Ethernet Communication
Govind89
I am new to i.MX RT1170 development and using the EVKBMIMXRT1170 board. I'm working with the built-in example code evkbmimxrt1170_enet_txrx_transfer_cm7 for Ethernet functionality, but I'm finding it difficult to understand how it works.
I would like to request a simpler, bare-metal code example that focuses just on basic Ethernet operations:
  • Ethernet configuration
  • Ethernet initialization
  • Ethernet frame transmission
  • Ethernet frame reception
I need this in API-style simple code without RTOS, using MCUXpresso IDE. Please provide guidance and the simplest base code for Ethernet functionality on my EVKBMIMXRT1170 development board.
i.MX-RT1170 MCUXpresso-IDE
Tags (2)
mayliu1
Hi @Govind89 ,
I suggest you can check the example in SDK import Wizard.
Best Regards
MayLiu
mayliu1
Hi @Govind89 ,
Thank you so much for your interest in our products and for using our community.
I think the project you imported is already without FREERTOS, if you want more Ethernet demo, you can check by import  SDK example.
If you want know more about the SDK API. you can refer to the document "MCUXpresso SDK API Reference Manual"
https://mcuxpresso.nxp.com/api_doc/dev/329/index.html
Wish it helps you.
Wish you a nice day!
Best Regards
MayLiu
Govind89
helle @mayliu1
Thanks for replay
Based on the example, I tried, but I am unable to receive and transmit the frame.
I modified the code to create a simpler version. using evkbmimxrt1170_enet_txrx_transfer_cm7 example code please guide me what will be need to change. i am attech project file.
#include "fsl_debug_console.h"
#include "fsl_silicon_id.h"
#include "fsl_enet.h"
#include "fsl_phy.h"
#include "board.h"
#include "fsl_phyrtl8201.h"
#include "board.h"
#define EXAMPLE_ENET ENET
#define EXAMPLE_CLOCK_FREQ CLOCK_GetRootClockFreq(kCLOCK_Root_Bus)
#define ENET_RXBD_NUM 4
#define ENET_TXBD_NUM 4
#define ENET_RXBUFF_SIZE ENET_FRAME_MAX_FRAMELEN
#define ENET_TXBUFF_SIZE ENET_FRAME_MAX_FRAMELEN
#define ENET_DATA_LENGTH 1000
/* Buffer descriptors */
AT_NONCACHEABLE_SECTION_ALIGN(enet_rx_bd_struct_t g_rxBuffDescrip[ENET_RXBD_NUM], ENET_BUFF_ALIGNMENT);
AT_NONCACHEABLE_SECTION_ALIGN(enet_tx_bd_struct_t g_txBuffDescrip[ENET_TXBD_NUM], ENET_BUFF_ALIGNMENT);
/* Data buffers */
SDK_ALIGN(uint8_t g_rxDataBuff[ENET_RXBD_NUM][ENET_RXBUFF_SIZE], ENET_BUFF_ALIGNMENT);
SDK_ALIGN(uint8_t g_txDataBuff[ENET_TXBD_NUM][ENET_TXBUFF_SIZE], ENET_BUFF_ALIGNMENT);
/* MAC address */
uint8_t g_macAddr[6] =
{ 0x02, 0x12, 0x13, 0x14, 0x15, 0x16 };
/* ENET handle */
static enet_handle_t g_handle;
static void BuildTestFrame(uint8_t *frame)
/* Destination MAC (broadcast) */
for (int i = 0; i < 6; i++)
frame[i] = 0xFF;
/* Source MAC */
memcpy(&frame[6], g_macAddr, 6);
/* EtherType/Length */
frame[12] = 0x08; // IPv4
frame[13] = 0x00;
/* Simple payload */
for (int i = 14; i < ENET_DATA_LENGTH; i++)
frame[i] = i % 256;
void InitEthernet(void)
enet_config_t config;
/* Prepare buffer configuration */
enet_buffer_config_t buffConfig =
ENET_RXBD_NUM,
ENET_TXBD_NUM,
ENET_RXBUFF_SIZE,
ENET_TXBUFF_SIZE, g_rxBuffDescrip, g_txBuffDescrip, &g_rxDataBuff[0][0], &g_txDataBuff[0][0],
true,
true,
NULL };
/* Get default ENET configuration */
ENET_GetDefaultConfig(&config);
config.miiMode = kENET_RmiiMode;
config.miiSpeed = kENET_MiiSpeed100M;
config.miiDuplex = kENET_MiiFullDuplex;
/* Initialize ENET */
