How to generate a simple periodic interrupt with Peripheral Tool. PIT not available in the list
4,824 次查看
MAPC
Senior Contributor I
I'm playing with Config Tools right now and I'm trying to generate a simple periodic interrupt. What is the best and easiest way to do it with Peripheral Tool?
PIT would be the best choice but it is not in the list.
Marco Coelho
4,184 次查看
Hello Aurelio,
Below is the reply from SDK team:
Unfortunatelly, the version 4 of the MCUXpresso Config Tools, contains only sub-set of the peripherals and it's being incrementally added.
I'm assigning to our marketing to consider adding PIT to next release of the data.
Hope it helps
Alice
6 回复数
4,184 次查看
 Hello Marco Coelho,
Yes, it really missing the PIT module , I  will report it to MCUXpresso config tool development team.
Which chip do you used ? Does it have FTM module ?
If yes, you  config it to periodic interrupt. Also in SDK package , there is FTM demo as a simple timer :
SDK_2.3.0_FRDM-K64F\boards\frdmk64f\driver_examples\ftm\timer
Hope it helps
Alice
4,184 次查看
MAPC
Hi Alice Yang,
I'm using MK64FN1M0VLL12 on FRDM-K64F kit.
Well, considering what we have got so far, I think that initializing PIT manually is the best option.
Thank you!
Marco Coelho
4,184 次查看
Hi Marco Coelho,
Ok, there also a PIT demo you can refer to :
SDK_2.3.0_FRDM-K64F\boards\frdmk64f\driver_examples\pit
Hope it helps
Alice
4,184 次查看
MAPC
Hi, Alice!
Any news from SDK development team about our issue?
Thanks!
Marco Coelho
4,185 次查看
Hello Aurelio,
Hope it helps
Alice
4,184 次查看
MAPC
Thank you very much, Alice!
