Questions: How to debug elf files with IDE
3,026件の閲覧回数
daweiyou
Hi Supporter:
One questions from customer:
They use Gcc to compile code and generate .elf, .map, .hex files, they want to know whether MCUXPRESSO IDE could compatitable these format and debug this elf file?
If yes, please show procedures, thanks.
2,888件の閲覧回数
BlackNight
Yes, you can do this:
a) create a project for that device in the IDE
b) in the debug configuration, use your .elf file instead:
I hope this helps,
Erich
2,888件の閲覧回数
daweiyou
Erich:
Will try it, thanks.
