Is it possible to use MQX RTOS in MCUXpresso IDE projects?
3,551 次查看
jameso
Is there a way to create an MQX RTOS project in MCUXpresso IDE? I have a project for an MK22FN128VLH10 and prefer to use MQX RTOS.
5 回复数
3,255 次查看
lpcxpresso_supp
It's certainly possible, but MCUXpresso offers no wizard assistance. You're on your own in this regard. There is an MQX Eclipse Plugin, but we've never tested it with MCUXpresso to my knowledge. Finally, MCUXpresso can offer no stack backtrace for MQX threads.
Thanks and regards,
MCUXpresso Support
2,731 次查看
Vidya_1203
Hi, Does MCUXpresso offer wizard assistance for MQX RTOS? If theres a plugin can you give a link for the plugin?
2,686 次查看
lpcxpresso_supp
In the meantime, latest MCUXpresso IDE version offers some level of support for MQX RTOS. See MCUXpresso_IDE_MQX_RTOS_Debug_Guide.pdf located inside the installation folder. Support refers to GDB thread awareness when using LinkServer debug solution - no RTOS TAD views, no NPW support.
MCUXpresso IDE Support
2,594 次查看
Vidya_1203
What is the procedure to integrate MQX RTOS code into MCUXpresso IDE?
标记 (1)
3,255 次查看
m4l490n
lpcxpresso_support‌ do you have a link for that plugin?
