K32L2A41A How to select 1 kHz LPO as a clock source for RTC
1,643 次查看
pciampanelli
using MCUXpresso IDE I'm trying to configure RTC Clock source to be 1kHz LPO.
The peripheral tool says: "The clock configuration of the RTC peripheral is a part of the clock tool" where the clock for RTC should be selected, but I find no sign of such configuration in Clock tool.
Can anyone help please?
thanks
Paolo
1,616 次查看
RaRo
Hello @pciampanelli,
It seems that you will have to configurate the RTC Clock Configuration by yourself. You could look at the SDK's examples or call the following function: RTC_SetClockSource(), between RTC_Init() and RTC_Stop().
There you could try to set the LPO as your clock source [in fsl_rtc.h], as follows:
static inline void RTC_SetClockSource(RTC_Type *base)
    base->CR |= RTC_CR_LPOS_MASK;
Best regards, Raul.
1,603 次查看
pciampanelli
Thanks Raul,
this solves the issue
best regards,
Paolo
1,617 次查看
RaRo
Best regards, Raul.
