Could not initialize cppcheck for project
rshipman
Senior Contributor I
I've just tried to install the ccpcheck plugin etc and it refuses to run:
I get this error:
Could not initialize cppcheck for project...
Here is the exception stack trace:
java.lang.NullPointerException: Cannot invoke "org.eclipse.core.runtime.IPath.toFile()" because the return value of "org.eclipse.cdt.core.settings.model.ACPathEntry.getLocation()" is null
at com.googlecode.cppcheclipse.ui.ToolchainSettings.getIncludes(ToolchainSettings.java:182)
at com.googlecode.cppcheclipse.ui.ToolchainSettings.getUserIncludes(ToolchainSettings.java:88)
at com.googlecode.cppcheclipse.core.Checker.<init>(Checker.java:81)
at com.googlecode.cppcheclipse.ui.Builder$ResourceVisitor.initChecker(Builder.java:164)
at com.googlecode.cppcheclipse.ui.Builder$ResourceVisitor.processFile(Builder.java:199)
at com.googlecode.cppcheclipse.ui.Builder$ResourceVisitor.visit(Builder.java:122)
at org.eclipse.core.internal.resources.Resource.lambda$1(Resource.java:154)
at org.eclipse.core.internal.resources.Resource.lambda$0(Resource.java:122)
at org.eclipse.core.internal.watson.ElementTreeIterator.doIteration(ElementTreeIterator.java:85)
at org.eclipse.core.internal.watson.ElementTreeIterator.doIteration(ElementTreeIterator.java:90)
at org.eclipse.core.internal.watson.ElementTreeIterator.iterate(ElementTreeIterator.java:135)
at org.eclipse.core.internal.resources.Resource.accept(Resource.java:131)
at org.eclipse.core.internal.resources.Resource.accept(Resource.java:92)
at org.eclipse.core.internal.resources.Resource.accept(Resource.java:154)
at org.eclipse.core.internal.resources.Resource.accept(Resource.java:142)
at com.googlecode.cppcheclipse.ui.Builder.processResource(Builder.java:306)
at com.googlecode.cppcheclipse.ui.commands.RunCodeAnalysis$RunCodeAnalysisJob.runResource(RunCodeAnalysis.java:26)
at com.googlecode.cppcheclipse.ui.commands.ResourceSelectionJob.run(ResourceSelectionJob.java:44)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:63)
Info:
MCUXpresso IDE v24.12 [Build 148] [2025-01-10]
I downloaded Cppcheck 2.18 from here: https://cppcheck.sourceforge.io/
I followed these instructions: https://github.com/cppchecksolutions/cppcheclipse/wiki/Installation
I added cppcheck path to PATH environment variable and restarted MCUXpresso.
Any ideas please?
Tags (2)
EdwinHz
Hi @rshipman,
I'm afraid this is outside of NXP's support scope, since it is related to an Eclipse level plugin, rather than a MCUXpresso IDE issue.
I recommend you take a look at the following links:
Static Code Analysis Tool cppcheck on MCUXpresso IDE - NXP Community
java.lang.NullPointerException: Could not initialize cppcheck for project lib-ltc · Issue #98 · kwin...
BR,
Edwin.
%3CLINGO-SUB%20id%3D%22lingo-sub-2172085%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ECould%20not%20initialize%20cppcheck%20for%20project%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2172085%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%3C%2FP%3E%3CP%3E%3CBR%20%2F%3EI've%20just%20tried%20to%20install%20the%20ccpcheck%20plugin%20etc%20and%20it%20refuses%20to%20run%3A%3C%2FP%3E%3CP%3EI%20get%20this%20error%3A%3C%2FP%3E%3CP%3ECould%20not%20initialize%20cppcheck%20for%20project...%3C%2FP%3E%3CP%3EHere%20is%20the%20exception%20stack%20trace%3A%3CBR%20%2F%3Ejava.lang.NullPointerException%3A%20Cannot%20invoke%20%22org.eclipse.core.runtime.IPath.toFile()%22%20because%20the%20return%20value%20of%20%22org.eclipse.cdt.core.settings.model.ACPathEntry.getLocation()%22%20is%20null%3CBR%20%2F%3Eat%20com.googlecode.cppcheclipse.ui.ToolchainSettings.getIncludes(ToolchainSettings.java%3A182)%3CBR%20%2F%3Eat%20com.googlecode.cppcheclipse.ui.ToolchainSettings.getUserIncludes(ToolchainSettings.java%3A88)%3CBR%20%2F%3Eat%20com.googlecode.cppcheclipse.core.Checker.