Cannot open project: Processor [...] version is not supported by current version of the tool
15,171件の閲覧回数
robleitner
Hi all,
I started to use MCUXpresso yesterday for the first time, version: MCUXpresso IDE v11.7.0 [Build 9198] [2023-01-17]
I successfully set up a project for my IMXRT1170-EVK and began using the tool to configure peripherals, clocks etc. All went well, no problems.
I saved the project, closed MCUXpresso and shut down for the night.
Today I have opened it again while the project still exists (dir structures, c and h files etc), but when I select my project in the drop-down list in the top right of the main window, I get the error:
Processor MIMXRT1176xxxx, ksdk_0 version is not supported by current version of the tool
I don't know why this is happening, and can't figure out how to solve it. Nothing has changed since last night: I haven't updated anything, or changed any MCUXpresso settings.
I went to the download manager and made sure my EVK and processor were checked, then re-downloaded (see screenshot). Everything downloaded successfully. And yet still I have the same error when I try to open my project.
How can I select my project, and why would anything have changed overnight when it was all working fine yesterday?
Many thanks
Rob
15,144件の閲覧回数
Lukas_Heczko
Hi Rob,
it seems you are using MIMXRT1170-EVKB instead of MIMXRT1170-EVK - I'm able to reproduce the problem when creating project with the "B" board.
To fix the problem please use attached patch:
From the patch, please copy the "MIMXRT1170-EVKB" folder from the "boards" subfolder into "c:\ProgramData\NXP\mcu_data_v13\boards\".
After that, you should be able to open again your project in the MCUXpresso IDE.
We are sorry for this inconvenience, it will be soon fixed also in our production data.
Lukas
6 返答(返信)
15,145件の閲覧回数
Lukas_Heczko
Hi Rob,
Lukas
15,133件の閲覧回数
robleitner
Thanks for the very fast reply, Lukas. This solved the problem immediately. Much appreciated.
15,136件の閲覧回数
liborukropec
Hi Rob,
as you use MacOS, the folder should be in your case here (in your $HOME):
$HOME/.nxp/mcu_data_v13/boards
Libor
15,133件の閲覧回数
robleitner
Ah thanks for this I was lost until I saw your post.
15,161件の閲覧回数
liborukropec
Hi Rob,
could you paste here the <workspace>/.metadata/.log file here? May be the last entries for the last execution should be sufficient.
Libor
15,156件の閲覧回数
robleitner
!SESSION 2023-03-28 14:11:46.807 -----------------------------------------------
eclipse.buildId=unknown
java.version=11.0.17
java.vendor=Eclipse Adoptium
BootLoader constants: OS=macosx, ARCH=x86_64, WS=cocoa, NL=en_US
Framework arguments: -keyring /Users/robl/.eclipse_keyring
Command-line arguments: -os macosx -ws cocoa -arch x86_64 -keyring /Users/robl/.eclipse_keyring
!ENTRY com.nxp.mcuxpresso.core.datamodels 1 0 2023-03-28 14:12:18.573
!MESSAGE Recreating part support. No part support available.
!ENTRY org.eclipse.equinox.p2.engine 4 4 2023-03-28 14:29:38.046
!MESSAGE An error occurred while collecting items to be installed
!SUBENTRY 1 org.eclipse.equinox.p2.engine 4 0 2023-03-28 14:29:38.046
!MESSAGE session context was:(profile=DefaultProfile, phase=org.eclipse.equinox.internal.p2.engine.phases.Collect, operand=, action=).
!SUBENTRY 1 org.eclipse.equinox.p2.artifact.repository 4 0 2023-03-28 14:29:38.046
!MESSAGE Problems downloading artifact: osgi.bundle,com.nxp.mcuxpresso.sdk.sdk_2.x_mimxrt1170-evkb,2.13.1.201911251446.
