How do I flash code to my LPCXpresso55S69 board
4,462 次查看
Carei
I want to see exactly the commands used by the IDE to flash my compiled code to the board whenever I click debug. How can I see these commands (and parameters)?
5 回复数
4,184 次查看
brendonslade
The link to Erich Styger's blog and the reference to the IDE User guide from the development team are both correct answers to see what redlinkserv commands the MCUXpresso IDE is doing "under the hood". However, if you want  to just flash your application and run it on your target outside of the IDE then the simplest way is now using LinkServer. See https://nxp.com/linkserver
4,317 次查看
lpcxpresso_supp
Please see section 15.1 from User Guide, functionality around "Preview Command". Is that what you're looking for?
MCUXpresso IDE Support
4,440 次查看
RaRo
Hello @Carei,
If you want to use Command Line to run and build your project, please take a look to the MCUXpresso IDE Command Line User Guide; in other case, could you please provide us more information about what are you doing and want?
Best regards, Raul.
4,419 次查看
Carei
Hello, Raul, and thank you for your help.
Currently I am working on porting an open source project (TockOS) for use with the LPCXpresso55S69 boards. I didn't have much difficulty with the documentation, until I managed to compile the software and found that I don't know how to flash the code (ELF format) to my board.
I have used mcuxpresso a little in the past, and I managed to write a blinky led and a hello world app for use with this board in the IDE. However I am not sure what commands the IDE uses in order to flash my code on the board.
It would be greatly appreciated if you could provide some more specific help on how to find the script the ide uses to flash code on the board. Until then I will start looking on the document you linked.
4,346 次查看
RaRo
Hello @Carei,
Could you please take a look to Standalone and Command Line Programmer with MCUXpresso | MCU on Eclipse? It might be useful. Hope this helps you.
Best regards, Raul.
