Activation on Ubuntu?
1,518 次查看
semiliranda
Sorry for publishing in a wrong place, but I did not find one, dedicated to LPCXpresso.
I lost a free license and cannot activate LPCXpresso again. When I close the window "Create Serial Number and Register (Free Edition)", I get an error message:
/usr/share/NXPLPCXpresso/LPCXpresso.sib (Permission denied)
      at java.io.FileOutputStream.open0(Native Method)
      at java.io.FileOutputStream.open(FileOutputStream.java:270)
      at java.io.FileOutputStream.<init>(FileOutputStream.java:213)
      at java.io.FileOutputStream.<init>(FileOutputStream.java:162)
      at com.crt.lpcxpresso.brand.lpcxhandler.SystemInfoBlock.store(SystemInfoBlock.java:295)
      at com.crt.lpcxpresso.brand.lpcxhandler.LPCXLicense.storeCurrent(LPCXLicense.java:275)
      at com.crt.lpcxpresso.brand.lpcxhandler.LPCXLicenseHandler.storeCurrent(LPCXLicenseHandler.java:106)
      at com.crt.lpcxpresso.brand.activation.free.FreeLicenseHandler.registerHandler(FreeLicenseHandler.java:232)
      at com.crt.lpcxpresso.brand.activation.free.FreeLicenseHandler.execute(FreeLicenseHandler.java:138)
      at org.eclipse.ui.internal.handlers.HandlerProxy.execute(HandlerProxy.java:295)
      at org.eclipse.ui.internal.handlers.E4HandlerProxy.execute(E4HandlerProxy.java:90)
      at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
      at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
      at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
      at java.lang.reflect.Method.invoke(Method.java:497)
      at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:56)
      at org.eclipse.e4.core.internal.di.InjectorImpl.invokeUsingClass(InjectorImpl.java:252)
      at org.eclipse.e4.core.internal.di.InjectorImpl.invoke(InjectorImpl.java:234)
      at org.eclipse.e4.core.contexts.ContextInjectionFactory.invoke(ContextInjectionFactory.java:132)
      at org.eclipse.e4.core.commands.internal.HandlerServiceHandler.execute(HandlerServiceHandler.java:152)
      at org.eclipse.core.commands.Command.executeWithChecks(Command.java:493)
      at org.eclipse.core.commands.ParameterizedCommand.executeWithChecks(ParameterizedCommand.java:486)
      at org.eclipse.e4.core.commands.internal.HandlerServiceImpl.executeHandler(HandlerServiceImpl.java:210)
      at org.eclipse.e4.ui.workbench.renderers.swt.HandledContributionItem.executeItem(HandledContributionItem.java:799)
      at org.eclipse.e4.ui.workbench.renderers.swt.HandledContributionItem.handleWidgetSelection(HandledContributionItem.java:675)
      at org.eclipse.e4.ui.workbench.renderers.swt.HandledContributionItem.access$7(HandledContributionItem.java:659)
      at org.eclipse.e4.ui.workbench.renderers.swt.HandledContributionItem$4.handleEvent(HandledContributionItem.java:592)
      at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:84)
      at org.eclipse.swt.widgets.Display.sendEvent(Display.java:4481)
      at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1329)
      at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:3819)
      at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3430)
      at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$4.run(PartRenderingEngine.java:1127)
      at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:337)
      at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:1018)
      at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:156)
      at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:694)
      at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:606)
      at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:150)
      at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:139)
      at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
      at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:134)
      at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:104)
      at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:380)
      at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:235)
      at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:669)
      at org.eclipse.equinox.launcher.Main.basicRun(Main.java:608)
      at org.eclipse.equinox.launcher.Main.run(Main.java:1515)
Actually, my instance pf LPCXpresso was already registered, but one day the license suddenly disappeared. I try to use the Activation Key for the current serial number, saved in my User Account on NXP site, but get an error message: "No license to activate."
Re-installation did not help. Could you help me please?
  • Add to Phrasebook
    • No word lists for English -> Russian...
    • Create a new word list...
  • Copy
标记 (2)
1,464 次查看
ZhangJennie
HI
LPCXpresso IDE is no longer remommended. If you can, please use MCUXpresso IDE instead.
MCUXpresso IDE|Eclipse-based Integrated Development Environment (IDE) | NXP
Anyway, general information on activating LPCXpresso IDE can be found at:
https://community.nxp.com/message/630539
Jun Zhang
