Could not initialize cppcheck for project
1,400件の閲覧回数
rshipman
Senior Contributor I
I've just tried to install the ccpcheck plugin etc and it refuses to run:
I get this error:
Could not initialize cppcheck for project...
Here is the exception stack trace:
java.lang.NullPointerException: Cannot invoke "org.eclipse.core.runtime.IPath.toFile()" because the return value of "org.eclipse.cdt.core.settings.model.ACPathEntry.getLocation()" is null
at com.googlecode.cppcheclipse.ui.ToolchainSettings.getIncludes(ToolchainSettings.java:182)
at com.googlecode.cppcheclipse.ui.ToolchainSettings.getUserIncludes(ToolchainSettings.java:88)
at com.googlecode.cppcheclipse.core.Checker.<init>(Checker.java:81)
at com.googlecode.cppcheclipse.ui.Builder$ResourceVisitor.initChecker(Builder.java:164)
at com.googlecode.cppcheclipse.ui.Builder$ResourceVisitor.processFile(Builder.java:199)
at com.googlecode.cppcheclipse.ui.Builder$ResourceVisitor.visit(Builder.java:122)
at org.eclipse.core.internal.resources.Resource.lambda$1(Resource.java:154)
at org.eclipse.core.internal.resources.Resource.lambda$0(Resource.java:122)
at org.eclipse.core.internal.watson.ElementTreeIterator.doIteration(ElementTreeIterator.java:85)
at org.eclipse.core.internal.watson.ElementTreeIterator.doIteration(ElementTreeIterator.java:90)
at org.eclipse.core.internal.watson.ElementTreeIterator.iterate(ElementTreeIterator.java:135)
at org.eclipse.core.internal.resources.Resource.accept(Resource.java:131)
at org.eclipse.core.internal.resources.Resource.accept(Resource.java:92)
at org.eclipse.core.internal.resources.Resource.accept(Resource.java:154)
at org.eclipse.core.internal.resources.Resource.accept(Resource.java:142)
at com.googlecode.cppcheclipse.ui.Builder.processResource(Builder.java:306)
at com.googlecode.cppcheclipse.ui.commands.RunCodeAnalysis$RunCodeAnalysisJob.runResource(RunCodeAnalysis.java:26)
at com.googlecode.cppcheclipse.ui.commands.ResourceSelectionJob.run(ResourceSelectionJob.java:44)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:63)
Info:
MCUXpresso IDE v24.12 [Build 148] [2025-01-10]
I downloaded Cppcheck 2.18 from here: https://cppcheck.sourceforge.io/
I followed these instructions: https://github.com/cppchecksolutions/cppcheclipse/wiki/Installation
I added cppcheck path to PATH environment variable and restarted MCUXpresso.
Any ideas please?
タグ(2)
1,382件の閲覧回数
EdwinHz
Hi @rshipman,
I'm afraid this is outside of NXP's support scope, since it is related to an Eclipse level plugin, rather than a MCUXpresso IDE issue.
I recommend you take a look at the following links:
Static Code Analysis Tool cppcheck on MCUXpresso IDE - NXP Community
java.lang.NullPointerException: Could not initialize cppcheck for project lib-ltc · Issue #98 · kwin...
BR,
Edwin.
