MCUXpresso IDE: Error , Error received while booting LinkServer
4,457 次查看
CEPL_Dev
Hi, I have been using MCUXpresso IDE version v11.3.0_5222 on my windows 10 system and few weeks back I have upgraded to Windows 11 . And since last week I am getting an error, which is attached below. I am using LPC-Link2 Debug Probe. By assuming it might be some compatibility issue, I have upgraded to MCUXpressoIDE_11.7.1 , and still the issue is not resolved. I am Looking for suggestions to fix this issue . Thanks , Amal
Prasanth
4,384 次查看
Pavel_Hernandez
Hello, you could try to run the IDE with an older compatibility of windows, and about the J-Link if you want to flash your target, you can use J-link commander o BLHOST.
Pavel
4 回复数
4,417 次查看
CEPL_Dev
Hi Pavel ,
             Thanks for the response.
I also tried MCUXpressoIDE version 11.7.1, on windows 11, same link server error is coming. Any fix for that .
or using other debugging tools like J-Link might fix the problem?
Amal
Prasanth
4,385 次查看
Pavel_Hernandez
Pavel
4,358 次查看
CEPL_Dev
Hi Pavel,
 thanks for the support,
Have a nice Day.
Amal
Prasanth
4,431 次查看
Pavel_Hernandez
Hello, my name is Pavel and I will be supporting your case, at this moment the last version is the 11.3 but this only work good in win10, there are some errors about the compatibility in win11, I recommend return to win10.
Pavel