!STACK 0
java.io.EOFException: Unexpected end of ZLIB input stream
at java.base/java.util.zip.InflaterInputStream.fill(Unknown Source)
at java.base/java.util.zip.InflaterInputStream.read(Unknown Source)
at java.base/java.util.zip.ZipInputStream.read(Unknown Source)
at java.base/java.util.jar.JarInputStream.read(Unknown Source)
at java.base/java.util.zip.ZipInputStream.closeEntry(Unknown Source)
at java.base/java.util.zip.ZipInputStream.getNextEntry(Unknown Source)
at java.base/java.util.jar.JarInputStream.getNextEntry(Unknown Source)
at java.base/java.util.jar.JarInputStream.getNextJarEntry(Unknown Source)
at org.eclipse.osgi.internal.signedcontent.SignedContentFromBundleFile.getSignedEntries(SignedContentFromBundleFile.java:225)
at org.eclipse.osgi.internal.signedcontent.SignedContentFromBundleFile.<init>(SignedContentFromBundleFile.java:193)
at org.eclipse.osgi.internal.signedcontent.SignedBundleHook.getSignedContent(SignedBundleHook.java:170)
at org.eclipse.equinox.internal.p2.artifact.repository.SignatureVerifier.verifyContent(SignatureVerifier.java:84)
at org.eclipse.equinox.internal.p2.artifact.repository.SignatureVerifier.verify(SignatureVerifier.java:66)
at org.eclipse.equinox.internal.p2.artifact.repository.SignatureVerifier.close(SignatureVerifier.java:115)
at org.eclipse.equinox.internal.provisional.p2.artifact.repository.processing.ProcessingStep.close(ProcessingStep.java:93)
at org.eclipse.equinox.internal.p2.artifact.processors.checksum.MessageDigestProcessingStep.close(MessageDigestProcessingStep.java:58)
at org.eclipse.equinox.internal.p2.artifact.repository.simple.SimpleArtifactRepository.reportStatus(SimpleArtifactRepository.java:1281)
at org.eclipse.equinox.internal.p2.artifact.repository.simple.SimpleArtifactRepository.downloadArtifact(SimpleArtifactRepository.java:673)
at org.eclipse.equinox.internal.p2.artifact.repository.simple.SimpleArtifactRepository.getArtifact(SimpleArtifactRepository.java:804)
at org.eclipse.equinox.internal.p2.artifact.repository.MirrorRequest.getArtifact(MirrorRequest.java:329)
at org.eclipse.equinox.internal.p2.artifact.repository.MirrorRequest.transferSingle(MirrorRequest.java:299)
at org.eclipse.equinox.internal.p2.artifact.repository.MirrorRequest.transfer(MirrorRequest.java:232)
at org.eclipse.equinox.internal.p2.artifact.repository.MirrorRequest.perform(MirrorRequest.java:162)
at org.eclipse.equinox.internal.p2.artifact.repository.simple.SimpleArtifactRepository.getArtifact(SimpleArtifactRepository.java:787)
at org.eclipse.equinox.internal.p2.artifact.repository.simple.DownloadJob.run(DownloadJob.java:64)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:63)
!ENTRY com.nxp.mcuxpresso.core.datamodels 1 0 2023-03-28 14:40:32.245
!MESSAGE The device 'MIMXRT1062xxxxA' (version='1.0.0') from SDK 'SDK_2.x_MIMXRT1060-EVKB' (version='2.13.1', build='epluginsite617 2023-03-27') will be installed.
!ENTRY com.nxp.mcuxpresso.core.datamodels 1 0 2023-03-28 14:40:34.569
!MESSAGE The device 'MIMXRT1176xxxxx' (version='1.0.0') from SDK 'SDK_2.x_MIMXRT1170-EVKB' (version='2.13.1', build='epluginsite617 2023-03-27') will be installed.
