KL26Z SIMPLE PROGRAM EEPROM
1,670件の閲覧回数
oswaldo-153
Hello all
someone has an example, using an eeprom memory with kl26z?
some document or information to use the eeprom memory from the kl26z
I am using the IAR compiler, I thank you very much
タグ(2)
1,593件の閲覧回数
danielchen
Hi Oswaldo:
KL doesn't have the EEPROM module, if you want to use it, you can use flash to emulate it.
About the KL EEPROM emulation, pleasae refer to below post
https://community.nxp.com/docs/DOC-94593
I hope it helps.