ENET_Init(EXAMPLE_ENET, &g_handle, &config, &buffConfig, g_macAddr, EXAMPLE_CLOCK_FREQ);
ENET_ActiveRead(EXAMPLE_ENET);
int main(void)
uint8_t txFrame[ENET_DATA_LENGTH];
uint8_t rxBuffer[ENET_RXBUFF_SIZE];
/* Initialize hardware */
BOARD_InitHardware();
/* Initialize Ethernet */
InitEthernet();
/* Build test frame */
BuildTestFrame(txFrame);
while (1)
uint32_t frameLength = 0;
/* Check for received frames */
if (ENET_GetRxFrameSize(&g_handle, &frameLength, 0) == kStatus_Success)
if (frameLength > 0)
/* Read the frame */
if (ENET_ReadFrame(EXAMPLE_ENET, &g_handle, rxBuffer, frameLength, 0, NULL) == kStatus_Success)
/* Process received frame here */
/* Send test frame */
status_t ENET_SendFrame(ENET_Type *base, enet_handle_t *handle, const uint8_t *data, uint32_t length, uint8_t ringId,
bool tsFlag, void *context);
ENET_SendFrame(EXAMPLE_ENET, &g_handle, txFrame, ENET_DATA_LENGTH, 0, false, NULL);
/* Small delay */
for (volatile int i = 0; i < 1000000; i++);
in that i am getting also error undefined reference to `PHY_LinkStatusChange'
mayliu1
Hi @Govind89 ,
I don't recommend modifying the NXP SDK demo code ,because it may introduce additional issues.
Since the NXP SDK demo is already well-optimized , and it was rigorously tested to ensure proper functionality, I suggest you refer to the example code as it is(when the demo runs ok, then you can modify the code you want to test).
Additionally, I suggest you check  the README file for this demo to confirm your development environment is correctly configured.
Wish it helps you.
Best Regards
MayLiu
Govind89
Thank you for your response. Additionally, I would like to inquire about communication between two RT boards using Ethernet. Both boards have 1 Gbps and 100 Mbps ports available. Could you please advise which example I should follow for this setup?
mayliu1
Hi @Govind89 ,
Best Regards
MayLiu
%3CLINGO-SUB%20id%3D%22lingo-sub-2088184%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EEthernet%20Communication%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2088184%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%20class%3D%22%22%3EI%20am%20new%20to%20i.MX%20RT1170%20development%20and%20using%20the%20EVKBMIMXRT1170%20board.%20I'm%20working%20with%20the%20built-in%20example%20code%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3Eevkbmimxrt1170_enet_txrx_transfer_cm7%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3Efor%20Ethernet%20functionality%2C%20but%20I'm%20finding%20it%20difficult%20to%20understand%20how%20it%20works.%3C%2FP%3E%3CP%20class%3D%22%22%3EI%20would%20like%20to%20request%20a%20simpler%2C%20bare-metal%20code%20example%20that%20focuses%20just%20on%20basic%20Ethernet%20operations%3A%3C%2FP%3E%3CUL%3E%3CLI%3E%3CP%20class%3D%22%22%3EEthernet%20configuration%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%20class%3D%22%22%3EEthernet%20initialization%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%20class%3D%22%22%3EEthernet%20frame%20transmission%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%20class%3D%22%22%3EEthernet%20frame%20reception%3C%2FP%3E%3C%2FLI%3E%3C%2FUL%3E%3CP%20class%3D%22%22%3EI%20need%20this%20in%20API-style%20simple%20code%20without%20RTOS%2C%20using%20MCUXpresso%20IDE.%20Please%20provide%20guidance%20and%20the%20simplest%20base%20code%20for%20Ethernet%20functionality%20on%20my%20EVKBMIMXRT1170%20development%20board.