Wire ACK Fault in DAP access
25,441 次查看
saad_saeed
I have just recently installed McuExpresso 10.3.0. Previously I was using McuExpresso 10.0.2. When I downloaded the latest SDK for FRDM K64 and tried to debug a demo example, I got this error.
Failed on connect: Nn(05). Wire ACK Fault in DAP access
I dont understand what is wrong. Kindly, help me with this.
Saad.
标记 (2)
18 回复数
22,223 次查看
Krish403
We are also having the same problem as CBI.
Is your problem resolved? If so please post it here.
Thank you very much.
24,452 次查看
ZhangJennie
Hi Saad,
First, we need identify this issue is only on one project or a common issue for all project.
- please create a NEW project in a NEW workspace, see how the connection works.
- please test your project in a NEW workspace, how does it work?
If both of above can't fix the issue, I suggest you update your K64 firmware.
OpenSDA Serial and Debug Adapter|NXP
Jun Zhang
24,452 次查看
saad_saeed
I have done what you said to me.
Now I am getting the following error
15: Target error from Commit Flash write
Cannot halt processor.
Debugging context: frdmk64f_lwip_tcpecho_bm Debug
24,452 次查看
saad_saeed
The issue has been resolved.:)
7,640 次查看
MNM
Iam also facing the same issue when iam trying to connect to IMXRT1064 using SWD i keep getting error : Wire Ack Fault in DAP Access. Kindly help me with this.
24,450 次查看
bjemt
I have the same problem.
  • How did you solve the problem in the end?
24,450 次查看
bjemt
I found the problem was that the MCP was locked, It's a simple way of unlocking a MCU in MCUXpresso that I thought I'd share with other novices so they can get going again easily:
Step 1: Open the GUI Flash tool
Step 2: Choose Resurrect locked...
Step 3: Hit Run.
In a moment the MCU will be unlocked and ready for more programming action!
18,164 次查看
cowles
In mcuxpressoide-11.7.1_9221 there is no such thing as "Resurrect locked ..."
18,081 次查看
ErichStyger
Specialist I
As the screenshot indicates:
"Resurrect locked Kinetis device": this feature exists for Kinetis devices only.
If you happen to have an LPC: try erasing the flash from the bootloader, or you might use a recover script like described here: https://mcuoneclipse.com/2023/07/25/linkserver-scripting-and-how-to-recover-mcus-with-a-script/
17,987 次查看
mrichardson
Tried the script....no dice.  But thanks for pointing me in that direction.
标记 (1)
17,966 次查看
ErichStyger
Specialist I
Thanks for trying. It worked in several cases on my side. Maybe indeed your device is permanently bricked.
24,403 次查看
Guntash
Worked for me as well. Thanks man!
24,450 次查看
bjemt
24,450 次查看
ZhangJennie
Good to know it. You are welcome!
Jun Zhang
23,670 次查看
CBI
The Problem has not been solved for me... I search a solution !!!
23,678 次查看
CBI
Hi all,
I am young in this forum
Meanwhile When I perform this
I have the following result
The detail infos in the console:
Executing flash operation 'Resurrect locked Kinetis device' (Resurrect locked Kinetis device) - Mon Mar 01 16:30:41 CET 2021
Checking MCU info...
Scanning for targets...
Executing flash action...
MCUXpresso IDE RedlinkMulti Driver v11.3 (Jan 11 2021 16:41:13 - crt_emu_cm_redlink.exe build 9)
( 0) Reading remote configuration
Wc(03). No cache support.
Found chip XML file in C:/Users/binard/Documents/MCUXpressoIDE_11.3.0_5222/workspace/frdmkw38_heart_rate_sensor_freertos/Debug\MKW38A512xxx4.xml
( 5) Remote configuration complete
Reconnected to existing LinkServer process.
Connecting to probe 1 core 0 (using server started externally) reports:
'Ee(42). Could not connect to core.'
Retrying...
Server OK but no connection to probe 1 core 0 (after 3 attempts) - Ee(42). Could not connect to core.
============= SCRIPT: kinetismasserase.scp =============
Kinetis Mass Erase Script
Error: Wire Ack Fault - target connected?
Assert NRESET
Reset pin state: 00
Error: Wire not connected
Power up Debug
No Debug Power
============= END SCRIPT ===============================
Failed on connect: Ee(42). Could not connect to core.
No connection to chip's debug port
(100) Target Connection Failed
Unable to perform operation!
Command failed with exit code 1
18,906 次查看
gpira
I have the same issue, do you find a solution?