%3CINIT%3E(Checker.java%3A81)%3CBR%20%2F%3Eat%20com.googlecode.cppcheclipse.ui.Builder%24ResourceVisitor.initChecker(Builder.java%3A164)%3CBR%20%2F%3Eat%20com.googlecode.cppcheclipse.ui.Builder%24ResourceVisitor.processFile(Builder.java%3A199)%3CBR%20%2F%3Eat%20com.googlecode.cppcheclipse.ui.Builder%24ResourceVisitor.visit(Builder.java%3A122)%3CBR%20%2F%3Eat%20org.eclipse.core.internal.resources.Resource.lambda%241(Resource.java%3A154)%3CBR%20%2F%3Eat%20org.eclipse.core.internal.resources.Resource.lambda%240(Resource.java%3A122)%3CBR%20%2F%3Eat%20org.eclipse.core.internal.watson.ElementTreeIterator.doIteration(ElementTreeIterator.java%3A85)%3CBR%20%2F%3Eat%20org.eclipse.core.internal.watson.ElementTreeIterator.doIteration(ElementTreeIterator.java%3A90)%3CBR%20%2F%3Eat%20org.eclipse.core.internal.watson.ElementTreeIterator.doIteration(ElementTreeIterator.java%3A90)%3CBR%20%2F%3Eat%20org.eclipse.core.internal.watson.ElementTreeIterator.iterate(ElementTreeIterator.java%3A135)%3CBR%20%2F%3Eat%20org.eclipse.core.internal.resources.Resource.accept(Resource.java%3A131)%3CBR%20%2F%3Eat%20org.eclipse.core.internal.resources.Resource.accept(Resource.java%3A92)%3CBR%20%2F%3Eat%20org.eclipse.core.internal.resources.Resource.accept(Resource.java%3A154)%3CBR%20%2F%3Eat%20org.eclipse.core.internal.resources.Resource.accept(Resource.java%3A142)%3CBR%20%2F%3Eat%20com.googlecode.cppcheclipse.ui.Builder.processResource(Builder.java%3A306)%3CBR%20%2F%3Eat%20com.googlecode.cppcheclipse.ui.commands.RunCodeAnalysis%24RunCodeAnalysisJob.runResource(RunCodeAnalysis.java%3A26)%3CBR%20%2F%3Eat%20com.googlecode.cppcheclipse.ui.commands.ResourceSelectionJob.run(ResourceSelectionJob.java%3A44)%3CBR%20%2F%3Eat%20org.eclipse.core.internal.jobs.Worker.run(Worker.java%3A63)%3CBR%20%2F%3E%3CBR%20%2F%3EInfo%3A%3CBR%20%2F%3EMCUXpresso%20IDE%20v24.12%20%5BBuild%20148%5D%20%5B2025-01-10%5D%3C%2FINIT%3E%3C%2FP%3E%3CP%3EI%20downloaded%20Cppcheck%202.18%20from%20here%3A%20%3CA%20href%3D%22https%3A%2F%2Fcppcheck.sourceforge.io%2F%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fcppcheck.sourceforge.io%2F%3C%2FA%3E%3CBR%20%2F%3EI%20followed%20these%20instructions%3A%20%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Fcppchecksolutions%2Fcppcheclipse%2Fwiki%2FInstallation%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fgithub.com%2Fcppchecksolutions%2Fcppcheclipse%2Fwiki%2FInstallation%3C%2FA%3E%3CBR%20%2F%3EI%20added%20cppcheck%20path%20to%20PATH%20environment%20variable%20and%20restarted%20MCUXpresso.%3C%2FP%3E%3CP%3EAny%20ideas%20please%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2172219%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Could%20not%20initialize%20cppcheck%20for%20project%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2172219%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F71022%22%20target%3D%22_blank%22%3E%40rshipman%3C%2FA%3E%2C%3C%2FP%3E%0A%3CP%3EI'm%20afraid%20this%20is%20outside%20of%20NXP's%20support%20scope%2C%20since%20it%20is%20related%20to%20an%20Eclipse%20level%20plugin%2C%20rather%20than%20a%20MCUXpresso%20IDE%20issue.%3C%2FP%3E%0A%3CP%3EI%20recommend%20you%20take%20a%20look%20at%20the%20following%20links%3A%3CBR%20%2F%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FMCUXpresso-IDE%2FStatic-Code-Analysis-Tool-cppcheck-on-MCUXpresso-IDE%2Fm-p%2F880557%22%20target%3D%22_blank%22%3EStatic%20Code%20Analysis%20Tool%20cppcheck%20on%20MCUXpresso%20IDE%20-%20NXP%20Community%3C%2FA%3E%3CBR%20%2F%3E%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Fkwin%2Fcppcheclipse%2Fissues%2F98%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ejava.lang.NullPointerException%3A%20Could%20not%20initialize%20cppcheck%20for%20project%20lib-ltc%20%C2%B7%20Issue%20%2398%20%C2%B7%20kwin%2Fcppcheclipse%3C%2FA%3E%3C%2FP%3E%0A%3CP%3EBR%2C%3CBR%20%2F%3EEdwin.%3C%2FP%3E%3C%2FLINGO-BODY%3E
