How to not erase a range of sectors with GUI flash tool?
1,777 次查看
rex_lam
I am using MCUXpresso GUI Flash Tool with LPC1853 MCU. I would like the tool to erase sectors 4 to 14 in Flash A, but not touch sectors 0 to 3. Is it possible to do so with the GUI Flash Tool?
1,671 次查看
ZhangJennie
Hi Rex,
I suggest you use FlashMagic ( www.flashmagictool.com) that can support sector erase.
Jun Zhang
1,672 次查看
ZhangJennie
Hi Rex,
Jun Zhang
1,671 次查看
rex_lam
I tried using FlashMagic, but I don't see SWD option in the Interface pull-down. I am using ULINK-ME debug probe, and it does not appear to be supported by FlashMagic.
Thank you for answering my question. I guess I have to use FlashMagic with compatible debug probe to erase specific sectors. It works with LPC-Link2.
1,671 次查看
ZhangJennie
Hi Rex,
I ever worked with Flash Magic under ISP mode without problem.
For more about FlashMagic usage, Flash Magic Forum - Index is the best place to discuss. some FlashMagic tool specialists are supporting there.
Thanks for your understanding.
Jun Zhang
