I have two different problem with Blhost tool and MCUBoot. The two problems are not related to each other.
1) If I try to load led_demo application with Blhost, loading aborted and not flash
completely the application.
All works well with KinetisFlashTool instead.
What can it depend on?
2) I tried to change the bootloader uart port from UART0 to UART3. In this case the autobaud not works.
If I removed it and I fixed the UART baudrate all works well. What does the autobaud algorithm do?
It works only with OpenSda chipset?
Thank you very much!
