Open Installed SDKs window?
ソリューションへジャンプ
2,262件の閲覧回数
curtis_hendrix
I closed the "Installed SDKs" window, and now I can't figure out to reopen it.  How can I reopen the "Installed SDKs" window?
2,166件の閲覧回数
lpcxpresso_supp
Simplest way is probably to use the "Quick Access" box (normally in the top right of the IDE window) and start to enter "Installed SDKs", then click on the view when the appropriate entry appears as you type ....
Otherwise, use the menu :
  • Window -> Show View -> Other -> MCUXpresso IDE -> Installed SDKs
MCUXpresso IDE Support
2,167件の閲覧回数
lpcxpresso_supp