!ENTRY com.nxp.mcuxpresso.core.datamodels 1 0 2023-03-28 14:40:35.424
!ENTRY com.nxp.mcuxpresso.core.datamodels 1 0 2023-03-28 14:40:36.422
!ENTRY org.eclipse.cdt.core 1 0 2023-03-28 14:58:57.986
!MESSAGE Indexed 'MIMXRT1176_Project' (0 sources, 0 headers) in 0.002 sec: 0 declarations; 0 references; 0 unresolved inclusions; 0 syntax errors; 0 unresolved names (0%)
!ENTRY com.nxp.swtools.provider.processors 4 0 2023-03-28 15:55:13.091
!MESSAGE [DATA] Unable to download board data:MIMXRT1170-EVKB
!ENTRY com.nxp.swtools.provider.processors 4 0 2023-03-28 15:55:21.632
!ENTRY com.nxp.swtools.periphs.gui.view 4 0 2023-03-28 15:57:13.011
!MESSAGE [TOOL] Could not find any matching component for type lpspi_cmsis
!ENTRY com.nxp.swtools.periphs.gui.view 4 0 2023-03-28 15:57:13.025
!MESSAGE [TOOL] Could not find any matching component for type igpio_adapter
!ENTRY com.nxp.swtools.periphs.gui.view 4 0 2023-03-28 15:57:13.037
!MESSAGE [TOOL] Could not find any matching component for type lpuart_cmsis
!ENTRY com.nxp.swtools.periphs.gui.view 4 0 2023-03-28 15:57:13.050
!MESSAGE [TOOL] Could not find any matching component for type lpi2c_cmsis
!ENTRY com.nxp.swtools.periphs.gui.view 4 0 2023-03-28 15:57:17.801
!MESSAGE [TOOL] Could not find any matching component for type lwip
!ENTRY com.nxp.swtools.periphs.gui.view 4 0 2023-03-28 15:57:17.849
!MESSAGE [TOOL] Could not find any matching component for type littlefs
!ENTRY com.nxp.swtools.periphs.gui.view 4 0 2023-03-28 15:57:17.861
!MESSAGE [TOOL] Could not find any matching component for type freemaster
!ENTRY com.nxp.swtools.periphs.gui.view 4 0 2023-03-28 15:57:17.874
!MESSAGE [TOOL] Could not find any matching component for type camera
!ENTRY com.nxp.swtools.periphs.gui.view 4 0 2023-03-28 15:57:17.886
!MESSAGE [TOOL] Could not find any matching component for type fatfs
!ENTRY com.nxp.swtools.periphs.gui.view 4 0 2023-03-28 15:57:17.903
!ENTRY com.nxp.swtools.periphs.gui.view 4 0 2023-03-28 16:05:17.422
!MESSAGE [TOOL] Could not find any matching component for type mipi_dsi_split
!ENTRY com.nxp.swtools.periphs.gui.view 4 0 2023-03-28 16:05:17.427
!MESSAGE [TOOL] Could not find any matching component for type fcb
!ENTRY com.nxp.swtools.periphs.gui.view 4 0 2023-03-28 16:05:17.439
!MESSAGE [TOOL] Could not find any matching component for type rtwdog
!ENTRY com.nxp.swtools.periphs.gui.view 4 0 2023-03-28 16:05:17.460
!MESSAGE [TOOL] Could not find any matching component for type pwm
!ENTRY com.nxp.swtools.periphs.gui.view 4 0 2023-03-28 16:05:17.473
!MESSAGE [TOOL] Could not find any matching component for type dac12
!ENTRY com.nxp.swtools.periphs.gui.view 4 0 2023-03-28 16:05:17.485
!MESSAGE [TOOL] Could not find any matching component for type spdif
!ENTRY com.nxp.swtools.periphs.gui.view 4 0 2023-03-28 16:05:17.505
!ENTRY com.nxp.swtools.periphs.gui.view 4 0 2023-03-28 16:05:17.526
!MESSAGE [TOOL] Could not find any matching component for type flexio_i2s
!ENTRY com.nxp.swtools.periphs.gui.view 4 0 2023-03-28 16:05:17.547
!MESSAGE [TOOL] Could not find any matching component for type flexio_spi
