ADC Data Average Using Timer
1,439 次查看
Govind89
i am using km34z256xxx7 and i am using mcuxpresso sdk . I want to use a timer and an ADC interrupt handler. In this, I want to read ADC data every 1 second using an interrupt-based approach. When the timer starts, it will trigger the ADC to read and store the data in a buffer. Once the timer reaches 1 second, it will stop, and I will calculate the average of the ADC data in the buffer. After completing the average calculation, the timer will restart, and the process will repeat.
 #mcuxpressoide #nxp
1,408 次查看
Celeste_Liu
Hello @Govind89 ,
Thanks for your post. This question is the repeat post, I will answer you in your private case which have the same question.
Any updated information, please reply me in that case. Thanks for your understanding.
Celeste