22,118 次查看
hfabbasi
@CBI   Did you manage to find the solution for this? I am facing the same problem and tried the same solution but it is not working for me as well
%3CLINGO-SUB%20id%3D%22lingo-sub-864332%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%20DAP%20%E8%AE%BF%E9%97%AE%E4%B8%AD%E7%9A%84%E5%AF%BC%E7%BA%BF%20ACK%20%E6%95%85%E9%9A%9C%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-864332%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E4%BD%A0%E5%A5%BD%3C%2FP%3E%3CP%3E%E6%88%91%E6%9C%80%E8%BF%91%E5%88%9A%E5%88%9A%E5%AE%89%E8%A3%85%E4%BA%86%20McuExpresso%2010.3.0%E3%80%82%E4%B9%8B%E5%89%8D%E6%88%91%E4%BD%BF%E7%94%A8%E7%9A%84%E6%98%AF%3CSPAN%3EMcuExpresso%2010.0.2%E3%80%82%E5%BD%93%E6%88%91%E4%B8%8B%E8%BD%BD%E6%9C%80%E6%96%B0%E7%9A%84%20FRDM%20K64%20SDK%20%E5%B9%B6%E5%B0%9D%E8%AF%95%E8%B0%83%E8%AF%95%E4%B8%80%E4%B8%AA%E6%BC%94%E7%A4%BA%E7%A4%BA%E4%BE%8B%E6%97%B6%EF%BC%8C%E5%87%BA%E7%8E%B0%E4%BA%86%E4%BB%A5%E4%B8%8B%E9%94%99%E8%AF%AF%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E8%BF%9E%E6%8E%A5%E5%A4%B1%E8%B4%A5%EF%BC%9ANn(05).DAP%20%E8%AE%BF%E9%97%AE%E4%B8%AD%E7%9A%84%E5%AF%BC%E7%BA%BF%20ACK%20%E6%95%85%E9%9A%9C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E6%88%91%E4%B8%8D%E6%98%8E%E7%99%BD%E5%88%B0%E5%BA%95%E5%87%BA%E4%BA%86%E4%BB%80%E4%B9%88%E9%97%AE%E9%A2%98%E3%80%82%E8%AF%B7%E5%B8%AE%E6%88%91%E8%A7%A3%E5%86%B3%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E8%B0%A2%E8%B0%A2%EF%BC%81%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E8%90%A8%E9%98%BF%E5%BE%B7%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2195837%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Re%3A%26nbsp%3B%20Wire%20ACK%20Fault%20in%20DAP%20access%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2195837%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%BD%93%E6%88%91%E5%B0%9D%E8%AF%95%E4%BD%BF%E7%94%A8%20SWD%20%E8%BF%9E%E6%8E%A5%20IMXRT1064%20%E6%97%B6%EF%BC%8C%E4%B9%9F%E9%81%87%E5%88%B0%E4%BA%86%E5%90%8C%E6%A0%B7%E7%9A%84%E9%97%AE%E9%A2%98%EF%BC%8C%E6%88%91%E4%B8%80%E7%9B%B4%E6%94%B6%E5%88%B0%E9%94%99%E8%AF%AF%E4%BF%A1%E6%81%AF%EF%BC%9AWire%20Ack%20Fault%20in%20DAP%20Access.%E8%AF%B7%E5%B8%AE%E6%88%91%E8%A7%A3%E5%86%B3%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%E3%80%82%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1701494%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20%20Wire%20ACK%20Fault%20in%20DAP%20access%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1701494%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E5%B0%9D%E8%AF%95%E3%80%82%E8%BF%99%E5%9C%A8%E6%88%91%E8%BF%99%E8%BE%B9%E7%9A%84%E5%87%A0%E4%B8%AA%E6%A1%88%E4%BE%8B%E4%B8%AD%E9%83%BD%E8%B5%B7%E4%BA%86%E4%BD%9C%E7%94%A8%E3%80%82%E4%B9%9F%E8%AE%B8%E4%BD%A0%E7%9A%84%E8%AE%BE%E5%A4%87%E7%A1%AE%E5%AE%9E%E8%A2%AB%E6%B0%B8%E4%B9%85%E5%B0%81%E9%94%81%E4%BA%86%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1701344%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20%20Wire%20ACK%20Fault%20in%20DAP%20access%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1701344%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%B0%9D%E8%AF%95%E4%BA%86%20script....%20%E6%B2%A1%E6%9C%89%E9%AA%B0%E5%AD%90%E3%80%82%20%E4%B8%8D%E8%BF%87%EF%BC%8C%E8%BF%98%E6%98%AF%E8%B0%A2%E8%B0%A2%E4%BD%A0%E7%BB%99%E6%88%91%E6%8C%87%E6%98%8E%E4%BA%86%E6%96%B9%E5%90%91%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1696335%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20%20Wire%20ACK%20Fault%20in%20DAP%20access%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1696335%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%A6%82%E6%88%AA%E5%9B%BE%E6%89%80%E7%A4%BA%EF%BC%9A%3C%2FP%3E%3CP%3E%22%20%E5%A4%8D%E6%B4%BB%E9%94%81%E5%AE%9A%E7%9A%84%20Kinetis%20%E8%AE%BE%E5%A4%87%20%22%EF%BC%9A%E6%AD%A4%E5%8A%9F%E8%83%BD%E4%BB%85%E9%80%82%E7%94%A8%E4%BA%8E%20Kinetis%20%E8%AE%BE%E5%A4%87%E3%80%82%3C%2FP%3E%3CP%3E%E5%A6%82%E6%9E%9C%E6%82%A8%E7%A2%B0%E5%B7%A7%E6%9C%89%E4%B8%80%E5%8F%B0%20LPC%EF%BC%9A%E8%AF%B7%E5%B0%9D%E8%AF%95%E4%BB%8E%E5%BC%95%E5%AF%BC%E5%8A%A0%E8%BD%BD%E7%A8%8B%E5%BA%8F%E6%93%A6%E9%99%A4%E9