Support for LPC15xx
Support for LPC15xx
2,698 次查看
johnbatikian
Is there support for the pin config tool for the LPC15xx family particularly the LPC1549?
2,544 次查看
ZhangJennie
John Batikian
MCUXpresso doesn't have pin configuration tool for LPC1549.
We can use LPC Initialization instead:
LPC Initialization Tool | NXP
"The LPC Initialization Tool from NXP® makes it easy for you to create a pin configuration for your target. It generates source code which you can add to yoThe LPC Initialization Tool from NXP® makes it easy for you to create a pin configuration for your target. It generates source code which you can add to your projects"
Jun Zhang
2,545 次查看
ZhangJennie
John Batikian
Jun Zhang
2,544 次查看
johnbatikian
Thank you. This works! I could not find this from the LPC1549 overview page.
2,544 次查看
ZhangJennie
You are welcome!
