84%E9%94%99%E8%AF%AF%E6%8A%A5%E5%91%8A%EF%BC%8C%E5%B9%B6%E9%99%84%E4%B8%8A%E9%A2%84%E5%A4%84%E7%90%86%E7%9A%84%E6%BA%90%E4%BB%A3%E7%A0%81%EF%BC%88%E4%BD%BF%E7%94%A8%20-freport-bug%EF%BC%89%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E8%A7%81%26lt%3B%3CA%20href%3D%22https%3A%2F%2Fbugs.linaro.org%2F%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fbugs.linaro.org%2F%3C%2FA%3E%26gt%3B%E4%BB%A5%E8%8E%B7%E5%8F%96%E8%AF%B4%E6%98%8E%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3Emake%5B1%5D%EF%BC%9A***%20%5Butilities%2Fdebug_console%2Fsubdir.mk%3A20%EF%BC%9A%E5%AE%9E%E7%94%A8%E5%B7%A5%E5%85%B7%2Fdebug_console%2Ffsl_debug_console.o%5D%E3%80%82%E9%94%99%E8%AF%AF%204%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3Edyld%5B31589%5D%EF%BC%9A%E6%9C%AA%E5%8A%A0%E8%BD%BD%E5%BA%93%EF%BC%9A%2Fusr%2Flocal%2Fopt%2Fzstd%2Flib%2Flibzstd.1.dylib%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E5%BC%95%E7%94%A8%E8%87%AA%EF%BC%9A%26lt%3B66B02E5C-65B3-3C28-8492-4979A8E596B8%26gt%3B%20%2FApplications%2FMCUXpressoIDE_25.6.136%2Fide%2Fplugins%2Fcom.nxp.mcuxpresso.tools.macosx_25.6.0.202501151204%2Ftools%2Flibexec%2Fgcc%2FArm-none-eabi%2F14.2.1%2Fcc1%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E5%8E%9F%E5%9B%A0%EF%BC%9A%E5%B0%9D%E8%AF%95%EF%BC%9A%22%2Fusr%2Flocal%2Fopt%2Fzstd%2Flib%2Flibzstd.1.dylib(%E6%97%A0%E6%AD%A4%E7%B1%BB%E6%96%87%E4%BB%B6%EF%BC%89%EF%BC%8C%22%2FSystem%2FVolumes%2FPreboot%2FCryptexes%2FOS%2Fusr%2Flocal%2Fopt%2Fzstd%2Flib%2Flibzstd.1.dylib(%E6%97%A0%E6%AD%A4%E6%96%87%E4%BB%B6%EF%BC%89%EF%BC%8C%22%2Fusr%2Flocal%2Fopt%2Fzstd%2Flib%2Flibzstd.1.dylib(%E6%97%A0%E6%AD%A4%E6%96%87%E4%BB%B6%EF%BC%89%EF%BC%8C%22%2Fusr%2Flib%2Flibzstd.1.dylib(%E6%97%A0%E6%AD%A4%E6%96%87%E4%BB%B6%EF%BC%8C%E4%B8%8D%E5%9C%A8%20dyld%20%E7%BC%93%E5%AD%98%E4%B8%AD%EF%BC%89%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3Earm-none-eabi-gcc%EF%BC%9A%E5%86%85%E9%83%A8%E7%BC%96%E8%AF%91%E5%99%A8%E9%94%99%E8%AF%AF%EF%BC%9A%E4%B8%AD%E6%AD%A2%E9%99%B7%E9%98%B1%EF%BC%9A6%20%E4%BF%A1%E5%8F%B7%E7%BB%88%E6%AD%A2%E7%9A%84%E7%A8%8B%E5%BA%8F%20cc1%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E8%AF%B7%E6%8F%90%E4%BA%A4%E5%AE%8C%E6%95%B4%E7%9A%84%E9%94%99%E8%AF%AF%E6%8A%A5%E5%91%8A%EF%BC%8C%E5%B9%B6%E9%99%84%E4%B8%8A%E9%A2%84%E5%A4%84%E7%90%86%E7%9A%84%E6%BA%90%E4%BB%A3%E7%A0%81%EF%BC%88%E4%BD%BF%E7%94%A8%20-freport-bug%EF%BC%89%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E8%A7%81%26lt%3B%3CA%20href%3D%22https%3A%2F%2Fbugs.linaro.org%2F%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fbugs.linaro.org%2F%3C%2FA%3E%26gt%3B%E4%BB%A5%E8%8E%B7%E5%8F%96%E8%AF%B4%E6%98%8E%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3Emake%5B1%5D%EF%BC%9A***%20%5Bstartup%2Fsubdir.mk%3A23%EF%BC%9A%E5%90%AF%E5%8A%A8%2F%E5%90%AF%E5%8A%A8_mcxn947_cm33_core0.o%5D%E9%94%99%E8%AF%AF%204%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3Edyld%5B31590%5D%EF%BC%9A%E6%9C%AA%E5%8A%A0%E8%BD%BD%E5%BA%93%EF%BC%9A%2Fusr%2Flocal%2Fopt%2Fzstd%2Flib%2Flibzstd.1.dylib%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E5%BC%95%E7%94%A8%E8%87%AA%EF%BC%9A%26lt%3B66B02E5C-65B3-3C28-8492-4979A8E596B8%26gt%3B%20%2FApplications%2FMCUXpressoIDE_25.6.136%2Fide%2Fplugins%2Fcom.nxp.mcuxpresso.tools.macosx_25.6.0.202501151204%2Ftools%2Flibexec%2Fgcc%2FArm-none-eabi%2F14.2.1%2Fcc1%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E5%8E%9F%E5%9B%A0%EF%BC%9A%E5%B0%9D%E8%AF%95%EF%BC%9A%22%2Fusr%2Flocal%2Fopt%2Fzstd%2Flib%2Flibzstd.1.dylib(%E6%97%A0%E6%AD%A4%E7%B1%BB%E6%96%87%E4%BB%B6%EF%BC%89%EF%BC%8C%22%2FSystem%2FVolumes%2FPreboot%2FCryptexes%2FOS%2Fusr%2Flocal%2Fopt%2Fzstd%2Flib%2Flibzstd.1.dylib(%E6%97%A0%E6%AD%A4%E6%96%87%E4%BB%B6%EF%BC%89%EF%BC%8C%22%2Fusr%2Flocal%2Fopt%2Fzstd%2Flib%2Flibzstd.1.dylib(%E6%97%A0%E6%AD%A4%E6%96%87%E4%BB%B6%EF%BC%89%EF%BC%8C%22%2Fusr%2Flib%2Flibzstd.1.dylib(%E6%97%A0%E6%AD%A4%E6%96%87%E4%BB%B6%EF%BC%8C%E4%B8%8D%E5%9C%A8%20dyld%20%E7%BC%93%E5%AD%98%E4%B8%AD%EF%BC%89%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3Earm-none-eabi-gcc%EF%BC%9A%E5%86%85%E9%83%A8%E7%BC%96%E8%AF%91%E5%99%A8%E9%94%99%E8%AF%AF%EF%BC%9A%E4%B8%AD%E6%AD%A2%E9%99%B7%E9%98%B1%EF%BC%9A6%20%E4%BF%A1%E5%8F%B7%E7%BB%88%E6%AD%A2%E7%9A%84%E7%A8%8B%E5%BA%8F%20cc1%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E8%AF%B7%E6%8F%90%E4%BA%A4%E5%AE%8C%E6%95%B4%E7%9A%84%E9%94%99%E8%AF%AF%E6%8A%A5%E5%91%8A%EF%BC%8C%E5%B9%B6%E9%99%84%E4%B8%8A%E9%A2%84%E5%A4%84%E7%90%86%E7%9A%84%E6%BA%90%E4%BB%A3%E7%A0%81%EF%BC%88%E4%BD%BF%E7%94%A8%20-freport-bug%EF%BC%89%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E8%A7%81%26lt%3B%3CA%20href%3D%22https%3A%2F%2Fbugs.linaro.org%2F%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fbugs.linaro.org%2F%3C%2FA%3E%26gt%3B%E4%BB%A5%E8%8E%B7%E5%8F%96%E8%AF%B4%E6%98%8E%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3Emake%5B1%5D%EF%BC%9A***%20%5Butilities%2Fsubdir.mk%3A20%EF%BC%9Autilities%2Ffsl_assert.o%5D%20%E9%94%99%E8%AF%AF%204%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3Edyld%5B31591%5D%EF%BC%9A%E6%9C%AA%E5%8A%A0%E8%BD%BD%E5%BA%93%EF%BC%9A%2Fusr%2Flocal%2Fopt%2Fzstd%