How to import AN5331 source code in last MCUXpresso IDE ?
1,463件の閲覧回数
julienlazarewic
I'm using the last version of MCUXpresso IDE.
I'd like to try "Offiline Flash Programmer" AN5331 but I not able to import source in a valid Xpresso IDE project.
Some help ?
1,350件の閲覧回数
ZhangJennie
Hi Julien.
I just contacted the author of an5331.Per our discussion, the code of an5331 is developed with Keil MDK. There is no easy way to import a MDK project to MCUXpresso. And we don't have MDK->MCUXpreso importer for it.
So far we don't have plan to produce a an5331 SW version for MCUXpresso either.
The fastest way to master an5331 is to get a MDK from Keil.
If you use MCUXpresso, you need do all the import work manually, It's practicable but it may cost some time.
Jennie Zhang