%97%AA%E5%AD%98%EF%BC%8C%E6%88%96%E8%80%85%E6%82%A8%E5%8F%AF%E4%BB%A5%E4%BD%BF%E7%94%A8%E6%81%A2%E5%A4%8D%E8%84%9A%E6%9C%AC%EF%BC%8C%E5%A6%82%E6%AD%A4%E5%A4%84%E6%89%80%E8%BF%B0%3CA%20href%3D%22https%3A%2F%2Fmcuoneclipse.com%2F2023%2F07%2F25%2Flinkserver-scripting-and-how-to-recover-mcus-with-a-script%2F%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3E%EF%BC%9A%20https%3A%2F%2Fmcuoneclipse.com%2F2023%2F07%2F25%2Flinkserver-scripting-and-how-to-recover-mcus-with-a-script%2F%3C%2FA%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1696158%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20%20Wire%20ACK%20Fault%20in%20DAP%20access%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1696158%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%9C%A8%20mcuxpressoide-11.7.1_9221%20%E4%B8%AD%EF%BC%8C%E6%B2%A1%E6%9C%89%22Resurrect%20%E9%94%81%E5%AE%9A%20...%22%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1650049%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20%20Wire%20ACK%20Fault%20in%20DAP%20access%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1650049%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%88%91%E4%B9%9F%E9%81%87%E5%88%B0%E4%BA%86%E5%90%8C%E6%A0%B7%E7%9A%84%E9%97%AE%E9%A2%98%EF%BC%8C%E4%BD%A0%E6%89%BE%E5%88%B0%E8%A7%A3%E5%86%B3%E5%8A%9E%E6%B3%95%E4%BA%86%E5%90%97%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1392867%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20%20Wire%20ACK%20Fault%20in%20DAP%20access%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1392867%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F183970%22%20target%3D%22_blank%22%3E%40CBI%3C%2FA%3E%E4%BD%A0%E6%89%BE%E5%88%B0%E8%A7%A3%E5%86%B3%E5%8A%9E%E6%B3%95%E4%BA%86%E5%90%97%EF%BC%9F%E6%88%91%E4%B9%9F%E9%81%87%E5%88%B0%E4%BA%86%E5%90%8C%E6%A0%B7%E7%9A%84%E9%97%AE%E9%A2%98%EF%BC%8C%E5%B9%B6%E5%B0%9D%E8%AF%95%E4%BA%86%E5%90%8C%E6%A0%B7%E7%9A%84%E8%A7%A3%E5%86%B3%E6%96%B9%E6%A1%88%EF%BC%8C%E4%BD%86%E5%AE%83%E5%AF%B9%E6%88%91%E4%B9%9F%E4%B8%8D%E8%B5%B7%E4%BD%9C%E7%94%A8%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1386508%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20%20Wire%20ACK%20Fault%20in%20DAP%20access%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1386508%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%82%A8%E5%A5%BD%EF%BC%8C%3C%2FP%3E%3CP%3E%E6%88%91%E4%BB%AC%E4%B9%9F%E9%81%87%E5%88%B0%E4%BA%86%E5%92%8C%20CBI%20%E4%B8%80%E6%A0%B7%E7%9A%84%E9%97%AE%E9%A2%98%E3%80%82%3C%2FP%3E%3CP%3E%E6%82%A8%E7%9A%84%E9%97%AE%E9%A2%98%E8%A7%A3%E5%86%B3%E4%BA%86%E5%90%97%EF%BC%9F%E5%A6%82%E6%9E%9C%E6%9C%89%EF%BC%8C%E8%AF%B7%E5%9C%A8%E6%AD%A4%E5%8F%91%E5%B8%83%E3%80%82%3C%2FP%3E%3CP%3E%E9%9D%9E%E5%B8%B8%E6%84%9F%E8%B0%A2%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1238113%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20%20Wire%20ACK%20Fault%20in%20DAP%20access%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1238113%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%88%91%E7%9A%84%E9%97%AE%E9%A2%98%E8%BF%98%E6%B2%A1%E6%9C%89%E8%A7%A3%E5%86%B3...%E6%88%91%E5%9C%A8%E5%AF%BB%E6%89%BE%E8%A7%A3%E5%86%B3%E5%8A%9E%E6%B3%95%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1238049%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20%20Wire%20ACK%20Fault%20in%20DAP%20access%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1238049%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%A4%A7%E5%AE%B6%E5%A5%BD%EF%BC%8C%3CBR%20%2F%3E%3CBR%20%2F%3E%EF%BC%8C%E6%88%91%E5%9C%A8%E8%BF%99%E4%B8%AA%E8%AE%BA%E5%9D%9B%E4%B8%8A%E8%BF%98%E5%BE%88%E5%B9%B4%E8%BD%BB%3CBR%20%2F%3E%E5%90%8C%E6%97%B6%EF%BC%8C%E5%BD%93%E6%88%91%E6%89%A7%E8%A1%8C%E4%BB%A5%E4%B8%8B%E6%93%8D%E4%BD%9C%E6%97%B6%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22CBI_0-1614612775982.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22CBI_0-1614612775982.png%22%20style%3D%22width%3A%20833px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F138355iDAB1A42917C5944D%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22CBI_0-1614612775982.png%22%20alt%3D%22CBI_0-1614612775982.