%3CBR%20%2F%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fc-pwmxy87654%2Fi.MX-RT1170%2Fpd-p%2Fi.MX-RT1170%22%20class%3D%22lia-product-mention%22%20data-product%3D%22519-1%22%20target%3D%22_blank%22%3Ei.MX-RT1170%3C%2FA%3E%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fc-pwmxy87654%2FMCUXpresso-IDE%2Fpd-p%2FMCUXpresso-IDE%22%20class%3D%22lia-product-mention%22%20data-product%3D%223137-1%22%20target%3D%22_blank%22%3EMCUXpresso-IDE%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2090579%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Ethernet%20Communication%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2090579%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F234971%22%20target%3D%22_blank%22%3E%40Govind89%3C%2FA%3E%26nbsp%3B%2C%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EI%20suggest%20you%20can%20check%20the%20example%20in%20SDK%20import%20Wizard.%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22mayliu1_0-1746098335143.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22mayliu1_0-1746098335143.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F335944i2EDE9580E2430E40%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22mayliu1_0-1746098335143.png%22%20alt%3D%22mayliu1_0-1746098335143.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3EBest%20Regards%3C%2FP%3E%0A%3CP%3EMayLiu%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2089827%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Ethernet%20Communication%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2089827%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EThank%20you%20for%20your%20response.%20Additionally%2C%20I%20would%20like%20to%20inquire%20about%20communication%20between%20two%20RT%20boards%20using%20Ethernet.%20Both%20boards%20have%201%20Gbps%20and%20100%20Mbps%20ports%20available.%20Could%20you%20please%20advise%20which%20example%20I%20should%20follow%20for%20this%20setup%3F%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2089794%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Ethernet%20Communication%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2089794%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F234971%22%20target%3D%22_blank%22%3E%40Govind89%3C%2FA%3E%26nbsp%3B%2C%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EThanks%20for%20your%20updated%20information.%3C%2FP%3E%0A%3CP%3E%3CSPAN%3EI%20don't%20recommend%20modifying%20the%20NXP%20SDK%20demo%20code%20%2Cbecause%20it%20may%20introduce%20additional%20issues.%20%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3ESince%20the%20NXP%20SDK%20demo%20is%20already%20well-optimized%20%2C%20and%20it%20was%20rigorously%20tested%20to%20ensure%20proper%20functionality%2C%20I%20suggest%20you%20refer%20to%20the%20example%20code%20as%20it%20is(when%20the%20demo%20runs%20ok%2C%20then%20you%20can%20modify%20the%20code%20you%20want%20to%20test).%20%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3EAdditionally%2C%20I%20suggest%20you%20check%26nbsp%3B%20the%20README%20file%20for%20this%20demo%20to%20confirm%20your%20development%20environment%20is%20correctly%20configured.%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22mayliu1_0-1745985202094.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22mayliu1_0-1745985202094.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F335705i2E7CB5080A5477E0%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22mayliu1_0-1745985202094.png%22%20alt%3D%22mayliu1_0-1745985202094.