MCUXpresso IDE stuck while loading
5,982 次查看
sandeepthota
IDE is stuck after selecting workspace. Changing to new workspace did not help.
5 回复数
5,975 次查看
ErichStyger
Specialist I
can you check/share the .log inside the .metadata of the workspace folder?
Other than that, can you add the option
-clean
to the command/shortcut launching the IDE?
5,964 次查看
sandeepthota
@ErichStygerPlease find the attached log file. Interestingly it is not updating the log file while starting. Last time the log was updated is with -clean option and I removed the clean and started again and no update on to file.
5,960 次查看
converse
Senior Contributor V
The log says "Unable to clean the storage area:". This implies that there may be another version of MCUXpresso already running. Have you tried rebooting and then running again?
5,959 次查看
sandeepthota
Yes I did several times and it didn't help. I even uninstalled and reinstalled software to see if it fixes but didn't help
5,955 次查看
converse
A couple of things to check:
Do you (as the runner of the program) have write access to the workspace?
Have you got any anti malware software running (virus/firewall)? Could this be stopping it?