2Flib%2Flibzstd.1.dylib%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E5%BC%95%E7%94%A8%E8%87%AA%EF%BC%9A%26lt%3B66B02E5C-65B3-3C28-8492-4979A8E596B8%26gt%3B%20%2FApplications%2FMCUXpressoIDE_25.6.136%2Fide%2Fplugins%2Fcom.nxp.mcuxpresso.tools.macosx_25.6.0.202501151204%2Ftools%2Flibexec%2Fgcc%2FArm-none-eabi%2F14.2.1%2Fcc1%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E5%8E%9F%E5%9B%A0%EF%BC%9A%E5%B0%9D%E8%AF%95%EF%BC%9A%22%2Fusr%2Flocal%2Fopt%2Fzstd%2Flib%2Flibzstd.1.dylib(%E6%97%A0%E6%AD%A4%E7%B1%BB%E6%96%87%E4%BB%B6%EF%BC%89%EF%BC%8C%22%2FSystem%2FVolumes%2FPreboot%2FCryptexes%2FOS%2Fusr%2Flocal%2Fopt%2Fzstd%2Flib%2Flibzstd.1.dylib(%E6%97%A0%E6%AD%A4%E6%96%87%E4%BB%B6%EF%BC%89%EF%BC%8C%22%2Fusr%2Flocal%2Fopt%2Fzstd%2Flib%2Flibzstd.1.dylib(%E6%97%A0%E6%AD%A4%E6%96%87%E4%BB%B6%EF%BC%89%EF%BC%8C%22%2Fusr%2Flib%2Flibzstd.1.dylib(%E6%97%A0%E6%AD%A4%E6%96%87%E4%BB%B6%EF%BC%8C%E4%B8%8D%E5%9C%A8%20dyld%20%E7%BC%93%E5%AD%98%E4%B8%AD%EF%BC%89%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3Earm-none-eabi-gcc%EF%BC%9A%E5%86%85%E9%83%A8%E7%BC%96%E8%AF%91%E5%99%A8%E9%94%99%E8%AF%AF%EF%BC%9A%E4%B8%AD%E6%AD%A2%E9%99%B7%E9%98%B1%EF%BC%9A6%20%E4%BF%A1%E5%8F%B7%E7%BB%88%E6%AD%A2%E7%9A%84%E7%A8%8B%E5%BA%8F%20cc1%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E8%AF%B7%E6%8F%90%E4%BA%A4%E5%AE%8C%E6%95%B4%E7%9A%84%E9%94%99%E8%AF%AF%E6%8A%A5%E5%91%8A%EF%BC%8C%E5%B9%B6%E9%99%84%E4%B8%8A%E9%A2%84%E5%A4%84%E7%90%86%E7%9A%84%E6%BA%90%E4%BB%A3%E7%A0%81%EF%BC%88%E4%BD%BF%E7%94%A8%20-freport-bug%EF%BC%89%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E8%A7%81%26lt%3B%3CA%20href%3D%22https%3A%2F%2Fbugs.linaro.org%2F%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fbugs.linaro.org%2F%3C%2FA%3E%26gt%3B%E4%BB%A5%E8%8E%B7%E5%8F%96%E8%AF%B4%E6%98%8E%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3Emake%5B1%5D%EF%BC%9A***%20%5Bsource%2Fsubdir.mk%3A23%EF%BC%9Asource%2FMCXN947_Project_2.o%5D%20%E9%94%99%E8%AF%AF%204%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3Edyld%5B31592%5D%EF%BC%9A%E6%9C%AA%E5%8A%A0%E8%BD%BD%E5%BA%93%EF%BC%9A%2Fusr%2Flocal%2Fopt%2Fzstd%2Flib%2Flibzstd.1.dylib%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E5%BC%95%E7%94%A8%E8%87%AA%EF%BC%9A%26lt%3B66B02E5C-65B3-3C28-8492-4979A8E596B8%26gt%3B%20%2FApplications%2FMCUXpressoIDE_25.6.136%2Fide%2Fplugins%2Fcom.nxp.mcuxpresso.tools.macosx_25.6.0.202501151204%2Ftools%2Flibexec%2Fgcc%2FArm-none-eabi%2F14.2.1%2Fcc1%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E5%8E%9F%E5%9B%A0%EF%BC%9A%E5%B0%9D%E8%AF%95%EF%BC%9A%22%2Fusr%2Flocal%2Fopt%2Fzstd%2Flib%2Flibzstd.1.dylib(%E6%97%A0%E6%AD%A4%E7%B1%BB%E6%96%87%E4%BB%B6%EF%BC%89%EF%BC%8C%22%2FSystem%2FVolumes%2FPreboot%2FCryptexes%2FOS%2Fusr%2Flocal%2Fopt%2Fzstd%2Flib%2Flibzstd.1.dylib(%E6%97%A0%E6%AD%A4%E6%96%87%E4%BB%B6%EF%BC%89%EF%BC%8C%22%2Fusr%2Flocal%2Fopt%2Fzstd%2Flib%2Flibzstd.1.dylib(%E6%97%A0%E6%AD%A4%E6%96%87%E4%BB%B6%EF%BC%89%EF%BC%8C%22%2Fusr%2Flib%2Flibzstd.1.dylib(%E6%97%A0%E6%AD%A4%E6%96%87%E4%BB%B6%EF%BC%8C%E4%B8%8D%E5%9C%A8%20dyld%20%E7%BC%93%E5%AD%98%E4%B8%AD%EF%BC%89%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3Earm-none-eabi-gcc%EF%BC%9A%E5%86%85%E9%83%A8%E7%BC%96%E8%AF%91%E5%99%A8%E9%94%99%E8%AF%AF%EF%BC%9A%E4%B8%AD%E6%AD%A2%E9%99%B7%E9%98%B1%EF%BC%9A6%20%E4%BF%A1%E5%8F%B7%E7%BB%88%E6%AD%A2%E7%9A%84%E7%A8%8B%E5%BA%8F%20cc1%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E8%AF%B7%E6%8F%90%E4%BA%A4%E5%AE%8C%E6%95%B4%E7%9A%84%E9%94%99%E8%AF%AF%E6%8A%A5%E5%91%8A%EF%BC%8C%E5%B9%B6%E9%99%84%E4%B8%8A%E9%A2%84%E5%A4%84%E7%90%86%E7%9A%84%E6%BA%90%E4%BB%A3%E7%A0%81%EF%BC%88%E4%BD%BF%E7%94%A8%20-freport-bug%EF%BC%89%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E8%A7%81%26lt%3B%3CA%20href%3D%22https%3A%2F%2Fbugs.linaro.org%2F%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fbugs.linaro.org%2F%3C%2FA%3E%26gt%3B%E4%BB%A5%E8%8E%B7%E5%8F%96%E8%AF%B4%E6%98%8E%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3Emake%5B1%5D%EF%BC%9A***%20%5Bsource%2Fsubdir.mk%3A23%EF%BC%9Asource%2Fsemihost_hardfault.o%5D%20%E9%94%99%E8%AF%AF%204%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3Emake%EF%BC%9A***%20%5Bmakefile%3A45%3A%20all%5D%20%E9%94%99%E8%AF%AF%202%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%22%20make-r-j7%20all%20%22%20%E4%BB%A5%E9%80%80%E5%87%BA%E4%BB%A3%E7%A0%81%202%20%E7%BB%88%E6%AD%A2%E3%80%82%E7%89%88%E6%9C%AC%E5%8F%AF%E8%83%BD%E4%B8%8D%E5%AE%8C%E6%95%B4%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%3E12%3A21%3A43%20%E7%89%88%E6%9C%AC%E5%A4%B1%E8%B4%A5%E3%80%829%20%E4%B8%AA%E9%94%99%E8%AF%AF%EF%BC%8C0%20%E4%B8%AA%E8%AD%A6%E5%91%8A%E3%80%82(%E8%80%97%E6%97%B6%20386%20%E6%AF%AB%E7%A7%92%EF%BC%89%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%3E%E5%A6%82%E4%BD%95%E4%BF%AE%E5%A4%8D%E5%AE%83%E4%BB%AC%EF%BC%9F%E6%88%91%E4%BD%BF%E7%94%A8%E7%9A%84%E6%98%AF%20MacOS%3C%2FSPAN%3E%3C%2FP%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2304343%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20error%20build%20hello_world%20first%20project%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2304343