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E7%BB%93%E6%9E%9C%E5%A6%82%E4%B8%8B%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22CBI_1-1614612812733.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22CBI_1-1614612812733.png%22%20style%3D%22width%3A%20534px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F138356iDC203A0F056AAD96%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22CBI_1-1614612812733.png%22%20alt%3D%22CBI_1-1614612812733.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E6%8E%A7%E5%88%B6%E5%8F%B0%E4%B8%AD%E7%9A%84%E8%AF%A6%E7%BB%86%E4%BF%A1%E6%81%AF%EF%BC%9A%3CBR%20%2F%3E%3CBR%20%2F%3E%E6%89%A7%E8%A1%8C%E9%97%AA%E5%AD%98%E6%93%8D%E4%BD%9C%20%E2%80%9C%E5%A4%8D%E6%B4%BB%E9%94%81%E5%AE%9A%E7%9A%84%20Kinetis%20%E8%AE%BE%E5%A4%87%E2%80%9D%EF%BC%88%E5%A4%8D%E6%B4%BB%E9%94%81%E5%AE%9A%E7%9A%84%20Kinetis%20%E8%AE%BE%E5%A4%87%EF%BC%89%E2%80%94%E2%80%942021%20%E5%B9%B4%203%20%E6%9C%88%201%20%E6%97%A5%E6%98%9F%E6%9C%9F%E4%B8%80%2016%3A30%3A41%20%E4%B8%AD%E6%AC%A7%E6%A0%87%E5%87%86%E6%97%B6%E9%97%B4%202021%20%E6%AD%A3%E5%9C%A8%E6%9F%A5%E7%9C%8B%20MCU%20%E4%BF%A1%E6%81%AF...%20%3CBR%20%2F%3E%3CBR%20%2F%3E%E6%AD%A3%E5%9C%A8%E6%89%AB%E6%8F%8F%E7%9B%AE%E6%A0%87...%3CBR%20%2F%3E%E6%AD%A3%E5%9C%A8%E6%89%A7%E8%A1%8C%20Flash%20%E5%8A%A8%E4%BD%9C...%3CBR%20%2F%3EMCUXpresso%20IDE%20RedlinkMulti%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%20v11.3%EF%BC%882021%20%E5%B9%B4%201%20%E6%9C%88%2011%20%E6%97%A5%2016%3A41%3A13-crt_emu_cm_redlink.exe%20%E7%89%88%E6%9C%AC%209%EF%BC%89%3CBR%20%2F%3E(0)%20%E8%AF%BB%E5%8F%96%E8%BF%9C%E7%A8%8B%E9%85%8D%E7%BD%AE%20Wc%20(03)%E3%80%82%3CBR%20%2F%3E%E4%B8%8D%E6%94%AF%E6%8C%81%E7%BC%93%E5%AD%98%E3%80%82%3CBR%20%2F%3E%E5%9C%A8%20C%3A%2FUsers%2Fbinard%2FDocuments%2FMCUXpressoIDE_11.3.0_5222%2Fworkspace%2Ffrdmkw38_heart_rate_sensor_freertos%2FDebug%5CMKW38A512xxx4.xml%20%E4%B8%AD%E6%89%BE%E5%88%B0%E8%8A%AF%E7%89%87%20XML%20%E6%96%87%E4%BB%B6%3CBR%20%2F%3E(%205)%20%E8%BF%9C%E7%A8%8B%E9%85%8D%E7%BD%AE%E5%AE%8C%E6%88%90%3CBR%20%2F%3E%E9%87%8D%E6%96%B0%E8%BF%9E%E6%8E%A5%E5%88%B0%E7%8E%B0%E6%9C%89%20LinkServer%20%E8%BF%9B%E7%A8%8B%E3%80%82%3CBR%20%2F%3E%E8%BF%9E%E6%8E%A5%E5%88%B0%E6%8E%A2%E6%B5%8B%E5%99%A8%201%20core%200%EF%BC%88%E4%BD%BF%E7%94%A8%E5%A4%96%E9%83%A8%E5%90%AF%E5%8A%A8%E7%9A%84%E6%9C%8D%E5%8A%A1%E5%99%A8%EF%BC%89%E7%9A%84%E6%8A%A5%E5%91%8A%EF%BC%9A%3CBR%20%2F%3E'Ee(42)%E3%80%82%E6%97%A0%E6%B3%95%E8%BF%9E%E6%8E%A5%E6%A0%B8%E5%BF%83%E3%80%82%3CBR%20%2F%3E%E9%87%8D%E8%AF%95...%3CBR%20%2F%3E%E9%87%8D%E6%96%B0%E8%BF%9E%E6%8E%A5%E5%88%B0%E7%8E%B0%E6%9C%89%E7%9A%84%20LinkServer%20%E8%BF%9B%E7%A8%8B%E3%80%82%3CBR%20%2F%3E%E6%9C%8D%E5%8A%A1%E5%99%A8%E6%AD%A3%E5%B8%B8%EF%BC%8C%E4%BD%86%E6%9C%AA%E8%BF%9E%E6%8E%A5%E5%88%B0%201%20%E6%A0%B8%E5%BF%83%200%20%E6%8E%A2%E6%B5%8B%E5%99%A8%EF%BC%88%E5%B0%9D%E8%AF%95%203%20%E6%AC%A1%E5%90%8E%EF%BC%89%20-%20Ee(42)%E3%80%82%E6%97%A0%E6%B3%95%E8%BF%9E%E6%8E%A5%E5%88%B0%E6%A0%B8%E5%BF%83%E3%80%82%3CBR%20%2F%3E%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%20SCRIPT%3A%20kinetismasserase.scp%20%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3CBR%20%2F%3EKinetis%20Mass%20Erase%20Script%3CBR%20%2F%3EError%EF%BC%9AWire%20Ack%20Fault%20-%20target%20connected%3F%3CBR%20%2F%3E%E6%96%AD%E8%A8%80%20NRESET%20%E9%87%8D%3CBR%20%2F%3E%E7%BD%AE%E5%BC%95%E8%84%9A%E7%8A%B6%E6%80%81%EF%BC%9A00%20%3CBR%20%2F%3E%20%E9%94%99%E8%AF%AF%EF%BC%9A%E6%9C%AA%E8%BF%9E%E6%8E%A5%E7%BA%BF%E5%BC%80%E6%9C%BA%E8%B0%83%E8%AF%95%E9%94%99%E8%AF%AF%EF%BC%9A%E7%94%B5%E7%BA%BF%E6%9C%AA%E8%BF%9E%E6%8E%A5%E9%94%99%E8%AF%AF%EF%BC%9A%E7%94%B5%E7%BA%BF%E6%9C%AA%E8%BF%9E%E6%8E%A5%3CBR%20%2F%3E%E6%97%A0%E8%B0%83%E8%AF%95%3CBR%20%2F%3E%3CBR%20%2F%3E%E7%94%B5%E6%BA%90%20%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%20%3CBR%20%2F%3E%20%3D%20%E7%BB%93%E6%9D%9F%E8%84%9A%E6%9C%AC%20%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%E6%97%A0%E6%B3%95%E8%BF%9E%E6%8E%A5%E6%A0%B8%E5%BF%83%E3%80%82%3CBR%20%2F%3E%E4%B8%8E%E8%8A%AF%E7%89%87%E8%B0%83%E8%AF%95%E7%AB%AF%E5%8F%A3%E6%97%A0%E8%BF%9E%E6%8E%A5%3CBR%20%2F%3E(100)%20%E7%9B%AE%E6%A0%87%E8%BF%9E%E6%8E%A5%E5%A