Problem using cache
Problem using cache
1,313件の閲覧回数
biafra
Senior Contributor I
Hi everyone,
I'm using MCUXpresso 10.2.1 with a custom board based on MK66FN2M0.
I developed an application that is working fine, but on some operations it's a little time consuming. I've enabled the cache memory with LMEM module, but I haven't seen any speed gain.
I've used the following statement:
LMEM_EnableCodeCache( LMEM, true );
Do some other configurations are needed?
Many thanks
Biafra
1,207件の閲覧回数
jingpan
Hi Biafra,
This function is enough to enable 8k I/D cache. Cache will not dramatically increase the speed. But it really work. I spent some time to test by Coremark. The total ticks drop from 1727 to 1574 after I enable cache.
Jing
