Debug hardfault with MCUXpresso. Vectpc show less information than LPCXpresso?
2,425 次查看
tim99
When experiencing a hardfault when debugging with LPCXpresso, looking at vectpc would give you useful hints on what had happened. Screenshot below is from a hardfault in LPCXpresso
In MCUXpresso this information does not apare:
How do I find the same information in MCUXpresso?
标记 (2)
1,883 次查看
lpcxpresso_supp
We'll be implementing a fix for issue with the (LinkServer-specific) "vectpc" functionality in the next IDE release.
In the meantime, and also if you try using a different probe type, then this blog article may be of interest...
Debugging ARM Cortex-M Hard Faults with GDB Custom Command | MCU on Eclipse
Basically this mimics exactly what the IDE is doing with "vectpc".
MCUXpresso IDE Support
1,883 次查看
lpcxpresso_supp
Thank you for the report - you appear to be correct.  We'll investigate.
1,883 次查看
tomaszziajko
Any luck in finding the problem? Additional information would be very helpful in hardfault tracking, and moving whole project to legacy IDE does not seem reasonable....
