Error Failed on chip setup Ep(04). Cannot halt processor. LPCXpresso54608 Board
oscarniño
Pleas somebody can help me I was working fine with my proyect but this error appeared.
The windows that shows the issue reports this:
Error in final launch sequence
Failed to execute MI command:
-target-select extended-remote | crt_emu_cm_redlink -msg-port=51951 -g -mi -2 -pLPC54608J512 -vendor=NXP -reset= -ProbeHandle=1 -CoreIndex=0 -cache=disable -x C:/Users/lapto/mcuxpresso/01/.mcuxpressoide_packages_support/LPC54608J512_support --flash-dir C:/Users/lapto/mcuxpresso/01/.mcuxpressoide_packages_support/LPC54608J512_support/Flash --telnet 3335
Error message from debugger back end:
Remote communication error. Target disconnected.: Success.
I had been working before with this board and It had happened but I fixed it running a program with LPCXpresso but now I can fix it. Please could somebody help me?
converse
Senior Contributor V
