Error while launching the program in MCUXpresso IDE
4,177件の閲覧回数
tomato
I am receiving this error when I try to run my program on MCUxpresso IDE with the LPC845-BRK board connected. Do you know how to solve it?
4,170件の閲覧回数
ErichStyger
Specialist I
It could be many things, but: did you use the 'blue' debug button to start the debug session?
I hope this helps,
Erich
4 返答(返信)
3,022件の閲覧回数
Kemsys
Facing this issue, could you please help me to solve this error.
4,171件の閲覧回数
ErichStyger
Specialist I
I hope this helps,
Erich
4,165件の閲覧回数
tomato
I pressed the blue one and the debug session started correctly.
Thank you very much.
Can you give a glimpse of the difference between the green and the blue button debug? I have just started to learn how to use MCUxpresso
4,162件の閲覧回数
ErichStyger
Specialist I
the blue one searches for available probes and creates the correct launch configuration.
Simply always use the blue one with MCUXpresso IDE.
You only can use the green one if you have a correct launch config already, and you want to select it manually.
