PWM and Timer Peripherals using simultaneously in LPC55S16 Microcontroller
1,397件の閲覧回数
VIGNESH_BABU
I am using the LPC55S16 Microcontroller. Where I using the PWM and Timer Peripherals simultaneously but I was unable to utilize the same Peripherals at same timer due to same MCR register Bits.Is there is any optional way to use same Peripherals at same time.
1,366件の閲覧回数
Hello @VIGNESH_BABU
There are five CTIMERs for lpc55s16, you can use one timer for PWM, one for timer.
Can not use same time, because as you said, one of them can reset the TC, "PWM" and "Timer" use the same TC.
Alice
