Linker command when building with west
jonasa
I build a project for a MCXE31B dev. board using west like this:
west build -b frdmmcxe31b -d build_lwip mcuxsdk\examples\lwip_examples\lwip_ping_enet_qos\bm
A file called
\build_lwip\compile_commands.json
Is generated with all the compile commands which is great.
But I would also like to see the linker command that is executed to build the .elf and .bin file.
Is that command logged in some other file by the build system?
Celeste_Liu
Hello @jonasa ,
Thanks for your post. You can find the relevant information using the command below. See attached picture.
grep -rn "MCXE31B_flash.ld" build.ninja
grep -R "objcopy" build.ninja
Hope it helps.
Celeste
Note: If this post answers your question, please click the "ACCEPT AS SOLUTION" button. Thank you!
Celeste_Liu
Hello @jonasa ,
Hope it helps.
Celeste
%3CLINGO-SUB%20id%3D%22lingo-sub-2350668%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ELinker%20command%20when%20building%20with%20west%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2350668%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%26nbsp%3B%3C%2FP%3E%3CP%3EI%20build%20a%20project%20for%20a%26nbsp%3BMCXE31B%20dev.%20board%20using%20west%20like%20this%3A%3CBR%20%2F%3E%3CBR%20%2F%3Ewest%20build%20-b%20frdmmcxe31b%20-d%20build_lwip%20mcuxsdk%5Cexamples%5Clwip_examples%5Clwip_ping_enet_qos%5Cbm%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EA%20file%20called%26nbsp%3B%3C%2FP%3E%3CP%3E%5Cbuild_lwip%5Ccompile_commands.json%3C%2FP%3E%3CP%3EIs%20generated%20with%20all%20the%20compile%20commands%20which%20is%20great.%3C%2FP%3E%3CP%3EBut%20I%20would%20also%20like%20to%20see%20the%20linker%20command%20that%20is%20executed%20to%20build%20the%20.elf%20and%20.bin%20file.%3CBR%20%2F%3E%3CBR%20%2F%3EIs%20that%20command%20logged%20in%20some%20other%20file%20by%20the%20build%20system%3F%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2352151%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Linker%20command%20when%20building%20with%20west%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2352151%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F157113%22%20target%3D%22_blank%22%3E%40jonasa%3C%2FA%3E%26nbsp%3B%2C%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EThanks%20for%20your%20post.%20You%20can%20find%20the%20relevant%20information%20using%20the%20command%20below.%26nbsp%3B%3CSPAN%20data-teams%3D%22true%22%3ESee%20attached%20picture.%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20data-teams%3D%22true%22%3Egrep%20-rn%20%22MCXE31B_flash.ld%22%20build.ninja%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20data-teams%3D%22true%22%3Egrep%20-R%20%22objcopy%22%20build.ninja%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CSPAN%20data-teams%3D%22true%22%3EHope%20it%20helps.%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20data-teams%3D%22true%22%3EBR%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20data-teams%3D%22true%22%3ECeleste%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CSPAN%20data-teams%3D%22true%22%3E---------------------------------------------------------------------------------------------------------------------------%3CBR%20%2F%3ENote%3A%20If%20this%20post%20answers%20your%20question%2C%20please%20click%20the%20%22ACCEPT%20AS%20SOLUTION%22%20button.%20Thank%20you!%3CBR%20%2F%3E---------------------------------------------------------------------------------------------------------------------------%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CBR%20%2F%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E
