ConfigTools I2C setup error
2,203 次查看
popkov
Setting pins to I2C mode enables push-pull mode by default, while open-drain mode is required for normal I2C operation.
Pins version: v7.0
标记 (2)
4 回复数
2,071 次查看
Petr_H
Currently the "electrical features" settings, such as open-drain, are not handled automatically in the Pins tool. Their adjustment now has to be done by user. Thank you for the feedback, we will consider this improvement for the next versions of the tool.
best regards
Petr Hradsky
MCUXpresso config tools team
2,071 次查看
popkov
Got it.
Thanks, Petr.
2,071 次查看
Sabina_Bruce
Hope you are doing well. Could you please confim the microcontroller that you are using, so that I may check if it happens with others too.
Sabina
2,071 次查看
popkov
Hello.
MCU is Kinetis MKV58F1M0xxx24.
