Post Build Steps output not showing in CDT Build Console
563 次查看
deniscollis
Contributor V
Here is a transcript from MCUXPresso's CDT Build Console :
Performing post-build steps
arm-none-eabi-objcopy -v -I ihex -O binary "X.hex" "X.bin" ; OtaUpdatePackageCreator -p "..\UpdatePackageConfig.txt"
copy from `X.hex' [ihex] to `X.bin' [binary]
OtaUpdatePackageCreator -p ..\UpdatePackageConfig.txt
Stdout from objcopy is echoed in the build console.
Stdout from OtaUpdatePackageCreator is not.
However, console output is indeed produced when the latter is run in a Windows cmd shell
C:\bldUtils\>OtaUpdatePackageCreator -p UpdatePackageConfig.txt
Ver: 11
In: X.bin, capk.bin
Out: updPkgV11.bin
C:\bldUtils\>
Any insights why this is?
518 次查看
mayliu1
Hi @deniscollis ,
Thank you so much for your interest in our products and for using our community.
Could you tell me  which version of MCUXPresso you are using. And a more detailed description of the problem.
Also, I checked the user guide about your problem ,  and I think the MCUXpresso_IDE_xx.xx_Command_Line_User_Guide might be helpful.
Wish it helps you.
Wish you a nice day!
Best Regards
MayLiu
