Hi Jorge
Thanks for looking into this.
I've tried your suggestion as shown below, but this has made no
difference. Please also note that the debug and release configurations
build and debug correctly, the debug_New configuration I've created also
compiles and links correctly, but I cannot debug.
As you have not been able to re-create the problem I have attached my
example workspace for you to investigate, (example.zip at the end of this
email). The Debug and Release configurations are fine, the Debug_New
configuration is the one that I can't debug.
I have re-run "lpc_driver_setup.exe" version 2.0.2.0 to update / repair
the USB drivers on my PC. Checking the driver versions in device manager
gives
I have run LCPScrypt version 2.1.0_842 which re-programmed the LCPLINK2
probe. Here is the output from the command showing the version programmed.
LPCScrypt - CMSIS-DAP firmware programming script v2.0.0 June 2018.
Connect an LPC-Link2 or LPCXpresso V2/V3 Board via USB then press Space.
Press any key to continue . . .
Booting LPCScrypt target with "LPCScrypt_227.bin.hdr"
LPCScrypt target booted
Programming LPC-Link2 with "LPC432x_CMSIS_DAP_V5_224.bin.hdr"
- LPC-Link2 programmed successfully and has the unique ID: NYBSDWIV
- To use: make link JP1 (nearest USB) and reboot.
Connect Next Board then press Space (or CTRL-C to Quit)
Best Regards
John Aldridge
John Aldridge CEng MIET - Senior Design Engineer - Direct: +44 1903 737353
- Fax: - E-Mail: JAldridge@parker.com
Parker Hannifin Manufacturing Ltd - Electromechanical & Drives Division
Europe - New Courtwick Lane · Littlehampton· West Sussex, UK · BN17 7RZ
Phone.: + 44 (0)1903 737000 - Fax: + 44 (0)1903 737 123
Parker Hannifin Manufacturing Ltd - Registered in London no 4806503
Registered Office - Parker House · 55 Maylands Ave · Hemel Hempstead · HP2
4SJ · United Kingdom
www.parker.com/eme
