9S12XET256 Bootloader for Xgate
836 次查看
Lauzon_Wang
Hi there, Im reffering AN4258SW to devlope bootloader on 9S12XET256. the application without using xgate could run on the right track for yet,  while the bootloader is not available for another application within xgate.Could you please check the following .prm file if there is any porblem? Sincerely, Thanks a lot!
0 回复数
