Hello Alice,
I tried it with the lpcxpresso55s69_i2s_dma_transfer example project,
with the same result.
Here's some more data that might help.
I see three mcuxpresso processes running:
rls@rls:~/vorwerk/git/lpc/pbc-lpc$ ps -ef |grep mcux
rls 25133 1823 0 14:46 ? 00:00:00
/usr/local/mcuxpressoide-10.3.1_2233/ide/mcuxpressoide
rls 25150 25133 95 14:46 ? 00:01:46
/usr/local/mcuxpressoide-10.3.1_2233/ide/jre/bin/java
-Dosgi.requiredJavaVersion=1.8 -Xms128m -Xmx1024m
-Djava.net.useSystemProxies=true -jar
/usr/local/mcuxpressoide-10.3.1_2233/ide//plugins/org.eclipse.equinox.launcher_1.4.0.v20161219-1356.jar
-os linux -ws gtk -arch x86_64 -showsplash -launcher
/usr/local/mcuxpressoide-10.3.1_2233/ide/mcuxpressoide -name
Mcuxpressoide --launcher.library
/usr/local/mcuxpressoide-10.3.1_2233/ide//plugins/org.eclipse.equinox.launcher.gtk.linux.x86_64_1.1.551.v20171108-1834/eclipse_1630.so
-startup
--launcher.overrideVmargs -exitdata 27e58000 -vm
/usr/local/mcuxpressoide-10.3.1_2233/ide/jre/bin/java -vmargs
rls 25262 25150 4 14:47 ? 00:00:03
/usr/local/mcuxpressoide-10.3.1_2233/ide/plugins/com.nxp.mcuxpresso.tools.bin.linux_10.3.1.201902141129/binaries/redlinkserv
-telnetport=3025 3050 3075
Here's what I get from gdb when I attach it to each process:
root@rls:/home/rls/vorwerk/git/lpc/pbc-lpc# gdb -p 25133
GNU gdb (Ubuntu 8.1-0ubuntu3) 8.1.0.20180409-git
Copyright (C) 2018 Free Software Foundation, Inc.
License GPLv3+: GNU GPL version 3 or later
<http://gnu.org/licenses/gpl.html>
This is free software: you are free to change and redistribute it.
There is NO WARRANTY, to the extent permitted by law. Type "show copying"
and "show warranty" for details.
This GDB was configured as "x86_64-linux-gnu".
Type "show configuration" for configuration details.
For bug reporting instructions, please see:
<http://www.gnu.org/software/gdb/bugs/>.
Find the GDB manual and other documentation resources online at:
<http://www.gnu.org/software/gdb/documentation/>.
For help, type "help".
Type "apropos word" to search for commands related to "word".
Attaching to process 25133
Reading symbols from
/usr/local/mcuxpressoide-10.3.1_2233/ide/mcuxpressoide...done.
Reading symbols from /lib/x86_64-linux-gnu/libpthread.so.0...Reading
symbols from
/usr/lib/debug/.build-id/28/c6aade70b2d40d1f0f3d0a1a0cad1ab816448f.debug...done.
done.
Using host libthread_db library "/lib/x86_64-linux-gnu/libthread_db.so.1".
Reading symbols from /lib/x86_64-linux-gnu/libdl.so.2...Reading symbols
from /usr/lib/debug//lib/x86_64-linux-gnu/libdl-2.27.so...done.
done.
Reading symbols from /lib/x86_64-linux-gnu/libc.so.6...Reading symbols
from /usr/lib/debug//lib/x86_64-linux-gnu/libc-2.27.so...done.
done.
Reading symbols from /lib64/ld-linux-x86-64.so.2...Reading symbols from
/usr/lib/debug//lib/x86_64-linux-gnu/ld-2.27.so...done.
done.
/usr/local/mcuxpressoide-10.3.1_2233/ide//plugins/org.eclipse.equinox.launcher.gtk.linux.x86_64_1.1.551.v20171108-1834/eclipse_1630.so...done.