!ENTRY com.nxp.swtools.periphs.gui.view 4 0 2023-03-28 16:05:17.559
!MESSAGE [TOOL] Could not find any matching component for type cdog
!ENTRY com.nxp.swtools.periphs.gui.view 4 0 2023-03-28 16:05:17.572
!MESSAGE [TOOL] Could not find any matching component for type snvs_hp
!ENTRY com.nxp.swtools.periphs.gui.view 4 0 2023-03-28 16:05:17.627
!MESSAGE [TOOL] Could not find any matching component for type sai
!ENTRY com.nxp.swtools.periphs.gui.view 4 0 2023-03-28 16:05:17.649
!MESSAGE [TOOL] Could not find any matching component for type pit
!ENTRY com.nxp.swtools.periphs.gui.view 4 0 2023-03-28 16:05:17.670
!MESSAGE [TOOL] Could not find any matching component for type enc
!ENTRY com.nxp.swtools.periphs.gui.view 4 0 2023-03-28 16:05:17.682
!MESSAGE [TOOL] Could not find any matching component for type elcdif
!ENTRY com.nxp.swtools.periphs.gui.view 4 0 2023-03-28 16:05:17.702
!MESSAGE [TOOL] Could not find any matching component for type edma
!ENTRY com.nxp.swtools.periphs.gui.view 4 0 2023-03-28 16:05:17.735
!MESSAGE [TOOL] Could not find any matching component for type flexspi
!ENTRY com.nxp.swtools.periphs.gui.view 4 0 2023-03-28 16:05:17.756
!MESSAGE [TOOL] Could not find any matching component for type semc
!ENTRY com.nxp.swtools.periphs.gui.view 4 0 2023-03-28 16:05:17.794
!MESSAGE [TOOL] Could not find any matching component for type snvs_lp
!ENTRY com.nxp.swtools.periphs.gui.view 4 0 2023-03-28 16:05:17.815
!MESSAGE [TOOL] Could not find any matching component for type flexio_uart
!ENTRY com.nxp.swtools.periphs.gui.view 4 0 2023-03-28 16:05:17.827
!MESSAGE [TOOL] Could not find any matching component for type wdog01
!ENTRY com.nxp.swtools.periphs.gui.view 4 0 2023-03-28 16:05:17.839
!MESSAGE [TOOL] Could not find any matching component for type lcdifv2
!ENTRY com.nxp.swtools.periphs.gui.view 4 0 2023-03-28 16:05:17.851
!MESSAGE [TOOL] Could not find any matching component for type acmp
!ENTRY com.nxp.swtools.periphs.gui.view 4 0 2023-03-28 16:05:17.863
!MESSAGE [TOOL] Could not find any matching component for type mu
!ENTRY com.nxp.swtools.periphs.gui.view 4 0 2023-03-28 16:05:17.875
!MESSAGE [TOOL] Could not find any matching component for type pxp
!ENTRY com.nxp.swtools.periphs.gui.view 4 0 2023-03-28 16:05:17.887
!MESSAGE [TOOL] Could not find any matching component for type kpp
!ENTRY com.nxp.swtools.periphs.gui.view 4 0 2023-03-28 16:05:17.907
!MESSAGE [TOOL] Could not find any matching component for type flexio_camera
!ENTRY com.nxp.swtools.periphs.gui.view 4 0 2023-03-28 16:05:17.937
!ENTRY com.nxp.swtools.periphs.gui.view 4 0 2023-03-28 16:05:17.949
!MESSAGE [TOOL] Could not find any matching component for type flexio_mculcd
!ENTRY com.nxp.swtools.periphs.gui.view 4 0 2023-03-28 16:05:17.961
!MESSAGE [TOOL] Could not find any matching component for type adc_etc
!ENTRY com.nxp.swtools.periphs.gui.view 4 0 2023-03-28 16:05:17.982
!MESSAGE [TOOL] Could not find any matching component for type flexio_i2c_master
!ENTRY com.nxp.swtools.periphs.gui.view 4 0 2023-03-28 16:05:18.011
