after-build user-command?
1,641 次查看
butok
we need to add an after-build user-command in a Keil project.
It's present in Options for Target - User - After Build/Rebuild  Capture.PNG
Is it supported by our SDK generators?
What yml records are responsible for it?
Thank you,
Andrej Butok
1,629 次查看
nxf47831
Hi  Andrej Butok,
This feature is supported on generator branch: develop/mcu_sdk_generator
You can set command with "postbuild" tag. Here is an example:
configuration:
  tools:
    mdk:
      postbuild: # add your command
If it does not work on your side, please create a jira ticket for me to port the feature.