Reading symbols from /usr/lib/x86_64-linux-gnu/libgdk-x11-2.0.so.0...(no
debugging symbols found)...done.
/usr/lib/x86_64-linux-gnu/libpangocairo-1.0.so.0...(no debugging symbols
found)...done.
Reading symbols from /usr/lib/x86_64-linux-gnu/libpango-1.0.so.0...(no
/usr/lib/x86_64-linux-gnu/libgdk_pixbuf-2.0.so.0...(no debugging symbols
found)...done.
Reading symbols from /usr/lib/x86_64-linux-gnu/libgio-2.0.so.0...(no
Reading symbols from /usr/lib/x86_64-linux-gnu/libgobject-2.0.so.0...(no
Reading symbols from /usr/lib/x86_64-linux-gnu/libglib-2.0.so.0...(no
Reading symbols from /usr/lib/x86_64-linux-gnu/libfontconfig.so.1...(no
Reading symbols from /usr/lib/x86_64-linux-gnu/libXrender.so.1...(no
Reading symbols from /usr/lib/x86_64-linux-gnu/libXinerama.so.1...(no
Reading symbols from /usr/lib/x86_64-linux-gnu/libXi.so.6...(no
Reading symbols from /usr/lib/x86_64-linux-gnu/libXrandr.so.2...(no
Reading symbols from /usr/lib/x86_64-linux-gnu/libXcursor.so.1...(no
Reading symbols from /usr/lib/x86_64-linux-gnu/libXcomposite.so.1...(no
Reading symbols from /usr/lib/x86_64-linux-gnu/libXdamage.so.1...(no
Reading symbols from /usr/lib/x86_64-linux-gnu/libXfixes.so.3...(no
Reading symbols from /usr/lib/x86_64-linux-gnu/libcairo.so.2...(no
Reading symbols from /usr/lib/x86_64-linux-gnu/libX11.so.6...(no
Reading symbols from /usr/lib/x86_64-linux-gnu/libXext.so.6...(no
Reading symbols from /lib/x86_64-linux-gnu/libm.so.6...Reading symbols
from /usr/lib/debug//lib/x86_64-linux-gnu/libm-2.27.so...done.
done.
/usr/lib/x86_64-linux-gnu/libpangoft2-1.0.so.0...(no debugging symbols
found)...done.
Reading symbols from /usr/lib/x86_64-linux-gnu/libfreetype.so.6...(no
Reading symbols from /usr/lib/x86_64-linux-gnu/libthai.so.0...(no
Reading symbols from /usr/lib/x86_64-linux-gnu/libgmodule-2.0.so.0...(no
Reading symbols from /lib/x86_64-linux-gnu/libz.so.1...(no debugging
Reading symbols from /lib/x86_64-linux-gnu/libselinux.so.1...(no
Reading symbols from /lib/x86_64-linux-gnu/libresolv.so.2...Reading
symbols from /usr/lib/debug//lib/x86_64-linux-gnu/libresolv-2.27.so...done.
done.
Reading symbols from /lib/x86_64-linux-gnu/libmount.so.1...(no debugging
Reading symbols from /usr/lib/x86_64-linux-gnu/libffi.so.6...(no
Reading symbols from /lib/x86_64-linux-gnu/libpcre.so.3...(no debugging
Reading symbols from /lib/x86_64-linux-gnu/libexpat.so.1...(no debugging
Reading symbols from /usr/lib/x86_64-linux-gnu/libpixman-1.so.0...(no
Reading symbols from /usr/lib/x86_64-linux-gnu/libpng16.so.16...(no
Reading symbols from /usr/lib/x86_64-linux-gnu/libxcb-shm.so.0...(no
Reading symbols from /usr/lib/x86_64-linux-gnu/libxcb.so.1...(no
Reading symbols from /usr/lib/x86_64-linux-gnu/libxcb-render.so.0...(no
Reading symbols from /lib/x86_64-linux-gnu/librt.so.1...Reading symbols
from /usr/lib/debug//lib/x86_64-linux-gnu/librt-2.27.so...done.
done.
