FRDM-KL03Z Hello World Example, how-to make RX work?
1,881 次查看
steffen_norbert
I need some help with the above mentioned example:
When used with semi-hosting the example works as expected. However when I use the UART, TX works as expected ("Hello world") while RX does not. I slightly changed the example from echoing to printing the hex value of the received character: Results are "consistent", i.e. the same char always produces the same hex value, however I can't find a meaningful pattern: sending  e.g. '1','2','3',... one would expect to see single bit or at most double bit changes, but  most of the time to many 1-Bits are produced. BTW: a loop-back test of my USB-serial-converter does work as expected.
If the problem is not known, some hints where to find (and read) configuration parameters and error flags would be greatly appreciated.
TX, Steffen
1,759 次查看
steffen_norbert
I found the solution, when I read:
https://jaycarlson.net/pf/freescale-nxp-kinetis-kl03/
After removing C35 everything worked!
Other than mentioned in the FRDM-KL03 Users Guide, even 9600 Baud are too fast with C35 in place!