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3EWish%20it%20helps%20you.%3CBR%20%2F%3EIf%20you%20still%20have%20question%20about%20it%2C%20please%20kindly%20let%20me%20know.%3C%2FP%3E%0A%3CP%3EWish%20you%20a%20nice%20day!%3C%2FP%3E%0A%3CP%3EBest%20Regards%3CBR%20%2F%3EMayLiu%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2088907%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Ethernet%20Communication%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2088907%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3Ehelle%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F239163%22%20target%3D%22_blank%22%3E%40mayliu1%3C%2FA%3E%3CBR%20%2F%3EThanks%20for%20replay%3CBR%20%2F%3E%3CBR%20%2F%3EBased%20on%20the%20example%2C%20I%20tried%2C%20but%20I%20am%20unable%20to%20receive%20and%20transmit%20the%20frame.%3CBR%20%2F%3E%3CBR%20%2F%3EI%20modified%20the%20code%20to%20create%20a%20simpler%20version.%20using%20evkbmimxrt1170_enet_txrx_transfer_cm7%20example%20code%20please%20guide%20me%20what%20will%20be%20need%20to%20change.%20i%20am%20attech%20project%20file.%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%23include%20%22fsl_debug_console.h%22%3CBR%20%2F%3E%3CBR%20%2F%3E%23include%20%22fsl_silicon_id.h%22%3CBR%20%2F%3E%3CBR%20%2F%3E%23include%20%22fsl_enet.h%22%3CBR%20%2F%3E%3CBR%20%2F%3E%23include%20%22fsl_phy.h%22%3CBR%20%2F%3E%3CBR%20%2F%3E%23include%20%22board.h%22%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%23include%20%22fsl_phyrtl8201.h%22%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%23include%20%22fsl_enet.h%22%3CBR%20%2F%3E%3CBR%20%2F%3E%23include%20%22board.h%22%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%23define%20EXAMPLE_ENET%20ENET%3CBR%20%2F%3E%3CBR%20%2F%3E%23define%20EXAMPLE_CLOCK_FREQ%20CLOCK_GetRootClockFreq(kCLOCK_Root_Bus)%3CBR%20%2F%3E%3CBR%20%2F%3E%23define%20ENET_RXBD_NUM%204%3CBR%20%2F%3E%3CBR%20%2F%3E%23define%20ENET_TXBD_NUM%204%3CBR%20%2F%3E%3CBR%20%2F%3E%23define%20ENET_RXBUFF_SIZE%20ENET_FRAME_MAX_FRAMELEN%3CBR%20%2F%3E%3CBR%20%2F%3E%23define%20ENET_TXBUFF_SIZE%20ENET_FRAME_MAX_FRAMELEN%3CBR%20%2F%3E%3CBR%20%2F%3E%23define%20ENET_DATA_LENGTH%201000%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%2F*%20Buffer%20descriptors%20*%2F%3CBR%20%2F%3E%3CBR%20%2F%3EAT_NONCACHEABLE_SECTION_ALIGN(enet_rx_bd_struct_t%20g_rxBuffDescrip%5BENET_RXBD_NUM%5D%2C%20ENET_BUFF_ALIGNMENT)%3B%3CBR%20%2F%3E%3CBR%20%2F%3EAT_NONCACHEABLE_SECTION_ALIGN(enet_tx_bd_struct_t%20g_txBuffDescrip%5BENET_TXBD_NUM%5D%2C%20ENET_BUFF_ALIGNMENT)%3B%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%2F*%20Data%20buffers%20*%2F%3CBR%20%2F%3E%3CBR%20%2F%3ESDK_ALIGN(uint8_t%20g_rxDataBuff%5BENET_RXBD_NUM%5D%5BENET_RXBUFF_SIZE%5D%2C%20ENET_BUFF_ALIGNMENT)%3B%3CBR%20%2F%3E%3CBR%20%2F%3ESDK_ALIGN(uint8_t%20g_txDataBuff%5BENET_TXBD_NUM%5D%5BENET_TXBUFF_SIZE%5D%2C%20ENET_BUFF_ALIGNMENT)%3B%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%2F*%20MAC%20address%20*%2F%3CBR%20%2F%3E%3CBR%20%2F%3Euint8_t%20g_macAddr%5B6%5D%20%3D%3CBR%20%2F%3E%3CBR%20%2F%3E%7B%200x02%2C%200x12%2C%200x13%2C%200x14%2C%200x15%2C%200x16%20%7D%3B%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%2F*%20ENET%20handle%20*%2F%3CBR%20%2F%3E%3CBR%20%2F%3Estatic%20enet_handle_t%20g_handle%3B%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3Estatic%20void%20BuildTestFrame(uint8_t%20*frame)%3CBR%20%2F%3E%3CBR%20