Reading symbols from /usr/lib/x86_64-linux-gnu/libharfbuzz.so.0...(no
Reading symbols from /usr/lib/x86_64-linux-gnu/libdatrie.so.1...(no
Reading symbols from /lib/x86_64-linux-gnu/libblkid.so.1...(no debugging
Reading symbols from /usr/lib/x86_64-linux-gnu/libXau.so.6...(no
Reading symbols from /usr/lib/x86_64-linux-gnu/libXdmcp.so.6...(no
Reading symbols from /usr/lib/x86_64-linux-gnu/libgraphite2.so.3...(no
Reading symbols from /lib/x86_64-linux-gnu/libuuid.so.1...(no debugging
Reading symbols from /lib/x86_64-linux-gnu/libbsd.so.0...(no debugging
Reading symbols from /usr/lib/x86_64-linux-gnu/libgtk-x11-2.0.so.0...(no
Reading symbols from /usr/lib/x86_64-linux-gnu/libatk-1.0.so.0...(no
/usr/lib/x86_64-linux-gnu/gtk-2.0/modules/libgail.so...(no debugging
Reading symbols from /usr/lib/x86_64-linux-gnu/libgailutil.so.18...(no
/usr/lib/x86_64-linux-gnu/gtk-2.0/modules/libatk-bridge.so...(no
/usr/lib/x86_64-linux-gnu/libatk-bridge-2.0.so.0...(no debugging symbols
found)...done.
Reading symbols from /lib/x86_64-linux-gnu/libdbus-1.so.3...(no
Reading symbols from /usr/lib/x86_64-linux-gnu/libatspi.so.0...(no
Reading symbols from /lib/x86_64-linux-gnu/libsystemd.so.0...(no
Reading symbols from /lib/x86_64-linux-gnu/liblzma.so.5...(no debugging
Reading symbols from /usr/lib/x86_64-linux-gnu/liblz4.so.1...(no
Reading symbols from /lib/x86_64-linux-gnu/libgcrypt.so.20...(no
Reading symbols from /lib/x86_64-linux-gnu/libgpg-error.so.0...(no
0x00007f169d5de204 in __waitpid (pid=25150, stat_loc=0x7fffd89da0fc,
options=0) at ../sysdeps/unix/sysv/linux/waitpid.c:30
30 ../sysdeps/unix/sysv/linux/waitpid.c: No such file or directory.
(gdb) bt
#0 0x00007f169d5de204 in __waitpid (pid=25150, stat_loc=0x7fffd89da0fc,
#1 0x00007f169c3fe1bc in launchJavaVM (args=0x25cf7f0) at eclipseGtk.c:366
#2 0x00007f169c3f9d0a in _run (argc=1, argv=0x255b3b0,
vmArgs=0x255c510) at ../eclipse.c:664
#3 0x00007f169c3f95cc in run (argc=1, argv=0x255b3b0, vmArgs=0x0) at
../eclipse.c:476
#4 0x000000000040163e in main (argc=5, argv=0x255b3b0) at
../eclipseMain.c:217
(gdb)
root@rls:/home/rls/vorwerk/git/lpc/pbc-lpc# gdb -p 25150
Attaching to process 25150
0x00007fcc53d39d2d in __GI___pthread_timedjoin_ex
(threadid=140515560695552, thread_return=0x7fff733d7400, abstime=0x0,
block=.
Attaching to process 25262
0x00007f27d7ccf449 in futex_wait (private=, stack_end=0x7ffcbc767518) at
../csu/libc-start.c:310
#6 0x0000000000403019 in ?? ()
(gdb)
