How to program a byte in a specific address on flash on MCUXpresso?
2,342 次查看
alexandrevoigtd
How to program byte by byte on a specifica address on flash. For example, I want to program 0xDE on address 0xFE000. I saw the sdk example but it not explain in how to write a byte in a specific address. This sdk is only possible to write 16 bytes at once. I tryed to modificate but I can´t. Anybody can help me? I am using MK22FN1MA0VLL12
2,199 次查看
Hello Alexandre Voigt da Poian ,
All flash functions except read require the user to setup and launch an FTFE command.
Please check the Flash commands in Reference Manual of MK22FN1MA0VLL12, the minimum size of write id 8 bytes.
TIC
2,199 次查看
alexandrevoigtd
Thank you very much. It was very good for me. Resolved my problem.
2,199 次查看
Hello Alexandre Voigt da Poian,
It's my pleasure.
TIC
