Program flash LPC-LINK2 issue
1,811 次查看
dawidstysiak
I noticed that when I use
crt_emu_cm_redlink -flash-load-exec  ...
some bytes in the last sector of flash LPC1115 are not correct.
When I use command
all is fine.
1,724 次查看
lpcxpresso_supp
Using which toolchain - the old LPCXpresso IDE, or the current MCUXpresso IDE? And which version? And if using LPCXpresso IDE, please try the current MCUXpresso IDE out.
I would suggest posting more details into the appropriate toolchain forum.
MCUXpresso IDE Support
1,724 次查看
dawidstysiak
I use the LPCXpresso IDE - v8.2.0. I will try MCUXpresso IDE. Thanks!