!MESSAGE [TOOL] Could not find any matching component for type csi
!ENTRY com.nxp.swtools.periphs.gui.view 4 0 2023-03-28 16:05:18.059
!MESSAGE [TOOL] Could not find any matching component for type flexcan
!ENTRY com.nxp.swtools.periphs.gui.view 4 0 2023-03-28 16:05:18.071
!MESSAGE [TOOL] Could not find any matching component for type aoi
!ENTRY com.nxp.swtools.periphs.gui.view 4 0 2023-03-28 16:05:18.101
!MESSAGE [TOOL] Could not find any matching component for type lpadc
!ENTRY com.nxp.swtools.periphs.gui.view 4 0 2023-03-28 16:05:18.113
!MESSAGE [TOOL] Could not find any matching component for type ewm
!ENTRY com.nxp.swtools.periphs.gui.view 4 0 2023-03-28 16:05:18.125
!MESSAGE [TOOL] Could not find any matching component for type qtmr
!ENTRY com.nxp.swtools.periphs.gui.view 4 0 2023-03-28 16:05:18.155
!ENTRY com.nxp.swtools.periphs.gui.view 4 0 2023-03-28 16:05:18.168
!ENTRY com.nxp.swtools.periphs.gui.view 4 0 2023-03-28 16:05:18.300
!ENTRY com.nxp.swtools.periphs.gui.view 4 0 2023-03-28 16:05:38.297
!ENTRY com.nxp.swtools.periphs.gui.view 4 0 2023-03-28 16:05:38.327
!ENTRY com.nxp.swtools.periphs.gui.view 4 0 2023-03-28 16:05:38.339
!ENTRY com.nxp.swtools.periphs.gui.view 4 0 2023-03-28 16:05:38.351
!ENTRY com.nxp.swtools.periphs.gui.view 4 0 2023-03-28 16:05:38.363
!ENTRY com.nxp.swtools.periphs.gui.view 4 0 2023-03-28 16:05:38.378
!ENTRY org.eclipse.help.base 2 0 2023-03-28 16:26:03.408
!MESSAGE Unable to consume Lucene index from bundle 'org.eclipse.wst.dtdeditor.doc.user_1.1.0.v201903222120 [618]'. The index should be rebuilt with Lucene 8.4.1
!ENTRY org.eclipse.help.base 2 0 2023-03-28 16:26:03.426
!MESSAGE Unable to consume Lucene index from bundle 'org.eclipse.wst.xmleditor.doc.user_1.1.0.v201903222120 [635]'. The index should be rebuilt with Lucene 8.4.1
!ENTRY org.eclipse.help.base 2 0 2023-03-28 16:26:03.427
!MESSAGE Unable to consume Lucene index from bundle 'org.eclipse.wst.xsdeditor.doc.user_1.0.800.v201903222120 [638]'. The index should be rebuilt with Lucene 8.4.1
!MESSAGE Unable to consume Lucene index from bundle 'org.eclipse.wst.sse.doc.user_1.2.0.v201903222120 [621]'. The index should be rebuilt with Lucene 8.4.1
!ENTRY org.eclipse.help.base 4 4 2023-03-28 16:26:07.222
!MESSAGE Help documentation could not be indexed completely.
!SUBENTRY 1 org.eclipse.help.base 4 4 2023-03-28 16:26:07.222
!MESSAGE Help document /com.nxp.gnudocs/standards.html cannot be opened.
!MESSAGE Help document /com.nxp.gnudocs/gdbint/index.html cannot be opened.
!ENTRY com.nxp.swtools.utils.scripting.internal 4 0 2023-03-28 16:48:44.608
!MESSAGE Both feature units of the microphone and speaker must be defined in the audio control interface.
!ENTRY com.nxp.swtools.utils.scripting.internal 4 0 2023-03-28 16:48:44.610
!MESSAGE No endpoint suitable for USB audio unified stream, Audio_stream_setting in Audio_unified interface requires output isochronous endpoint with usage:data.
!MESSAGE No endpoint suitable for USB audio unified feedback, Audio_stream_setting in Audio_unified interface requires input isochronous endpoint with usage:feedback.
