I encountered a probably missing parametrized configuration.
Environment:
In ConfigTool>>Peripherals>>FLEXSPI peripheral tab>>Enable LUT Initialization ,
setup a ciustom lut lenght of 60, the default is 64, but generating the code always result into the define in peripherals.h:
#define FLEXSPI_LUT_LENGTH 64
Also tried with other random value between 1 and 64, nothing changes.
Hello @simpledeveloper,
You're totally right, the FLEXSPI_LUT_LENGTH seems fixed, I would report this to the internal team.
Thanks a lot for your feedback!
BR,
Alexis Andalon