%2F%3E%7B%3CBR%20%2F%3E%3CBR%20%2F%3E%2F*%20Destination%20MAC%20(broadcast)%20*%2F%3CBR%20%2F%3E%3CBR%20%2F%3Efor%20(int%20i%20%3D%200%3B%20i%20%26lt%3B%206%3B%20i%2B%2B)%3CBR%20%2F%3E%3CBR%20%2F%3E%7B%3CBR%20%2F%3E%3CBR%20%2F%3Eframe%5Bi%5D%20%3D%200xFF%3B%3CBR%20%2F%3E%3CBR%20%2F%3E%7D%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%2F*%20Source%20MAC%20*%2F%3CBR%20%2F%3E%3CBR%20%2F%3Ememcpy(%26amp%3Bframe%5B6%5D%2C%20g_macAddr%2C%206)%3B%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%2F*%20EtherType%2FLength%20*%2F%3CBR%20%2F%3E%3CBR%20%2F%3Eframe%5B12%5D%20%3D%200x08%3B%20%2F%2F%20IPv4%3CBR%20%2F%3E%3CBR%20%2F%3Eframe%5B13%5D%20%3D%200x00%3B%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%2F*%20Simple%20payload%20*%2F%3CBR%20%2F%3E%3CBR%20%2F%3Efor%20(int%20i%20%3D%2014%3B%20i%20%26lt%3B%20ENET_DATA_LENGTH%3B%20i%2B%2B)%3CBR%20%2F%3E%3CBR%20%2F%3E%7B%3CBR%20%2F%3E%3CBR%20%2F%3Eframe%5Bi%5D%20%3D%20i%20%25%20256%3B%3CBR%20%2F%3E%3CBR%20%2F%3E%7D%3CBR%20%2F%3E%3CBR%20%2F%3E%7D%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3Evoid%20InitEthernet(void)%3CBR%20%2F%3E%3CBR%20%2F%3E%7B%3CBR%20%2F%3E%3CBR%20%2F%3Eenet_config_t%20config%3B%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%2F*%20Prepare%20buffer%20configuration%20*%2F%3CBR%20%2F%3E%3CBR%20%2F%3Eenet_buffer_config_t%20buffConfig%20%3D%3CBR%20%2F%3E%3CBR%20%2F%3E%7B%3CBR%20%2F%3E%3CBR%20%2F%3EENET_RXBD_NUM%2C%3CBR%20%2F%3E%3CBR%20%2F%3EENET_TXBD_NUM%2C%3CBR%20%2F%3E%3CBR%20%2F%3EENET_RXBUFF_SIZE%2C%3CBR%20%2F%3E%3CBR%20%2F%3EENET_TXBUFF_SIZE%2C%20g_rxBuffDescrip%2C%20g_txBuffDescrip%2C%20%26amp%3Bg_rxDataBuff%5B0%5D%5B0%5D%2C%20%26amp%3Bg_txDataBuff%5B0%5D%5B0%5D%2C%3CBR%20%2F%3E%3CBR%20%2F%3Etrue%2C%3CBR%20%2F%3E%3CBR%20%2F%3Etrue%2C%3CBR%20%2F%3E%3CBR%20%2F%3ENULL%20%7D%3B%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%2F*%20Get%20default%20ENET%20configuration%20*%2F%3CBR%20%2F%3E%3CBR%20%2F%3EENET_GetDefaultConfig(%26amp%3Bconfig)%3B%3CBR%20%2F%3E%3CBR%20%2F%3Econfig.miiMode%20%3D%20kENET_RmiiMode%3B%3CBR%20%2F%3E%3CBR%20%2F%3Econfig.miiSpeed%20%3D%20kENET_MiiSpeed100M%3B%3CBR%20%2F%3E%3CBR%20%2F%3Econfig.miiDuplex%20%3D%20kENET_MiiFullDuplex%3B%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%2F*%20Initialize%20ENET%20*%2F%3CBR%20%2F%3E%3CBR%20%2F%3EENET_Init(EXAMPLE_ENET%2C%20%26amp%3Bg_handle%2C%20%26amp%3Bconfig%2C%20%26amp%3BbuffConfig%2C%20g_macAddr%2C%20EXAMPLE_CLOCK_FREQ)%3B%3CBR%20%2F%3E%3CBR%20%2F%3EENET_ActiveRead(EXAMPLE_ENET)%3B%3CBR%20%2F%3E%3CBR%20%2F%3E%7D%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3Eint%20main(void)%3CBR%20%2F%3E%3CBR%20%2F%3E%7B%3CBR%20%2F%3E%3CBR%20%2F%3Euint8_t%20txFrame%5BENET_DATA_LENGTH%5D%3B%3CBR%20%2F%3E%3CBR%20%2F%3Euint8_t%20rxBuffer%5BENET_RXBUFF_SIZE%5D%3B%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%2F*%20Initialize%20hardware%20*%2F%3CBR%20%2F%3E%3CBR%20%2F%3EBOARD_InitHardware()%3B%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%2F*%20Initialize%20Ethernet%20*%2F%3CBR%20%2F%3E%3CBR%20%2F%3EInitEthernet()%3B%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%2F*%20Build%20test%20frame%20*%2F%3CBR%20%2F%3E%3CBR%20%2F%3EBuildTestFrame(txFrame)%3B%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3Ewhile%20(1)%3CBR%20%2F%3E%3CBR%20%2F%3E%7B%3CBR%20%2F%3E%3CBR%20%2F%3Euint32_t%20frameLength%20%3D%200%3B%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%2F*%20Check%20for