4%B1%E8%B4%A5%3CBR%20%2F%3E%E6%97%A0%E6%B3%95%E6%89%A7%E8%A1%8C%E6%93%8D%E4%BD%9C%EF%BC%81%3CBR%20%2F%3E%E5%91%BD%E4%BB%A4%E5%A4%B1%E8%B4%A5%EF%BC%8C%E9%80%80%E5%87%BA%E4%BB%A3%E7%A0%81%E4%B8%BA%201%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1155860%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20%20Wire%20ACK%20Fault%20in%20DAP%20access%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1155860%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%AF%B9%E6%88%91%E6%9D%A5%E8%AF%B4%E4%B9%9F%E6%98%AF%E5%A6%82%E6%AD%A4%E3%80%82%E8%B0%A2%E8%B0%A2%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-864339%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20%20Wire%20ACK%20Fault%20in%20DAP%20access%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-864339%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%20style%3D%22background-color%3A%20transparent%3B%20border-image-outset%3A%200%3B%20border-image-repeat%3A%20stretch%3B%20border-image-slice%3A%20100%25%3B%20border-image-source%3A%20none%3B%20border-image-width%3A%201%3B%20color%3A%20%2351626f%3B%20font-family%3A%20arial%2Chelvetica%2C%22%20helvetica%3D%22%22%20neue%3D%22%22%3E%3CSPAN%20style%3D%22color%3A%20%23333333%3B%20font-family%3A%20Arial%2C%20'Microsoft%20YaHei'%2C%20'%5C%20FAE%E8%BD%AF%E9%9B%85%E9%BB%91'%2C%20'%5C%20B8B%E4%BD%93'%2C%20'Malgun%20Gothic'%2C%20Meiryo%2C%20sans-serif%3B%20font-size%3A%2016px%3B%20font-style%3A%20normal%3B%20font-variant%3A%20normal%3B%20font-weight%3A%20normal%3B%20letter-spacing%3A%20normal%3B%20line-height%3A%2026px%3B%20orphans%3A%20auto%3B%20text-align%3A%20justify%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20white-space%3A%20normal%3B%20widows%3A%20auto%3B%20word-spacing%3A%200px%3B%20-webkit-text-stroke-width%3A%200px%3B%20background-color%3A%20%23f7f8fa%3B%20display%3A%20inline%20!important%3B%20float%3A%20none%3B%22%3E%E6%88%91%E5%8F%91%E7%8E%B0%E9%97%AE%E9%A2%98%E5%87%BA%E5%9C%A8%20MCP%20%E8%A2%AB%E9%94%81%E5%AE%9A%E4%B8%8A%EF%BC%8C%E8%BF%99%E6%98%AF%E5%9C%A8%20MCUXpresso%20%E4%B8%AD%E8%A7%A3%E9%94%81%20MCU%20%E7%9A%84%3CSPAN%20style%3D%22color%3A%20%23000011%3B%20font-family%3A%20Helvetica%20Neue%2CHelvetica%2CArial%2CLucida%20Grande%2Csans-serif%3B%20background-color%3A%20transparent%3B%22%3E%20%E4%B8%80%E4%B8%AA%3C%2FSPAN%3E%3C%2FSPAN%3E%E7%AE%80%E5%8D%95%E6%96%B9%E6%B3%95%EF%BC%8C%E6%88%91%E6%83%B3%E4%B8%8E%E5%85%B6%E4%BB%96%E6%96%B0%E6%89%8B%E5%88%86%E4%BA%AB%EF%BC%8C%E8%BF%99%E6%A0%B7%E4%BB%96%E4%BB%AC%E5%B0%B1%E8%83%BD%E8%BD%BB%E6%9D%BE%E4%B8%8A%E6%89%8B%E4%BA%86%EF%BC%9A%3C%2FP%3E%3CP%20style%3D%22background-color%3A%20transparent%3B%20border-image-outset%3A%200%3B%20border-image-repeat%3A%20stretch%3B%20border-image-slice%3A%20100%25%3B%20border-image-source%3A%20none%3B%20border-image-width%3A%201%3B%20color%3A%20%2351626f%3B%20font-family%3A%20arial%2Chelvetica%2C%22%20helvetica%3D%22%22%20neue%3D%22%22%3E%3CSPAN%20style%3D%22color%3A%20%23000011%3B%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22background-color%3A%20transparent%3B%20border-image-outset%3A%200%3B%20border-image-repeat%3A%20stretch%3B%20border-image-slice%3A%20100%25%3B%20border-image-source%3A%20none%3B%20border-image-width%3A%201%3B%20color%3A%20%2351626f%3B%20font-family%3A%20arial%2Chelvetica%2C%22%20helvetica%3D%22%22%20neue%3D%22%22%3E%3CSPAN%20style%3D%22color%3A%20%23000011%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Unlock%20Kinetis%20MCU!!.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Unlock%20Kinetis%20MCU!!.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F68339i241DA93587355C49%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22Unlock%20Kinetis%20MCU!!.png%22%20alt%3D%22Unlock%20Kinetis%20MCU!!.