How to relocate & debug program into new flash section?
8,153 次查看
jmreina
We have a program with three separate flash sections. The program compiles & debugs fine with default config (e.g. from BOOTLOADER below, in '1. Memory Config')
  • Sections: BOOTLOADER, APPLICATION & REVERT
Issue:
  • When the program is placed in APPLICATION the program compiles but cannot debug! (see '2. Error I/II')
How can we get debugging working here for a program in the APPLICATION flash section?
8,079 次查看
ZhangJennie
Hi jmreina
Are your bootloader and application in the same project or separated two projects?
If the same project, please create a demo project to show me how to reproduce the issue?
Jun Zhang
8,074 次查看
jmreina
Separate right now! I can share two separate projects for demonstration let me know
