Questions: How to debug elf files with IDE
daweiyou
Hi Supporter:
One questions from customer:
They use Gcc to compile code and generate .elf, .map, .hex files, they want to know whether MCUXPRESSO IDE could compatitable these format and debug this elf file?
If yes, please show procedures, thanks.
BlackNight
Yes, you can do this:
a) create a project for that device in the IDE
b) in the debug configuration, use your .elf file instead:
I hope this helps,
Erich
daweiyou
Erich:
Will try it, thanks.
