imx rt1050 processor does not contain about supported sdk components
4,311 次查看
haripankhchopra
When i using mcu expresso config toolv4 for imxrt 1050 ,it give error selected processor does not contain about supported sdk components.
8 回复数
3,782 次查看
Hello ,
Do you choose the MCUXpresso IDE when download SDK package ?
If yes,the newest version MCUXpresso IDE v10.1.0 integrated the configure tools,so  the standalone Configure tools doesn't includes MCUXpresso IDE.
Hope it helps
TIC
3,782 次查看
haripankhchopra
Hello Sir,
                  I am downloaded IMX RT 1050 SDK with all toolchains.So,how can i use with IAR and Keil and solve this problem.
3,782 次查看
marek-trmac
support for RT1050 in Config Tools is currently limited to Pins tool.
'sdk_components.xml' are needed for proper integration with toolchain project, which is currently not supported yet, but it will be added soon. In the mean time, you can use the tool without integration with toolchain project.
Also support for clock tool is planned.
Marek
Marek
NOTE: If you find the answer useful, kindly click on [ACCEPT AS SOLUTION] button
3,782 次查看
robertcox
Is there any update on when  Config tools will support CLOCK?
thanks
Bobcat
3,782 次查看
CJarvis
Robert,
The clock data for the MCUXpresso Config Tools is now available.  If you computer is connected to the internet the Config Tools will be able to retrieve the new clock data.
3,782 次查看
robertcox
Thanks for letting me know, Clark.
It doesn't seem to be available to me yet. Could you tell me how to access it?
I'm using "MCU Xpresso IDE / Help / Check for updates" with no results.
I also browsed to the downloads here, and it's still showing a 2017 download as the most recent:
MCUXpresso Config ToolsMCUXpresso Config Tools|Software Development for NXP Microcontrollers (MCUs)|...
3,782 次查看
Hi Robert,
Which chip ? Please have a look at this table, it shows the supported configure tools with different  chips:
MCUXpresso Supported Devices Table
TIC
3,783 次查看
marek-trmac
Robert, I was told it will be available in next couple of days.
Marek
Marek
