boot loader
boot loader
chenq
how to use freemaster software to download the firmware into the S12 mcu? Is there any document?
ZhangJennie
Hi David,
There is no CAN bootloader for HCS12, only I know is CAN bootloader for S12Z
https://www.nxp.com/docs/en/application-note/AN4723.pdf
https://www.nxp.com/docs/en/application-note-software/AN4723_SW.zip
I would suggest your combine AN4258 with it.
More information, refer this article:
https://community.nxp.com/docs/DOC-102620
Jennie Zhang
ZhangJennie
Hi David,
Freemaster is debug monitor and data visualization tool. It is for displaying variables changing on an oscillooscope-like display. We don't use it as bootloader.
If you want to use bootloader program flash via SCI, you can refer
https://www.nxp.com/docs/en/application-note/AN2548.pdf
or
https://www.nxp.com/docs/en/application-note/AN3275.pdf
or
https://www.nxp.com/docs/en/application-note/AN4258.pdf
You can also search out related bootloader project from nxp web site
Jennie Zhang
chenq
hi,lady Zhang
Thanks for your reply.
Recently I need write a bootloader program to upgrade the firmware via CAN not SCI.
acoording to the document AN4860 , MC56F827XX family is supported to write flash via FreeMaster,but not S12 family.
Have a nice day,
David Chan
ZhangJennie
Hi David,
Jennie Zhang