!ENTRY com.nxp.swtools.utils.scripting.internal 4 0 2023-03-28 16:49:19.239
!ENTRY com.nxp.swtools.utils.scripting.internal 4 0 2023-03-28 16:49:19.240
!ENTRY com.nxp.swtools.utils.scripting.internal 4 0 2023-03-28 16:49:24.550
!ENTRY com.nxp.swtools.utils.scripting.internal 4 0 2023-03-28 16:49:24.551
!ENTRY com.nxp.swtools.utils.scripting.internal 4 0 2023-03-28 16:49:24.552
!ENTRY com.nxp.swtools.utils.scripting.internal 4 0 2023-03-28 16:49:40.606
!ENTRY com.nxp.swtools.utils.scripting.internal 4 0 2023-03-28 16:49:40.607
!ENTRY com.nxp.swtools.utils.scripting.internal 4 0 2023-03-28 16:49:58.147
!ENTRY com.nxp.swtools.utils.scripting.internal 4 0 2023-03-28 16:49:58.148
!ENTRY com.nxp.swtools.utils.scripting.internal 4 0 2023-03-28 16:49:58.149
!ENTRY com.nxp.swtools.utils.scripting.internal 4 0 2023-03-28 16:50:10.088
!ENTRY com.nxp.swtools.utils.scripting.internal 4 0 2023-03-28 16:50:10.089
!ENTRY com.nxp.swtools.utils.scripting.internal 4 0 2023-03-28 16:50:10.090
!ENTRY com.nxp.swtools.utils.scripting.internal 4 0 2023-03-28 16:51:41.343
!ENTRY com.nxp.swtools.utils.scripting.internal 4 0 2023-03-28 16:51:41.344
!ENTRY com.nxp.swtools.utils.scripting.internal 4 0 2023-03-28 16:51:41.345
!ENTRY com.nxp.swtools.utils.scripting.internal 4 0 2023-03-28 16:51:42.889
!ENTRY com.nxp.swtools.utils.scripting.internal 4 0 2023-03-28 16:51:42.890
!ENTRY com.nxp.swtools.periphs.gui.view 4 0 2023-03-28 20:39:35.098
!ENTRY com.nxp.swtools.periphs.gui.view 4 0 2023-03-28 20:39:35.134
!ENTRY com.nxp.swtools.periphs.gui.view 4 0 2023-03-28 20:39:35.151
!ENTRY com.nxp.swtools.periphs.gui.view 4 0 2023-03-28 20:39:35.169
!ENTRY com.nxp.swtools.periphs.gui.view 4 0 2023-03-28 20:39:35.186
!ENTRY com.nxp.swtools.periphs.gui.view 4 0 2023-03-28 20:39:35.207
!ENTRY com.nxp.swtools.mux.view 4 0 2023-03-28 21:13:47.221
!MESSAGE waitUntilUpdated(): project.waitUntilValidated() failed
!ENTRY com.nxp.swtools.utils 4 0 2023-03-28 21:13:47.224
!MESSAGE saveConfiguration: waitUntilUpdated failed for tool: Pins
!ENTRY org.eclipse.oomph.p2.core 4 0 2023-03-28 21:14:21.058
!MESSAGE FrameworkEvent ERROR
!STACK 0
org.osgi.framework.BundleException: Exception in org.eclipse.oomph.p2.internal.core.P2CorePlugin$Implementation.stop() of bundle org.eclipse.oomph.p2.core.