%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F259414%22%20target%3D%22_blank%22%3E%40nik_45935%3C%2FA%3E%3C%2FP%3E%0A%3CDIV%3E%0A%3CP%3E%E8%AF%B7%E4%BB%8E%E4%BB%A5%E4%B8%8B%E7%BD%91%E5%9D%80%E4%B8%8B%E8%BD%BD%20MCUXpresso%20%E9%9B%86%E6%88%90%E5%BC%80%E5%8F%91%E7%8E%AF%E5%A2%83%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdesign%2Fdesign-center%2Fsoftware%2Fdevelopment-software%2Fmcuxpresso-software-and-tools-%2Fmcuxpresso-integrated-development-environment-ide%3AMCUXpresso-IDE%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3E%EF%BC%9A%3C%2FA%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdesign%2Fdesign-center%2Fsoftware%2Fdevelopment-software%2Fmcuxpresso-software-and-tools-%2Fmcuxpresso-integrated-development-environment-ide%3AMCUXpresso-IDE%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fwww.nxp.com%2Fdesign%2Fdesign-center%2Fsoftware%2Fdevelopment-software%2Fmcuxpresso-software-and-tools-%2Fmcuxpresso-integrated-development-environment-ide%3AMCUXpresso-IDE%3C%2FA%3E%20%3C%2FP%3E%0A%3CP%3E%3CBR%20%2F%3E%E7%84%B6%E5%90%8E%E4%BB%8E%E4%BB%A5%E4%B8%8B%E7%BD%91%E5%9D%80%E4%B8%8B%E8%BD%BD%20FRDM-MCXN947%20%E7%9A%84%20SDK%3CA%20href%3D%22https%3A%2F%2Fmcuxpresso.nxp.com%2F%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3E%EF%BC%9A%3C%2FA%3E%3CA%20href%3D%22https%3A%2F%2Fmcuxpresso.nxp.com%2F%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fmcuxpresso.nxp.com%2F%3C%2FA%3E%20%3C%2FP%3E%0A%3CP%3E%3CBR%20%2F%3E%E4%B9%8B%E5%90%8E%EF%BC%8C%E8%AF%B7%E5%8F%82%E9%98%85%20%3CEM%3EMCUXpresso%20IDE%20%E7%94%A8%E6%88%B7%E6%8C%87%E5%8D%97%3C%2FEM%3E%E4%BB%A5%E5%AF%BC%E5%85%A5%20SDK%20%E7%A4%BA%E4%BE%8B%E5%B9%B6%E8%BF%9B%E8%A1%8C%E6%9E%84%E5%BB%BA%E3%80%82%3C%2FP%3E%0A%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Alice_Yang_0-1769998987249.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Alice_Yang_0-1769998987249.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F375085i868A0FE1559AAFDE%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Alice_Yang_0-1769998987249.png%22%20alt%3D%22Alice_Yang_0-1769998987249.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E5%B8%8C%E6%9C%9B%E5%AF%B9%E6%82%A8%E6%9C%89%E6%89%80%E5%B8%AE%E5%8A%A9%E3%80%82%E5%A6%82%E6%9E%9C%E6%82%A8%E4%BB%8D%E6%9C%89%E4%BB%BB%E4%BD%95%E9%97%AE%E9%A2%98%EF%BC%8C%E8%AF%B7%E9%9A%8F%E6%97%B6%E4%B8%8E%E6%88%91%E8%81%94%E7%B3%BB%E3%80%82%3CBR%20%2F%3E%E8%B0%A2%E8%B0%A2%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3E%E7%88%B1%E4%B8%BD%E4%B8%9D%3C%2FP%3E%0A%3C%2FDIV%3E%3C%2FLINGO-BODY%3E