%20received%20frames%20*%2F%3CBR%20%2F%3E%3CBR%20%2F%3Eif%20(ENET_GetRxFrameSize(%26amp%3Bg_handle%2C%20%26amp%3BframeLength%2C%200)%20%3D%3D%20kStatus_Success)%3CBR%20%2F%3E%3CBR%20%2F%3E%7B%3CBR%20%2F%3E%3CBR%20%2F%3Eif%20(frameLength%20%26gt%3B%200)%3CBR%20%2F%3E%3CBR%20%2F%3E%7B%3CBR%20%2F%3E%3CBR%20%2F%3E%2F*%20Read%20the%20frame%20*%2F%3CBR%20%2F%3E%3CBR%20%2F%3Eif%20(ENET_ReadFrame(EXAMPLE_ENET%2C%20%26amp%3Bg_handle%2C%20rxBuffer%2C%20frameLength%2C%200%2C%20NULL)%20%3D%3D%20kStatus_Success)%3CBR%20%2F%3E%3CBR%20%2F%3E%7B%3CBR%20%2F%3E%3CBR%20%2F%3E%2F*%20Process%20received%20frame%20here%20*%2F%3CBR%20%2F%3E%3CBR%20%2F%3E%7D%3CBR%20%2F%3E%3CBR%20%2F%3E%7D%3CBR%20%2F%3E%3CBR%20%2F%3E%7D%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%2F*%20Send%20test%20frame%20*%2F%3CBR%20%2F%3E%3CBR%20%2F%3Estatus_t%20ENET_SendFrame(ENET_Type%20*base%2C%20enet_handle_t%20*handle%2C%20const%20uint8_t%20*data%2C%20uint32_t%20length%2C%20uint8_t%20ringId%2C%3CBR%20%2F%3E%3CBR%20%2F%3Ebool%20tsFlag%2C%20void%20*context)%3B%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3EENET_SendFrame(EXAMPLE_ENET%2C%20%26amp%3Bg_handle%2C%20txFrame%2C%20ENET_DATA_LENGTH%2C%200%2C%20false%2C%20NULL)%3B%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%2F*%20Small%20delay%20*%2F%3CBR%20%2F%3E%3CBR%20%2F%3Efor%20(volatile%20int%20i%20%3D%200%3B%20i%20%26lt%3B%201000000%3B%20i%2B%2B)%3B%3CBR%20%2F%3E%3CBR%20%2F%3E%7D%3CBR%20%2F%3E%3CBR%20%2F%3E%7D%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3Ein%20that%20i%20am%20getting%20also%20error%20undefined%20reference%20to%20%60PHY_LinkStatusChange'%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2088894%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Ethernet%20Communication%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2088894%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F234971%22%20target%3D%22_blank%22%3E%40Govind89%3C%2FA%3E%26nbsp%3B%2C%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EThank%20you%20so%20much%20for%20your%20interest%20in%20our%20products%20and%20for%20using%20our%20community.%3C%2FP%3E%0A%3CP%3EI%20think%20the%20project%20you%20imported%20is%20already%20without%20FREERTOS%2C%20if%20you%20want%20more%26nbsp%3B%3CSPAN%3EEthernet%26nbsp%3Bdemo%2C%20you%20can%20check%20by%20import%26nbsp%3B%20SDK%20example.%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22mayliu1_0-1745898661549.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22mayliu1_0-1745898661549.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F335405iEC4F586E1607CB8E%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22mayliu1_0-1745898661549.png%22%20alt%3D%22mayliu1_0-1745898661549.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3EIf%20you%20want%20know%20more%20about%20the%20SDK%20API.%20you%20can%20refer%20to%20the%20document%20%22MCUXpresso%20SDK%20API%20Reference%20Manual%22%3C%2FP%3E%0A%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fmcuxpresso.nxp.com%2Fapi_doc%2Fdev%2F329%2Findex.html%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fmcuxpresso.nxp.com%2Fapi_doc%2Fdev%2F329%2Findex.html%3C%2FA%3E%3C%2FP%3E%0A%3CP%3EWish%20it%20helps%20you.%3CBR%20%2F%3EIf%20you%20still%20have%20question%20about%20it%2C%20please%20kindly%20let%20me%20know.%3C%2FP%3E%0A%3CP%3EWish%20you%20a%20nice%20day!%3C%2FP%3E%0A%3CP%3EBest%20Regards%3CBR%20%2F%3EMayLiu%3C%2FP%3E%3C%2FLINGO-BODY%3E
