LPC54S018M reset error for FLEXCOMM9/10
1,633 次查看
G1234
There is an error in #define FLEXCOMM_RSTS in drivers/fsl_reset.h causing FLEXCOMM9 to be resetted when actually FLEXCOMM10 should be resetted:
, ...kFC8_RST_SHIFT_RSTn, kFC9_RST_SHIFT_RSTn, kFC9_RST_SHIFT_RSTn
should be
, ...kFC8_RST_SHIFT_RSTn, kFC9_RST_SHIFT_RSTn, kFC10_RST_SHIFT_RSTn
SDK 2.12.0
1,618 次查看
Julián_AragónM
Hi @G1234,
Thank you for the feedback, we will update the SDK team about this issue immediately to update the correction.
Best regards, Julian
1,619 次查看
Julián_AragónM
Hi @G1234,
