Why does MCUExpresso IDEcompile so slow
3,216 次查看
davidfu
Is it full compile everytime? As I konw gcc make can do incremental compiling. Can we set incremental compiling?
3,213 次查看
ErichStyger
Specialist I
Hi @davidfu ,
is it compiling all the files? Then I guess you have renamed the project, but did not update the 'Refresh policy' setting? I wrote about this a while back, see https://mcuoneclipse.com/2015/06/06/eclipse-project-refresh-policy-broken-incremental-build-with-ext...
I hope this helps,
Erich
3,214 次查看
ErichStyger
Specialist I
Hi @davidfu ,
I hope this helps,
Erich
3,198 次查看
davidfu
@ErichStyger  Awesome work! It works. I do have change my project name before. Thank you.
B.R.
David