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22background-color%3A%20transparent%3B%20border-image-outset%3A%200%3B%20border-image-repeat%3A%20stretch%3B%20border-image-slice%3A%20100%25%3B%20border-image-source%3A%20none%3B%20border-image-width%3A%201%3B%20color%3A%20%2351626f%3B%20font-family%3A%20arial%2Chelvetica%2C%22%20helvetica%3D%22%22%20neue%3D%22%22%3E%3CSPAN%20style%3D%22color%3A%20%23000011%3B%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22background-color%3A%20transparent%3B%20border-image-outset%3A%200%3B%20border-image-repeat%3A%20stretch%3B%20border-image-slice%3A%20100%25%3B%20border-image-source%3A%20none%3B%20border-image-width%3A%201%3B%20color%3A%20%2351626f%3B%20font-family%3A%20arial%2Chelvetica%2C%22%20helvetica%3D%22%22%20neue%3D%22%22%3E%3CSPAN%20style%3D%22color%3A%20%23000011%3B%22%3E%E6%AD%A5%E9%AA%A4%201%EF%BC%9A%E6%89%93%E5%BC%80%E5%9B%BE%E5%BD%A2%E7%94%A8%E6%88%B7%E7%95%8C%E9%9D%A2%20Flash%20%E5%B7%A5%E5%85%B7%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22background-color%3A%20transparent%3B%20border-image-outset%3A%200%3B%20border-image-repeat%3A%20stretch%3B%20border-image-slice%3A%20100%25%3B%20border-image-source%3A%20none%3B%20border-image-width%3A%201%3B%20color%3A%20%2351626f%3B%20font-family%3A%20arial%2Chelvetica%2C%22%20helvetica%3D%22%22%20neue%3D%22%22%3E%3CSPAN%20style%3D%22color%3A%20%23000011%3B%22%3E%E6%AD%A5%E9%AA%A4%202%EF%BC%9A%E9%80%89%E6%8B%A9%20%22%E6%81%A2%E5%A4%8D%E9%94%81%E5%AE%9A...%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22background-color%3A%20transparent%3B%20border-image-outset%3A%200%3B%20border-image-repeat%3A%20stretch%3B%20border-image-slice%3A%20100%25%3B%20border-image-source%3A%20none%3B%20border-image-width%3A%201%3B%20color%3A%20%2351626f%3B%20font-family%3A%20arial%2Chelvetica%2C%22%20helvetica%3D%22%22%20neue%3D%22%22%3E%3CSPAN%20style%3D%22color%3A%20%23000011%3B%22%3E%E6%AD%A5%E9%AA%A4%203%EF%BC%9A%E7%82%B9%E5%87%BB%E8%BF%90%E8%A1%8C%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22background-color%3A%20transparent%3B%20border-image-outset%3A%200%3B%20border-image-repeat%3A%20stretch%3B%20border-image-slice%3A%20100%25%3B%20border-image-source%3A%20none%3B%20border-image-width%3A%201%3B%20color%3A%20%2351626f%3B%20font-family%3A%20arial%2Chelvetica%2C%22%20helvetica%3D%22%22%20neue%3D%22%22%3E%3CSPAN%20style%3D%22color%3A%20%23000011%3B%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22background-color%3A%20transparent%3B%20border-image-outset%3A%200%3B%20border-image-repeat%3A%20stretch%3B%20border-image-slice%3A%20100%25%3B%20border-image-source%3A%20none%3B%20border-image-width%3A%201%3B%20color%3A%20%2351626f%3B%20font-family%3A%20arial%2Chelvetica%2C%22%20helvetica%3D%22%22%20neue%3D%22%22%3E%3CSPAN%20style%3D%22color%3A%20%23000011%3B%22%3E%E7%A8%8D%E5%90%8E%EF%BC%8CMCU%20%E5%B0%86%E8%A2%AB%E8%A7%A3%E9%94%81%EF%BC%8C%E5%8F%AF%E4%BB%A5%E8%BF%9B%E8%A1%8C%E6%9B%B4%E5%A4%9A%E7%BC%96%E7%A8%8B%E6%93%8D%E4%BD%9C%EF%BC%81%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-864338%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20%20Wire%20ACK%20Fault%20in%20DAP%20access%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-864338%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%20style%3D%22background-color%3A%20transparent%3B%20border-image-outset%3A%200%3B%20border-image-repeat%3A%20stretch%3B%20border-image-slice%3A%20100%25%3B%20border-image-source%3A%20none%3B%20border-image-width%3A%201%3B%20color%3A%20%2351626f%3B%20font-family%3A%20arial%2Chelvetica%2C%22%20helvetica%3D%22%22%20neue%3D%22%22%3E%3CSPAN%20style%3D%22background-color%3A%20%23ffffff%3B%20border-image-outset%3A%200%3B%20border-image-repeat%3A%20stretch%3B%20border-image-slice%3A%20100%25%3B%20border-image-source%3A%20none%3B%20border-image-width%3A%201%3B%20color%3A%20%23666666%3B%20display%3A%20inline%3B%20float%3A%20none%3B%20font-family%3A%20Arial%2C%22%20microsoft%3D%22%22%20yahei%3D%22%22%3E%E6%88%91%E4%B9%9F%E6%9C%89%E5%90%8C%E6%A0%B7%E7%9A%84%E9%97%AE%E9%A2%98%3C%2FSPAN%3E%E3%80%82%20%3C%2FP%3E%3CUL%20style%3D%22background-color%3A%20%23f7f8fa%3B%20border-image-outset%3A%200%3B%20border-image-repeat%3A%20stretch%3B%20border-image-slice%3A%20100%25%3B%20border-image-source%3A%20none%3B%20border-image-width%3A%201%3B%20box-sizing%3A%20border-box%3B%20color%3A%20%232e3033%3B%20font-family%3A%20Arial%2C%22%20microsoft%3D%22%22%20yahei%3D%22%22%3E%3CLI%20style%3D%22border-image-