Where is board.h located ?
4,385 次查看
NicolasP
I've created a Pin/DDR configuration for a i.MX 8M Plus with "Config Tools for i.MX Version 11.0".
The generated "pin_mux.h" file includes the file "board.h".
Where is this file located ?
Similarly, the DDR tool generates the "ddr_timing.c" file.
In the comments of this file, uboot is referenced. How is this file supposed to be used ?
The help accessible from the tool does not give any answers to my questions,
Nicolas
4,376 次查看
joanxie
I suggest that you can download the latest SDK from
"https://mcuxpresso.nxp.com/en/welcome"
which includes the driver and head file you need, you also can refer to the ddr tool and user guide of ddr tool as below
"https://community.nxp.com/t5/i-MX-Processors-Knowledge-Base/i-MX-8M-Family-DDR-Tool-Release/ta-p/110...7"
pls refer to the MSCALE_DDR_Tool_User_Guide.pdf
6 回复数
4,311 次查看
NicolasP
Finally found it.
Actually, there are "board.h" in several locations. Don"t know why Windows search didn't find them before.
Just to be sure, the SDK is for the Cortex-M7 only, not the Cortex-A53. Right ?
4,308 次查看
joanxie
yes, just for M core
4,303 次查看
NicolasP
Ok.
Thanks for your support.
4,377 次查看
joanxie
4,319 次查看
NicolasP
Hello joanxie,
There is no board.h file in the SDK archive.
Nicolas
4,316 次查看
joanxie
in the "board" folder