%3CLINGO-SUB%20id%3D%22lingo-sub-2172085%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%81%AE%20cppcheck%20%E3%82%92%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2172085%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%3C%2FP%3E%3CP%3E%3CBR%20%2F%3Eccpcheck%20%E3%83%97%E3%83%A9%E3%82%B0%E3%82%A4%E3%83%B3%E3%81%AA%E3%81%A9%E3%82%92%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E5%AE%9F%E8%A1%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%E6%AC%A1%E3%81%AE%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%99%3A%3C%2FP%3E%3CP%3E%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%81%AE%20cppcheck%20%E3%82%92%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F...%3C%2FP%3E%3CP%3E%E4%BE%8B%E5%A4%96%E3%81%AE%E3%82%B9%E3%82%BF%E3%83%83%E3%82%AF%20%E3%83%88%E3%83%AC%E3%83%BC%E3%82%B9%E3%81%AF%E6%AC%A1%E3%81%AE%E3%81%A8%E3%81%8A%E3%82%8A%E3%81%A7%E3%81%99%E3%80%82%3CBR%20%2F%3E%20java.lang.NullPointerException%3A%20%22org.eclipse.core.runtime.IPath.toFile()%22%20%E3%82%92%E5%91%BC%E3%81%B3%E5%87%BA%E3%81%99%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%8Corg.eclipse.cdt.core.settings.model.ACPathEntry.getLocation()%E3%80%8D%E3%81%AE%E6%88%BB%E3%82%8A%E5%80%A4%E3%81%8Cnull%E3%81%A7%E3%81%82%E3%82%8B%E3%81%9F%E3%82%81%3CBR%20%2F%3Ecom.googlecode.cppcheclipse.ui.ToolchainSettings.getIncludes(ToolchainSettings.java%3A182)%20%E3%81%A7%3CBR%20%2F%3Ecom.googlecode.cppcheclipse.ui.ToolchainSettings.getUserIncludes(ToolchainSettings.java%3A88)%20%E3%81%A7%3CBR%20%2F%3Ecom.googlecode.cppcheclipse.core.Checker.%3CINIT%3E(Checker.java%3A81)%20%E3%81%A7%3CBR%20%2F%3Ecom.googlecode.cppcheclipse.ui.Builder%24ResourceVisitor.initChecker(Builder.java%3A164)%20%E3%81%A7%3CBR%20%2F%3Ecom.googlecode.cppcheclipse.ui.Builder%24ResourceVisitor.processFile(Builder.java%3A199)%20%E3%81%A7%3CBR%20%2F%3Ecom.googlecode.cppcheclipse.ui.Builder%24ResourceVisitor.visit(Builder.java%3A122)%20%E3%81%A7%3CBR%20%2F%3Eorg.eclipse.core.internal.resources.Resource.lambda%241(Resource.java%3A154)%20%E3%81%A7%3CBR%20%2F%3Eorg.eclipse.core.internal.resources.Resource.lambda%240(Resource.java%3A122)%20%E3%81%A7%3CBR%20%2F%3Eorg.eclipse.core.internal.watson.ElementTreeIterator.doIteration(ElementTreeIterator.java%3A85)%20%E3%81%A7%3CBR%20%2F%3Eorg.eclipse.core.internal.watson.ElementTreeIterator.doIteration(ElementTreeIterator.java%3A90)%20%E3%81%A7%3CBR%20%2F%3Eorg.eclipse.core.internal.watson.ElementTreeIterator.doIteration(ElementTreeIterator.java%3A90)%20%E3%81%A7%3CBR%20%2F%3Eorg.eclipse.core.internal.watson.ElementTreeIterator.iterate(ElementTreeIterator.java%3A135)%20%E3%81%A7%3CBR%20%2F%3Eorg.eclipse.core.internal.resources.Resource.accept(Resource.java%3A131)%20%E3%81%A7%3CBR%20%2F%3Eorg.eclipse.core.internal.resources.Resource.accept(Resource.java%3A92)%20%E3%81%A7%3CBR%20%2F%3Eorg.eclipse.core.internal.resources.Resource.accept(Resource.java%3A154)%20%E3%81%A7%3CBR%20%2F%3Eorg.eclipse.core.internal.resources.Resource.accept(Resource.java%3A142)%20%E3%81%A7%3CBR%20%2F%3Ecom.googlecode.cppcheclipse.ui.Builder.processResource(Builder.java%3A306)%20%E3%81%A7%3CBR%20%2F%3Ecom.googlecode.cppcheclipse.ui.commands.RunCodeAnalysis%24RunCodeAnalysisJob.runResource(RunCodeAnalysis.java%3A26)%20%E3%81%A7%3CBR%20%2F%3Ecom.googlecode.cppcheclipse.ui.commands.ResourceSelectionJob.run(ResourceSelectionJob.java%3A44)%20%E3%81%A7%3CBR%20%2F%3Eorg.eclipse.core.internal.jobs.Worker.run(Worker.java%3A63)%20%E3%81%A7%3CBR%20%2F%3E%3CBR%20%2F%3E%E6%83%85%E5%A0%B1%EF%BC%9A%3CBR%20%2F%3E%20MCUXpresso%20IDE%20v24.12%20%5B%E3%83%93%E3%83%AB%E3%83%89%20148%5D%20%5B2025-01-10%5D%3C%2FINIT%3E%3C%2FP%3E%3CP%3ECppcheck%202.18%20%E3%82%92%E3%81%93%E3%81%93%E3%81%8B%E3%82%89%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3A%20%3CA%20href%3D%22https%3A%2F%2Fcppcheck.sourceforge.io%2F%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fcppcheck.sourceforge.io%2F%3C%2FA%3E%3CBR%20%2F%3E%E7%A7%81%E3%81%AF%E4%BB%A5%E4%B8%8B%E3%81%AE%E6%89%8B%E9%A0%86%E3%81%AB%E5%BE%93%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F%3A%20%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Fcppchecksolutions%2Fcppcheclipse%2Fwiki%2FInstallation%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fgithub.com%2Fcppchecksolutions%2Fcppcheclipse%2Fwiki%2FInstallation%3C%2FA%3E%3CBR%20%2F%3EPATH%E7%92%B0%E5%A2%83%E5%A4%89%E6%95%B0%E3%81%ABcppcheck%E3%83%91%E3%82%B9%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%97%E3%80%81MCUXpresso%E3%82%92%E5%86%8D%E8%B5%B7%E5%8B%95%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%E4%BD%95%E3%81%8B%E3%82%A2%E3%82%A4%E3%83%87%E3%82%A2%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2172219%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Could%20not%20initialize%20cppcheck%20for%20project%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2172219%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F71022%22%20target%3D%22_blank%22%3E%40rshipman%3C%2FA%3E%20%E3%80%81%3C%2FP%3E%0A%3CP%3E%E3%81%93%E3%82%8C%E3%81%AF%20MCUXpresso%20IDE%20%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%A7%E3%81%AF%E3%81%AA%E3%81%8F%E3%80%81Eclipse%20%E3%83%AC%E3%83%99%E3%83%AB%E3%81%AE%E3%83%97%E3%83%A9%E3%82%B0%E3%82%A4%E3%83%B3%E3%81%AB%E9%96%A2%E9%80%A3%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%9F%E3%82%81%E3%80%81NXP%20%E3%81%AE%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E7%AF%84%E5%9B%B2%E5%A4%96%E3%81%A7%E3%81%82%E3%82%8B%E3%81%A8%E6%80%9D%E3%82%8F%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E4%BB%A5%E4%B8%8B%E3%81%AE%E3%83%AA%E3%83%B3%E3%82%AF%E3%82%92%E3%81%94%E8%A6%A7%E3%81%AB%E3%81%AA%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E3%81%8A%E5%8B%A7%E3%82%81%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FMCUXpresso-IDE%2FStatic-Code-Analysis-Tool-cppcheck-on-MCUXpresso-IDE%2Fm-p%2F880557%22%20target%3D%22_blank%22%3EMCUXpresso%20IDE%20%E3%81%AE%E9%9D%99%E7%9A%84%E3%82%B3%E3%83%BC%E3%83%89%E8%A7%A3%E6%9E%90%E3%83%84%E3%83%BC%E3%83%AB%20cppcheck%20-%20NXP%E3%82%B3%E3%83%9F%E3%83%A5%E3%83%8B%E3%83%86%E3%82%A3%3C%2FA%3E%3CBR%20%2F%3E%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Fkwin%2Fcppcheclipse%2Fissues%2F98%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ejava.lang.NullPointerException%3A%20%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%20lib-ltc%20%E3%81%AE%20cppcheck%20%E3%82%92%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%20%C2%B7%20%E5%95%8F%E9%A1%8C%20%2398%20%C2%B7%20kwin%2Fcppcheclipse%3C%2FA%3E%3C%2FP%3E%0A%3CP%3EBR%E3%80%81%3CBR%20%2F%3E%E3%82%A8%E3%83%89%E3%82%A6%E3%82%A3%E3%83%B3%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E