outset%3A%200%3B%20border-image-repeat%3A%20stretch%3B%20border-image-slice%3A%20100%25%3B%20border-image-source%3A%20none%3B%20border-image-width%3A%201%3B%20box-sizing%3A%20border-box%3B%20display%3A%20list-item%3B%20font-family%3A%20Arial%2C%22%20microsoft%3D%22%22%20yahei%3D%22%22%3E%3CP%20data-group%3D%221-1%22%20style%3D%22border-image-outset%3A%200%3B%20border-image-repeat%3A%20stretch%3B%20border-image-slice%3A%20100%25%3B%20border-image-source%3A%20none%3B%20border-image-width%3A%201%3B%20box-sizing%3A%20border-box%3B%20color%3A%20%23666666%3B%20font-family%3A%20Arial%2C%22%20microsoft%3D%22%22%20yahei%3D%22%22%3E%E4%BD%A0%E6%9C%80%E7%BB%88%E6%98%AF%E5%A6%82%E4%BD%95%E8%A7%A3%E5%86%B3%E9%97%AE%E9%A2%98%E7%9A%84%EF%BC%9F%3C%2FP%3E%3C%2FLI%3E%3C%2FUL%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-864337%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20%20Wire%20ACK%20Fault%20in%20DAP%20access%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-864337%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23666666%3B%20font-family%3A%20Arial%2C%20'Microsoft%20YaHei'%2C%20'%5C%20FAE%E8%BD%AF%E9%9B%85%E9%BB%91'%2C%20'%5C%20B8B%E4%BD%93'%2C%20'Malgun%20Gothic'%2C%20Meiryo%2C%20sans-serif%3B%20font-size%3A%2016px%3B%20font-style%3A%20normal%3B%20font-variant%3A%20normal%3B%20font-weight%3A%20normal%3B%20letter-spacing%3A%20normal%3B%20line-height%3A%2024px%3B%20orphans%3A%20auto%3B%20text-align%3A%20start%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20white-space%3A%20normal%3B%20widows%3A%20auto%3B%20word-spacing%3A%200px%3B%20-webkit-text-stroke-width%3A%200px%3B%20background-color%3A%20%23ffffff%3B%20display%3A%20inline%20!important%3B%20float%3A%20none%3B%22%3E%E6%88%91%E4%B9%9F%E6%9C%89%E5%90%8C%E6%A0%B7%E7%9A%84%E9%97%AE%E9%A2%98%3C%2FSPAN%3E%E3%80%82%20%3C%2FP%3E%3CUL%20style%3D%22box-sizing%3A%20border-box%3B%20margin%3A%200px%3B%20padding%3A%200px%3B%20color%3A%20%232e3033%3B%20font-family%3A%20Arial%2C%20'Microsoft%20YaHei'%2C%20'%5C%20FAE%E8%BD%AF%E9%9B%85%E9%BB%91'%2C%20'%5C%20B8B%E4%BD%93'%2C%20'Malgun%20Gothic'%2C%20Meiryo%2C%20sans-serif%3B%20font-size%3A%2016px%3B%20font-style%3A%20normal%3B%20font-variant%3A%20normal%3B%20font-weight%3A%20normal%3B%20letter-spacing%3A%20normal%3B%20line-height%3A%2016px%3B%20orphans%3A%20auto%3B%20text-align%3A%20start%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20white-space%3A%20normal%3B%20widows%3A%20auto%3B%20word-spacing%3A%200px%3B%20-webkit-text-stroke-width%3A%200px%3B%20background-color%3A%20%23f7f8fa%3B%22%3E%3CLI%20style%3D%22box-sizing%3A%20border-box%3B%20margin%3A%200px%200px%2010px%3B%20padding%3A%200px%3B%20list-style%3A%20none%3B%22%3E%3CP%20data-group%3D%221-1%22%20style%3D%22box-sizing%3A%20border-box%3B%20margin%3A%200px%3B%20padding%3A%200px%3B%20font-size%3A%2016px%3B%20color%3A%20%23666666%3B%20line-height%3A%2026px%3B%22%3E%E4%BD%A0%E6%9C%80%E7%BB%88%E6%98%AF%E5%A6%82%E4%BD%95%E8%A7%A3%E5%86%B3%E9%97%AE%E9%A2%98%E7%9A%84%EF%BC%9F%3C%2FP%3E%3C%2FLI%3E%3C%2FUL%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-864336%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20%20Wire%20ACK%20Fault%20in%20DAP%20access%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-864336%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E5%BE%88%E9%AB%98%E5%85%B4%E7%9F%A5%E9%81%93%E8%BF%99%E4%B8%80%E7%82%B9%E3%80%82%E4%B8%8D%E5%AE%A2%E6%B0%94%EF%BC%81%3C%2FP%3E%3CP%3E%3CBR%20%2F%3E%E7%A5%9D%E6%82%A8%E6%84%89%E5%BF%AB%EF%BC%8C%3CBR%20%2F%3EJun%20Zhang%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E-----------------------------------------------------------------------------------------------------------------------%3CBR%20%2F%3E%E6%B3%A8%EF%BC%9A%E5%A6%82%E6%9E%9C%E6%9C%AC%E5%B8%96%E5%9B%9E%E7%AD%94%E4%BA%86%E6%82%A8%E7%9A%84%E9%97%AE%E9%A2%98%EF%BC%8C%E8%AF%B7%E7%82%B9%E5%87%BB%E6%AD%A3%E7%A1%AE%E7%AD%94%E6%A1%88%E6%8C%89%E9%92%AE%E3%80%82Thank%20you!