at org.eclipse.osgi.internal.framework.BundleContextImpl.stop(BundleContextImpl.java:895)
at org.eclipse.osgi.internal.framework.EquinoxBundle.stopWorker0(EquinoxBundle.java:1046)
at org.eclipse.osgi.internal.framework.EquinoxBundle$EquinoxModule.stopWorker(EquinoxBundle.java:376)
at org.eclipse.osgi.container.Module.doStop(Module.java:660)
at org.eclipse.osgi.container.Module.stop(Module.java:521)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.decStartLevel(ModuleContainer.java:1888)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.doContainerStartLevel(ModuleContainer.java:1763)
at org.eclipse.osgi.container.SystemModule.stopWorker(SystemModule.java:275)
at org.eclipse.osgi.internal.framework.EquinoxBundle$SystemBundle$EquinoxSystemModule.stopWorker(EquinoxBundle.java:208)
at org.eclipse.osgi.container.SystemModule.stop(SystemModule.java:207)
at org.eclipse.osgi.internal.framework.EquinoxBundle$SystemBundle$EquinoxSystemModule$1.run(EquinoxBundle.java:226)
at java.base/java.lang.Thread.run(Unknown Source)
Caused by: org.eclipse.oomph.p2.P2Exception: Provisioning agent could not be loaded from /Users/robl/.p2
at org.eclipse.oomph.p2.internal.core.AgentImpl.getOrCreateProvisioningAgent(AgentImpl.java:1310)
at org.eclipse.oomph.p2.internal.core.AgentImpl.getProvisioningAgent(AgentImpl.java:688)
at org.eclipse.oomph.p2.internal.core.AgentImpl.getProfileRegistry(AgentImpl.java:332)
at org.eclipse.oomph.p2.internal.core.AgentImpl$1.initializeFirstTime(AgentImpl.java:140)
at org.eclipse.oomph.p2.internal.core.PersistentMap.load(PersistentMap.java:113)
at org.eclipse.oomph.p2.internal.core.AgentImpl.<init>(AgentImpl.java:187)
at org.eclipse.oomph.p2.internal.core.AgentManagerImpl$1.createElement(AgentManagerImpl.java:92)
at org.eclipse.oomph.p2.internal.core.AgentManagerImpl$1.createElement(AgentManagerImpl.java:1)
at org.eclipse.oomph.p2.internal.core.PersistentMap.addElement(PersistentMap.java:153)
at org.eclipse.oomph.p2.internal.core.AgentManagerImpl.addAgent(AgentManagerImpl.java:228)
at org.eclipse.oomph.p2.internal.core.AgentManagerImpl$1.initializeFirstTime(AgentManagerImpl.java:105)
at org.eclipse.oomph.p2.internal.core.AgentManagerImpl.<init>(AgentManagerImpl.java:142)
at org.eclipse.oomph.p2.internal.core.AgentManagerImpl.<init>(AgentManagerImpl.java:64)
at org.eclipse.oomph.p2.core.P2Util.getAgentManager(P2Util.java:97)
at org.eclipse.oomph.p2.internal.core.P2CorePlugin$Implementation.stop(P2CorePlugin.java:177)
at org.eclipse.osgi.internal.framework.BundleContextImpl$3.run(BundleContextImpl.java:875)
at org.eclipse.osgi.internal.framework.BundleContextImpl$3.run(BundleContextImpl.java:1)
at java.base/java.security.AccessController.doPrivileged(Native Method)
at org.eclipse.osgi.internal.framework.BundleContextImpl.stop(BundleContextImpl.java:867)
... 13 more
Root exception:
!SESSION 2023-03-29 09:44:29.997 -----------------------------------------------
!ENTRY com.nxp.swtools.utils 4 0 2023-03-29 09:44:55.045
!MESSAGE Error during opening configuration MIMXRT1176_Project.mex:
Processor MIMXRT1176xxxxx, ksdk2_0 version is not supported by current version of the tool
!ENTRY com.nxp.swtools.utils 4 0 2023-03-29 09:47:43.880
!ENTRY com.nxp.swtools.utils 4 0 2023-03-29 09:48:04.231
!ENTRY com.nxp.swtools.utils 4 0 2023-03-29 09:49:25.830
!ENTRY com.nxp.swtools.utils 4 0 2023-03-29 09:53:44.516
!ENTRY com.nxp.swtools.utils 4 0 2023-03-29 10:00:34.166
!ENTRY com.nxp.swtools.utils 4 0 2023-03-29 10:02:40.902
!ENTRY com.nxp.swtools.utils 4 0 2023-03-29 10:04:32.412