%3CBR%20%2F%3E-----------------------------------------------------------------------------------------------------------------------%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-864335%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%26nbsp%3B%20Wire%20ACK%20Fault%20in%20DAP%20access%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-864335%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E8%B0%A2%E8%B0%A2%EF%BC%81%3C%2FP%3E%3CP%3E%E9%97%AE%E9%A2%98%E5%B7%B2%E7%BB%8F%E8%A7%A3%E5%86%B3%E3%80%82%EF%BC%89%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-864334%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%26nbsp%3B%20Wire%20ACK%20Fault%20in%20DAP%20access%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-864334%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E4%BD%A0%E5%A5%BD%3C%2FP%3E%3CP%3E%E6%88%91%E5%B7%B2%E7%BB%8F%E6%8C%89%E4%BD%A0%E8%AF%B4%E7%9A%84%E5%81%9A%E4%BA%86%E3%80%82%3C%2FP%3E%3CP%3E%E7%8E%B0%E5%9C%A8%E6%88%91%E6%94%B6%E5%88%B0%E4%BB%A5%E4%B8%8B%E9%94%99%E8%AF%AF%E4%BF%A1%E6%81%AF%3C%2FP%3E%3CP%3E15%EF%BC%9ACommit%20Flash%20%E5%86%99%E5%85%A5%E6%97%B6%E5%87%BA%E7%8E%B0%E7%9B%AE%E6%A0%87%E9%94%99%E8%AF%AF%3CBR%20%2F%3E%2015%EF%BC%9ACommit%20Flash%20%E5%86%99%E5%85%A5%E6%97%B6%E5%87%BA%E7%8E%B0%E7%9B%AE%E6%A0%87%E9%94%99%E8%AF%AF%3CBR%20%2F%3E%20%E6%97%A0%E6%B3%95%E5%81%9C%E6%AD%A2%E5%A4%84%E7%90%86%E5%99%A8%E3%80%82%3CBR%20%2F%3E%E8%B0%83%E8%AF%95%E4%B8%8A%E4%B8%8B%E6%96%87%EF%BC%9Afrdmk64f_lwip_tcpecho_bm%20%E8%B0%83%E8%AF%95%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-864333%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20%20Wire%20ACK%20Fault%20in%20DAP%20access%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-864333%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%E8%90%A8%E9%98%BF%E5%BE%B7%E3%80%81%3C%2FP%3E%3CP%3E%E9%A6%96%E5%85%88%EF%BC%8C%E6%88%91%E4%BB%AC%E9%9C%80%E8%A6%81%E7%A1%AE%E5%AE%9A%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%E5%8F%AA%E5%AD%98%E5%9C%A8%E4%BA%8E%E4%B8%80%E4%B8%AA%E9%A1%B9%E7%9B%AE%E4%B8%AD%EF%BC%8C%E8%BF%98%E6%98%AF%E6%89%80%E6%9C%89%E9%A1%B9%E7%9B%AE%E7%9A%84%E5%85%B1%E5%90%8C%E9%97%AE%E9%A2%98%E3%80%82%3C%2FP%3E%3CP%3E-%20%E8%AF%B7%E5%9C%A8%E6%96%B0%E5%B7%A5%E4%BD%9C%E5%8C%BA%E4%B8%AD%E5%88%9B%E5%BB%BA%E4%B8%80%E4%B8%AA%E6%96%B0%E9%A1%B9%E7%9B%AE%EF%BC%8C%E7%9C%8B%E7%9C%8B%E8%BF%9E%E6%8E%A5%E6%98%AF%E5%A6%82%E4%BD%95%E5%B7%A5%E4%BD%9C%E7%9A%84%E3%80%82%3C%2FP%3E%3CP%3E-%20%E8%AF%B7%E5%9C%A8%E6%96%B0%E5%B7%A5%E4%BD%9C%E5%8C%BA%E6%B5%8B%E8%AF%95%E6%82%A8%E7%9A%84%E9%A1%B9%E7%9B%AE%EF%BC%8C%E6%95%88%E6%9E%9C%E5%A6%82%E4%BD%95%EF%BC%9F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%A6%82%E6%9E%9C%E4%BB%A5%E4%B8%8A%E4%B8%A4%E7%A7%8D%E6%96%B9%E6%B3%95%E9%83%BD%E4%B8%8D%E8%83%BD%E8%A7%A3%E5%86%B3%E9%97%AE%E9%A2%98%EF%BC%8C%E6%88%91%E5%BB%BA%E8%AE%AE%E6%82%A8%E6%9B%B4%E6%96%B0%20K64%20%E5%9B%BA%E4%BB%B6%E3%80%82%3C%2FP%3E%3CP%3E%3CA%20class%3D%22link-titled%22%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fsupport%2Fdeveloper-resources%2Frun-time-software%2Fkinetis-developer-resources%2Fides-for-kinetis-mcus%2Fopensda-serial-and-debug-adapter%3AOPENSDA%3F%26amp%3Btid%3DvanOpenSDA%22%20title%3D%22https%3A%2F%2Fwww.nxp.com%2Fsupport%2Fdeveloper-resources%2Frun-time-software%2Fkinetis-developer-resources%2Fides-for-kinetis-mcus%2Fopensda-serial-and-debug-adapter%3AOPENSDA%3F%26amp%3Btid%3DvanOpenSDA%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3EOpenSDA%20%E4%B8%B2%E8%A1%8C%E5%92%8C%E8%B0%83%E8%AF%95%E9%80%82%E9%85%8D%E5%99%A8%7CNXP%3C%2FA%3E%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CBR%20%2F%3E%E7%A5%9D%E6%82%A8%E6%84%89%E5%BF%AB%EF%BC%8C%3CBR%20%2F%3EJun%20Zhang%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E-----------------------------------------------------------------------------------------------------------------------%3CBR%20%2F%3E%E6%B3%A8%EF%BC%9A%E5%A6%82%E6%9E%9C%E6%9C%AC%E5%B8%96%E5%9B%9E%E7%AD%94%E4%BA%86%E6%82%A8%E7%9A%84%E9%97%AE%E9%A2%98%EF%BC%8C%E8%AF%B7%E7%82%B9%E5%87%BB%E6%AD%A3%E7%A1%AE%E7%AD%94%E6%A1%88%E6%8C%89%E9%92%AE%E3%80%82Thank%20you!%3CBR%20%2F%3E-----------------------------------------------------------------------------------------------------------------------%3C%2FP%3E%3C%2FLINGO-BODY%3E
